Vista SP1 Slipstream Installation DVD
How to Create a Vista SP1 Slipstream Installation DVD
This will show you how to create a Vista installation DVD with the Vista SP1 slipstreamed into it for any 32 and 64 bit version of Vista you want. This DVD will allow you to do a clean install of Vista with the SP1 all at once instead of installing Vista first then the SP1.
This Vista SP1 slipstream installation DVD will also allow you to run a Repair install on Vista with SP1 installed now. Before, you could not use a normal Vista installation DVD ro run a Repair install on Vista with SP1 installed since Vista with SP1 was a new version than what was on the Vista DVD.
If you have a Dell OEM computer, then see this link to help you possibly create a sliptream installation DVD from your Dell installation disc.
You can only make a 64-bit Vista DVD in a installed 64-bit Vista, and only a 32-bit Vista DVD in a installed 32-bit Vista.
REQUIREMENTS:
Microsoft has issued a note to users, of “v-Lited” Windows Vista SP1 installs, having issues upgrading to SP2. Their advice? Reinstall Windows with genuine media. For more on this, see: Short: vLite screws up Windows Vista SP1 upgrade path - Within Windows
You will need to temporarily disable your antivirus program before you start this to prevent possible interference to the vLite program below. This program is safe, but could be mistaken as not by some antivirus programs and prevent you from creating the SP1 slipstream DVD.
1. Copy the Vista Installation DVD Contents to the Desktop
A) Place the retail or OEM (not Recovery) Vista installation DVD into the DVD drive.​
NOTE: If AutoPlay or the Vista install window pops-up, just close it.​
B) Open the Start Menu and click on Computer.​
C) Right click on the DVD drive in Computer with the Vista installation DVD and click on Copy. (See screenshot below)​
D) Right click on a empty space on the desktop and click on Paste.​
NOTE: This may take a few minutes to finish copying all of the Vista installation DVD contents to the folder on the desktop.​
2. Download the SP1 Standalone Installer to the Desktop
NOTE: See Requirements at the top of the tutorial for the download links. You will need to select the same 32 bit or 64 bit version of the SP1 as the Vista installation DVD from step 1.​
A) Download and save the SP1 standalone installer to the desktop.​
3. Download and Install the vLite Program
NOTE: See Requirements at the top of the tutorial for the download link.​
A) Right click on the vLite program shortcut and click Run as Administrator.​
B) Click on Allow.​
C) If this window pops-up, then click on the Install button(s) for the missing features needed by vLite. (See screenshot below)​
NOTE: If you see the WAIK Download link, then you will need to click on the Install button to download the 1.34GB ISO WAIK file first. Next, follow the instructions at the download link:​
  • Click the Download button on this page to start the download.
  • Click on Save, and save the .iso file to your desktop.
  • Burn the saved .iso file to a DVD. You can use ISO Recorder to do this. This link will show you how to use ISO Recorder.
  • Run the DVD to install WAIK.
WARNING: There is a glitch in the vLite 1.2 version where you may receive an error about WAIK when trying to run vLite. WAIK is not always properly recognized in Vista 32 bit. You may need to manually copy and paste the wimgapi.dll file from WAIK into the root vLite folder (main folder) in C:\Programs for it to work properly.​
4. Click on the Browse button. (See screenshot below)​
5. Click on the Vista folder (created from step 1) on the desktop and click on the LRMCFRE_EN_DVD folder, then click OK. (See screenshot below)​
NOTE: You may have a different name than LRMCFRE_EN_DVD based on your type of Vista installation DVD, but it will be the one right under Vista.​
6. Click on the Vista edition that you want to use for the Vista SP1 slipstream DVD to highlight it and click OK. (See screenshot below)​
NOTE: You can only have one Vista edition per slipstream DVD. If you want to have more than one Vista edition, then you must repeat this tutorial for each individual Vista edition for their own DVD.​
7. Click on the Next button. (See screenshot below)​
8. Check both the Service Pack Slipstream and Bootable ISO boxes and click on the Next button. (See screenshot below)​
9. Click on the Select button. (See screenshot below)​
10. Select the SP1 standalone program (from step 2) on the desktop and click on the Open button. (See screenshot below)​
11. Click on Run when this window pops-up in a few seconds. (See screenshot below)​
NOTE: This runs the SP1 installer program for the vLite program only. It will not install the SP1 on your computer.​
12. This will take around 60 to 120 minutes or so to complete this part. Some older slower systems may take a bit longer. (See screenshot below)​
Enjoy your break. ;)
NOTE: In the Status box, you will see Preparing first, Extracting second, Integrating third, then this below until it is finished with this part. It will seem like it is stuck about 60% of the way, but it is not.​
13. When Finished, click on Next. (See screenshot below)​
NOTE: If this fails, then verify that you are using the same 32 bit or 64 bit versions of the Vista SP1 and Vista Installation DVD files. If they are not the same, it will fail.​
14. Under the General section, make sure that Create Image is selected and click on the Make ISO button. (See screenshot below)​
15. If the Created Image is over 4 GB
A) If this window pops-up on you with a similar message after you click on the Make ISO button (from step 14), then click on No and continue to step 16. (See screenshot below)​
NOTE: If you do not get the option to make the ISO image smaller, then see:
B) If not, then go to step 19 and skip steps 16, 17, and 18.​
16. Dot Rebuild one (Vista edition from step 5) and click OK. (See screenshot below)​
17. When finished, click on the Next button. (See screenshot below)​
NOTE: This will take a little bit to finish.​
18. Under the General section, make sure that Create Image is selected and click on the Make ISO button. (See screenshot below)​
NOTE: After the Vista and SP1 image file has been rebuilt to make it smaller, you will return to the same screen in step 14.​
19. Select the Desktop and click on the Save button. (See screenshot below)​
NOTE: This is where the ISO file will be saved when it is finished being created.​
20. When it is finished creating the ISO file, place a blank unformated DVD into the DVD drive.​
NOTE: If AutoPlay pops-up asking you to format the DVD, just close it.​
21. Under the General section, make sure that Burn Image is selected and that you have your DVD drive selected under Device. Click on the Burn button. (See screenshot below)​
22. When it is finished making the Vista SP1 Slipstream Installation DVD it will say Write Successful, then click on the Finish or Exit button. (See screenshot below)​
NOTE: It will take a few minutes to finish this. When you click Finish, it will close vLite.​
23. Remove your new Vista SP1 Slipstream Installation DVD from the DVD drive.​
NOTE: You will use this DVD the same way you did the retail Vista installation DVD.​
24. Do not forget to enable your antivirus program again.​
That's it, your done. Finally. LOL ;)
LOL, can't forget those now. ;)
For those with a "recovery partition" - check to see if it contains WAU files ( Windows Anytime Upgrade - the contents are identical to the full retail install disc ).
