Post Your Overclock Results.
    HOME BREW
    2x2Gb Patriot PC2-6400 LL
    Inno3D GeForce GTX260 216 SP
    Liquid Cooling System
    Logitech G9 Gaming Mouse
    Logitech G15 Gaming Keyboard
Hmmm - I haven't tried entry level yet - I always try the level recommended for my computer, P? I cannot remember - new Vista install and I haven't gotten around to installing Vantage again....
I should try that with my dual GTX 260s and my OC'd 6600....so I can justify buying a 9650 :p
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Hi John,
That is something I would like to see as I was wanting to get a second one myself to put in SLI, please post some 3DMark06 results as well. How long have you had two of those cards and how come you haven't posted your results? You have been holding out on us lol.
    HOME BREW
nice setup Mr Grim!!!
& sweet OC...... i see you grabbed the 216 260, these appear to be great performers
i will be snapping one up when i can work my other half around the need to upgrade my 88GT :p
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
This is on recommended test, never thought about a basic one either.
    Intel Q6600
    eVGA 790i Ultra
    Corsair DDR3-1333 2 x 2Gb @ 1400mhz
    2 x eVGA GTX260 Super Clocked
    Seagate 80Gb, WD 640Gb and Ext 400Gb Storage
Entry Level Test looks so bland but here it is. Mr Grim would like to see a performance test on your system :)
    Intel Q6600
    eVGA 790i Ultra
Recently I bought new case for my PC - an AeroCool S9 Pro, with a huge side fan. As this case is much wider than my previous one I decided to change my CPU cooler as well :) So I bought Scythe Mugen (Infinity) :D I also added two Noctua NF-P12 120mm fans to blow the air in and out of the case (one of them replaced the standard 120mm fan that came with the case, as it was too noisy) :)
After 30 minutes of stress testing in orthos temperature on my CPU stabilized at 49C! :D And my CPU is overclocked to 3.73GHz :D This is just awesome result, as my previous cooler under load achieved 65C :) Idle temp is 33C, but this is the lowest temp that my MB can display for the CPU, unfortunately. I bet that the idle temp is lower than that :) The cooler was definitely worth the money :D Now with this new case entire system temp is 30C, under full load (and I mean while gaming i.e. in Crisis) it increases just to 34C! :)
When I get my hands on the camera I'll post some photos of my current setup :)
    My Own Build
    Intel Core 2 Duo E8200 @ 3.73 GHz
    ASUS P5E
    Kingston DDR2 HyperX PC2-8500 4x1GB CL5 @ 1117MHz
    Gainward GeForce 8800GT 512MB GS (700 / 1700 / 1020 MHz)
    SoundBlaster X-Fi Platinum Fatal1ty Edition
    LG Flatron W2252TQ 22"
    Seagate Barracuda 11 500GB & 750GB, Total Capacity: 1.2TB
    Corsair HX520W PSU
    AeroCool S9 Pro with 40cm Side Fan
    Scythe Mugen (Infinity) CPU Cooler, 4x Noctua NF-P12-1300
    Logitech MX1000
    Logitech Media Keyboard 600
    ADSL Broadband - 1 Mbit Down / 256 Kbit Up
    Genius SW-HF5.1 5000 Speakers, Roland RH-50 Headphones
I finally got some photos of my system :) So like I said before, here they are:
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
Now that's a side fan ;) What sort of noise do you get with it?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Those Noctua fans are great, aren't they. Sooo quiet. Shame about the colour though. I have 2 x 140mm. Cut my case noise right down.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
They are good aren't they. I'm looking to get more. With fans that good, you can forgive them for being ugly ;)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Eye know, Eyeknow. They are the best. I don't run mine on silent either, so could reduce fan noise to a whisper. How's the foot-rot and mouldy clothing, Smarty. I saw how you got a drenching and I bet it was no fun either!:eek::eek:
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Surprisingly this side fan is very quiet :) On Aerocool site it states that it has around 12dB... personally I would say it gets around 16, but for a fan of this size it's a great result :) It has only 400 RPM, but according to specification it is getting around 250 CFM of air flow! :D
Yes, they are definitely worth their price :D Previously I was using NoiseBlocker fans, but Noctua beat them all the way down! Comes in a box with silicon mounting "things", which further reduce the noise and vibration :) First thing that I did when I put my PC in the new case was to replace the standard fan that Aerocool put on front of the case. I don't like my PC to light my whole room in the evening and that fan had 4 insanely-bright blue LEDs mounted in it. The other disadvantage was that it was too loud... so I bought those Noctua fans, and I got silence at last :D
All four of mine are running at full speed and the PC is very quiet :) So I recommend those fans, they are worth a buy :)
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
Lol. At least the carpets have stopped stinking ;) Others copped it much worse than we did, so all things considered we were very lucky.
I ditched the LNA adapter after a few hours. A few decibels difference doesn't bother me.
A silly question, but is that side fan an exhaust, or is it blowing inwards? I'm assuming inwards.
I get what you mean about the LED's. Sure they may look cool, but I find even tiny blue LED's annoying in the dark. Never mind a spotlight ;)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Yes, it's blowing inwards :) I hate blue LED's :p My LCD panel has a blue/orange light under the button, but this is ok, as it's not so bright, but when I bought my speakers... man, that was a surprise like with this aerocool fan :p The blue insanely-bright LED's on the control panel on subwoofer, and each of them was a big one, made watching a movie in the dark impossible, as in my room the sub is front-facing me. So I came up with an idea to darken them... somehow :p I had plenty of SD cards "write-protect" stickers laying around :p They were round and in enough size to hide those bright LED's ;) So I painted them black and made a small not-even-a-1mm hole with a needle in each one of them, and the result is that I know in which mode the speakers are, I know at which level the volume is, and the light is not "blinding" me anymore :D Simple ideas are often the best :p
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
Lol, good idea :) Since I didn't need any indicators, I just placed tape over mine.
Do you have much problem with dust getting in? I'm looking at getting a new case with a big a** fan soon-ish, but I have a lot of dust floating around that gets into everything :rolleyes: I suppose it can't be any worse than just leaving the side off...
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Well, front fan has a filter in this case, and every 5" drive bay has a meshed cap with filter too, so it's well ventilated, but the side fan doesn't have any filter. And personally I think it doesn't need one. It has a strong blow, but it takes air from side of the case, not from the bottom, and front. Dust accumulates in any case, no matter what.
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
Lol, don't I know it. I just re-arranged some things inside my case and it looks a couple of months worth of dust is in there, not a couple of weeks ;)
Thanks for the info Majkel :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
my new toy has arrived!!!! :D:D
i knew the card was big but nothing prepares you for its actual bulk!! :eek:
now to bench & OC this puppy......
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
