Post Your Overclock Results.
Here's my modest OC result. Temps are OK - around 59ºC for CPU and 52ºC for the MB.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
here is my oc results. a modest oc for my rig. also i recently oc my v-cards. XFX 8600GT natural clocks GPU: 620 SHADER: 1355 MERORY: 800
OC GPU: 890 SHADER: 1504 MERORY: 860
Nice job. :)
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
How did you get a x29 when the extreme only gets x24? My i7 only is limited to x20 as it was one of the first i7's out
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
Are you asking me?
In BIOS
1. Load defaults under AI tweaker by clicking F5.
2. Disable Intel Turbo Mode Tech
3. Change CPU Ratio Setting to 29 (type in manually)
4. Change CPU Voltage to 1.4 (type in manually)
Save settings and exit (F10).
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
That i w sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet. aaaThanks
    Home made
    Gigabyte X58-UD4P
    1920x1080
    Cooler Master 1000
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
Hi, that's my config and my o.c. :
P6T
i7 920 D0
6gb DDR3 Patriot Viper 1600
WD Velociraptor 150gb
Asus GTX275
Enermax Infiniti 720w
CM RC-690
Vista H.P. x64
First test
Second test
    Venom (custom)
    i7 920 D0
    Asus P6T
    Patriot Viper 6gb 1600mhz
    Asus GTX275
    Realtek® ALC1200 8 -Channel High Definition Audio integrated
    Samsung T220 22" 2ms
    WD Velociraptor 150gb WD 320 sata II
    Cooler Master RC690
    Zerotherm Nirvana fan:2 front,1 rear,2 above,1 bottom,2 side
    Cyber Snipa Stinger
    Microsoft Sidewinder X6
    Telecom Italia 20mb/s
my over clocking result temps are around 38 when idle and around 67/68 when runing prime 95
in the picture prime 95 has been runing for just under 15 hours
    home built
    Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
    ASUS P6T Deluxe V2 iX58
    6GB (3x2GB) Corsair Dominator DDR3 1600MHz@1400mhz 8-8-8-24
    BFG GTX 285 OCX
    on board
    samsung t220 sync master
    1TB samsung
    Corsair HX1000W
    antec 902
    Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
    Microsoft Wireless Laser Desktop 7000
    6mb
    LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
Heres mine. from 1.8GHz to 2.6GHz. Intel Core 2 Duo 1.8GHz OCed to 2.6Ghz. ONE core DISABLED. heres a pic. This is on a laptop too
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