You can use vLite to make a bootable iso of the WAU files , burn the image to disc and you have in effect a full retail install disc.
See Shawn's tutorial on slipstreaming SP1 - obviously only check the Bootable iso box, browse to Wau files, click next, then create and burn the iso image as per the tutorial. (Don't forget - do not format the dvd - close autoplay if it pops up ).
You now have a bootable install disc identical to the full retail version - have fun !
( If you a recovery dvd it might be worth using autoplay to view the files on the dvd and then decide which if any to copy to hard disk).
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Thanks SIW2
Unfortunately I cannot find a "WAU" file anywhere.
Must have deleted it, when i went back to XP.:(
Just a thought.
If I put a spare(replace) Hdd in it, and try a full recovery, I wonder If it will make a recovery partition again?
Now harm in trying,,,,,,, (with a different HDD of coarse)
allan
this is a really cool little tool. Dose anyone know if i have to Re-Activate my version since i have the OEM Version of 32bit Vista Ultimate? becouse i do know the OEM Version of Windows XP was just 1 file that you add. but it only worked for the OEM versions
    AMD 64 X2 Dual Core 6000+
    ASUS M2N32-SLI
    Kingston DD2 800Mhz 3072 SLI Ready
    NVIDA Geforce 8800 GTS
    Seagate Barracuda 250 GB 7200 RPM
Hi Equation, and welcome to Vista Forums.
Not sure what you mean, but when you use the new Vista SP1 slipstreamd DVD to install Vista, you will still need to activate it like any other Vista you install.
Thanks SIW2
Just a thought.
allan
Allan,
No, it will not recreate the recovery partition again. :(
It is only for restoring Vista.
Sorry,
Thanks SIW2
Just a thought.
allan
Allan,
Sorry,
Thanks Shawn
I tried it, and it didn't.
Oh well, kept me amused for a little while.......:huh:
allan
No problem Allan. Sorry it did not work out for you on creating the slipstream DVD. :(
Hi Equation,
On XP you could just copy the wpa files on to a cd then copy them back after reinstall to save ringing microsoft to reactivate.
Vista reactivates online so it's no trouble - it will reactivate automatically if you checked that box during reinstall process.
Otherwise you can do it manually. See this tutorial for how it's done
How to Activate Vista Normally and by Phone Activation
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
sorry for the late post .. I was meaning is there anyway of saving the Windows Vista already activated and save it to your integrated setup.
because my old version of Windows XP Home From Alienware was only useable on 1 computer and I didn’t have to reactivate it. but I have Windows Vista Ultimate 32 / 64 OEM
And thank you Brink its good to be a member of a good forum
    ASUS M2N32-SLI
Hi Equation,
SIW2
ahh ok i just was your post :confused: lol to much java in the morning :sick:
    ASUS M2N32-SLI
hello,
some help please. i have started the tutorial and at step 12 were it starts integrating about 2 minutes after it starts my computer crashes i have tried multiple times with anti-virus and firewall on and off and also just with anti-virus off. every time i try it crashes. assistance would be appreciated.
thank you
    Vistax64
Hello Ari,
I'm not sure what may be causing that. You might also post this in the vLite forum to see if it is program specific.
MSFN Forums -> vLite
thank you although i have a question, is it possible that i still need to run it as an administrator even though i have remove UAC?
*** REMOVED BY: Brink ****
Illegal Vista duplication discussions are not allowed to be posted in the forum.
    Vistax64
That could be the problem Ari. Try enabling UAC and run the steps again with Run as administrator to see how it runs.
Hello Dadudedadude, and welcome to Vista Forums.
You may have a bad or wrong copy of the SP1. Try redownloading it and start over to see how it works for you then.
Hi Ari,
Are you trying to slipstream SP1 and remove components at the same time ?
You have a better chance of success if you slipstream Sp1 first. To remove components, do it all again as a separate operation. You just need to browse to what were the original files ( FRMCXFRE ) as vLite will have added SP1 to these.
( If you only want to make 1 disc you need to click exit at the end of step 13, otherwise make 2 discs - one being vista complete with Sp1 , and the other being vista with Sp1 and your removals. This is for safety.)
Boxes to check for removal are : Components, Bootable iso and Enable before apply, then Next. When you have ticked the components to remove, click Apply to rebuild again with the changes, then create the Iso and Burn the image to disc.
Many people have trouble integrating microsoft updates, so it's better to leave that and let Vista get the post SP1 updates after you have installed.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
