Post Your Overclock Results.
I have my CPU clocked at 3.8Ghz for everyday use but I normally have speed step and all that other junk disabled for overclocking but I wanted to see if it was stable at 3.8Ghz with it all on.
So I did a stability test with Orthos with CPU-Z running and I notice about every 5 seconds it started jumping up to that crazy speed for a couple of seconds, it has never done that before and my computer is totally stable and running 32c normal and 47c under load.
It would be great if it could do that sort of speed, maybe one day..... 14.36Ghz WOW, I will keep on dreaming. lol
    HOME BREW
    2x2Gb Patriot PC2-6400 LL
    Inno3D GeForce GTX260 216 SP
    Liquid Cooling System
    Logitech G9 Gaming Mouse
    Logitech G15 Gaming Keyboard
That would be a fast computer at 14.36Ghz
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Photoshop.. No, it can't be. lol
ya that sure would be nice.
I run 24/7 at 4.0 Ghz, but I'm going to try to push my Max a little farther then my current (4.205 Ghz). I will this week on days off.
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
Hey guys...
Was reading this thread today and you got me all inspired.
I'll put up screenies when I get a chance...but, its going something like this:
Core2Duo E8500 3.16Ghz. Overclocked to 4.009Ghz @ 1.296V
On a GIGABYTE GA-EP45T-DS3R LGA775 IP45
Thats 422.0MHz with a 9.5 Multiplier.
Does a 1M prime in 11.80 seconds....Flies...Absolutely flies.
Stable as anything. I am quite literally amazed at this cpu and how easily it clocks.
Temps are more than comfortable @ 33 deg idle and about 45-48 under 100% load. Thats under a Thermaltake Big Typ 120VX and a lot of case fans.
Dollar for dollar these 8500's are freakin crazy value if you have the guts to throw some voltage at it.
I'd go for 4.5G but I want watercooling to do it. I am freakin stoked to get something this fast.....STABLE....I multibox Warcraft.....if it can handle a couple of hours of that, its stable.
Cheers guys....keep em coming. Loving the discussion.
Just if I may, with your case cooling....
Having lots of fans is one thing, but using them to your advantage is another. If you have a usual tower case, the kind of airflow that you are after is from front to back.. (Generally) Side fans just create turbulance inside the case and provide an opportunity for the air to get warmer. I've found the best way to have the fans set up is to have a couple of 120mm at the front, and a couple at the back also...just get a slipstream straight through. All those extra fans may look good, but they may just be warming things up....
Other than that, if you get one of those massive hovercraft fans in the side of your case....then go for it !!! some of those things are crazy....Anyhoo..
    My build
    Core2Quad Q9550 yorkfield C1 3.8G
    GIGABYTE GA-EP45-UD3R
    8gig Kingston HyperX 8500 CL5
    Gigabyte GTX280 1G...generally stock.
    onboard
    Samsung 24" 2433bw + Benq 19" FP91G+
    2 x Samsung 500G Raid0 1 x Samsung 1TB 32
    Thermaltake Toughpower 850W
    Antec twelve hundred.
    Air...a lot of air. Thermalright 120 push/pull,8 case fans,
    Logitech G5
    Logitech G15
    ADSL2
As I promised I put some benchmark results of my config :)
Here they are:
All benchmarks were made in native resolution of my LCD panel, which is 1680x1050px :) PhysX on my GPU is enabled :)
    My Own Build
    Intel Core 2 Duo E8200 @ 3.73 GHz
    ASUS P5E
    Kingston DDR2 HyperX PC2-8500 4x1GB CL5 @ 1117MHz
    Gainward GeForce 8800GT 512MB GS (700 / 1700 / 1020 MHz)
    SoundBlaster X-Fi Platinum Fatal1ty Edition
    LG Flatron W2252TQ 22"
    Seagate Barracuda 11 500GB & 750GB, Total Capacity: 1.2TB
    Corsair HX520W PSU
    AeroCool S9 Pro with 40cm Side Fan
    Scythe Mugen (Infinity) CPU Cooler, 4x Noctua NF-P12-1300
    Logitech MX1000
    Logitech Media Keyboard 600
    ADSL Broadband - 1 Mbit Down / 256 Kbit Up
    Genius SW-HF5.1 5000 Speakers, Roland RH-50 Headphones
Results with water block @4.5Ghz on 3D Mark Vantage on Entry settings and not stable on Orthos still. 40c idle and 60c under 100% load.
    HOME BREW
Nice job Mr Grim. keep pushin
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Nice Grim. I didn't know you were going water.. Not bad at all. I'd really like to water my CPU with a swifttech 220 or something. but not sure I'm ready to jump into the H2O game just yet.
and moirae not bad at all there sir. 4.0 Ghz with under 1.30v is pretty good. well under 1.3 in CPU-Z I'm assuming. with full load temps getting as high as only 48c you could for sure push that thing higher. if your only hitting maybe 48c you could easily push to 4.4 Ghz or so with that thing.. and farther for suicide runs. as long as the full load stays under 65c your ok. and sounds like your for sure under that. Well done.
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
That's OK I didn't know I was either, I went to local shop to see if they could get me some good chipset coolers and some how I got persuaded to buy the the Armour water cooled case instead lol. It's OK though I was looking at buying that case anyway, now I just need to find a good waterblock set-up for the chipset lol:):).
    HOME BREW
So you got the Thermaltake Armour Case with build in water.. what kind?
Not bad at all thre. I've been thinkin about the TT big Water kit. but idk
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
    My build
    onboard
    Logitech G5
    Logitech G15
    ADSL2
I've got the armor case...without the water at this stage...Thats coming before summer.....
Thermaltake Armor LCS VE2000 Full Tower Case Review - hardCOREware.net
Is that what you have mate?
Pretty good way to start really....Great case that one.
Yes that's the one, cost me $315 which is probably a bit much but everything cost more up in the far north, we are the end of the road. I'm very happy with it but and if you look at the price of buying the case and water set-up separately you are probably saving a few dollars.
It has a nice big front mounted Radiator and it gives you plenty of room for extra cooling for chipset and GPU. The case has good cable management and a tone of room.:)
The only things I have noticed that were a bit of a shame is the pump and tank position on the base doesn't line up with all 4 holes, so I just ended up using 2 and also the hose connection on the pump is going to make it difficult if I want to run SLI on my board.:mad:
All in all I think it's a great case and worth the money, but don't ask my partner that:zip:, as her view may be a little different, being that she hates me spending money on anything computer related...oh well lol:D
    HOME BREW
You need to spend money on yourself Grim cause she spends money on herself right.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
All in all I think it's a great board and worth the money, but don't ask my partner that:zip:, as her view may be a little different, being that she hates me spending money on anything computer related...oh well lol:D
I know that feeling lols...
Ive had my armor case for about three years now...or therabouts...Absolutely love it. Cops some criticism for the drive mounting now days, but it was absolutely brilliant when it was released...Great case for air cooling...tonnes of room and ventilation.
Giving some thought into buying a Coolermaster Cosmos S as an upgrade, and rigging that as my watercooled unit. That case alone goes for about three hunjie....I reckon you got a bargain.
Considering that the watercooling setup that I want is going to cost another $300 on top of the case.....and then I will want a new CPU to mess with....then a new GPU..........sigh
    My build
    onboard
    Logitech G5
    Logitech G15
    ADSL2
How about before and after benchmarks? How stable is it?
    16GB DDR667
    SAS RAID
Not that stable yet, failed OCCT in the first minute and failed Orthos after few seconds, might be memory timings or voltges that still need adjusting. Might give it another go tonight.
    HOME BREW
the girl doesn't like that huh.. tell her it's your hobbie and to leave you alone... I bet she shops a lot.. and gets WAY to many Shoes, or about 15 Bra's. or 35 skirts.. thats Womans hobbie. yours is your computer.. Tell her that. you'll get a little break.. or tell her she can't spend to much on her make-up then.. hahaha jk jk
I'd love to see your final benchies after you get that thing stable.. kepp up the good work
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
Well I finally have my GTX260 and here is the first Result @ Stock Speed, so xguntherc if you will, please let me know the best setting for this new Beast!
Thanks Mate!
    HOME BREW
OK had a look at some of your previous post and tried for a similar clock, but I got some artefacts at those speeds so I tried a lower clock and here is the result.
    HOME BREW
