@ HexManiac,. Thanks for the info. I don't plan to overclock, but it is always worth knowing the how and why.
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Hi Dinesh,
THANKS
I get to Step 16...but can not seem to modify my scores. From my WinSPR tags in WordPad I show:
<WinSPR>
<SystemScore>5.8</SystemScore>
<MemoryScore>5.9</MemoryScore>
<CpuScore>5.8</CpuScore>
<CPUSubAggScore>4.2</CPUSubAggScore>
<VideoEncodeScore>4.3</VideoEncodeScore>
<GraphicsScore>5.9</GraphicsScore>
<GamingScore>5.9</GamingScore>
<DiskScore>5.9</DiskScore>
</WinSPR>
So my lowest score is 4.2...yet I still show 5.8.
Thanks Again. John Lak (Korki)
    Gateway GT5676
    AMD Phenom Quadcore 9600 at 2.3GHz
    Stock (Foxconn Bengal RS780)
    4 MB DIMM
    ATI Radeon HD3870 by VisionTek
    Realtek Integrated HD Audio - Stock
    ViewSonic VX-910, 19"
    1280 X 1024
    Two 320GB, 7200rpm, SATA II
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
Hi Korki,
Check your BIOS settings. Some BIOSes have the ability to disable all but one of the cores in the processor for diagnostic and compatibility reasons.
Hey Dwarf!
Thank You Very Much for your advice.
Yeah...I'm a NOOB. HOW do I chck /alter BIOS to be certain I'm getting Perfomance I paid for.
John (Korki) Lak
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
Hi John, I am not too familiar with the AMD Quad Core but I think you have got to be getting more than 4.2 exp. If BIOS isn't the culprit have a look at the Tutorial section on speeding things up in Vista.
It seems to me also that we are in danger of missing the point with exp. scores. They don't really mean too much in the scheme of things if your computor does what you want it to. What they are good for is highlighting problem areas, as in the case of my BIOS incorrectly reading my RAM sticks, and in Johns case, where he should get better results. With a 2.4 Quad core I get a 5.9 exp.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
John, I just checked the performance scores for your processor at Tomshardware. Results of the multi-threaded processor benchmark from synthetic suite 3DMark06 were Intel Quad Core 6600 - 3507, AMD Phenom 9600 - 3245. That not such a huge difference and your CPU should be giving you better results. Anybody else have any thoughts?
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
attachment.php
    Intel Core 2 Q6700
    Asus Commando
    G-Skill F2-6400CL5D-4GBPQ (2GB x 2)
    Nvdia Quadro FX 3400
    SoundMAXIntegrated Digital HD Audio
    Dell E207WFP
    1152 x 864
He may have an older BIOS and his processor clock and multiplier may not be set up properly (up to spec).
    Q9450 SLAWR
    XFX 780i
    8GB OCZ SLI 5-4-4-12@800
    XFX 8800 GTX 768MB (2)
    Auzen X-Fi Prelude / Logitech Z-5500 Digital 5.1
    Samsung Syncmaster 214T
    1600 x 1200
    300GB VelociRaptor / 750GB / 500GB / 750GB
    Antec 1000W TPQ
    Antec 900
    4 x 120mm, 1 x 200mm
    Logitech G7, Razer Lachesis
    Microsoft Entertainment Desktop 8000
    3Mb
Hee Hee!
Great responses from All. I learned a lot. Thank YOU!
I have a Gateway GT5676 bought in April '07... It's got a basic OEM MB made by Foxconn (Begal RS780) which they Do Not support. I talked to them.
The BIOS is Am Megatrends 7B3G1804 Ver. 8.00.14 dated 2/18/08... so is not so old, I think.
With the AMD Phenom 9600 Quad-core /ATI HD3870 GPU I think it is a decent gamer entry @ < $1K w/o monitor/pntr.
But will not OC (actually will Not Let me)... at least thru ATI's CCC ver 8.9 Always reverts to the default 300Mhz GPU Clock and 1170 MHz Memory clock.
ATI does have a QUANTUM FORCE HD380 BIOS Editor...which requires Flashing the BIOS but I'm too new (re: Chicken) to try.
So I'll just have to wait to get a 790gx/SB750 MB some day.
Lastly 4 point of reference my Call Of Juarez benchmark FPS scores are:
14 Min
59 Max and
30 AVG
C Ya! Time for a beverage ... a "Caucasian", ala The Dude
John
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
Hello NormCameron,
its just a cost-effective tweak who cannot afford to have RAID technology as you wanted.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
This is my original
But I disliked my Aero performance one so...
    HP Paviliion DV6670ej
    Intel Centrino Duo @ 2.0 GHz
    2046 MB RAM
    GeForce 8400M GS
    1.5 MB cable
@ Dinesh, Thanks for the heads up.
Norm
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
I don't get this, 6 gigs of ram, vista home premium x64, 2 HD video cards, .5 terabits hard drive, runs cold, figured it would be at least a 5.x?? hummmmmm...:confused:
    Me? I built this pig!
    AMD Athlon(tm) 64 X2 Dual Core Processor 5400+ 2.80GHz
    MSI - K9NSLI Platinum
    6 gigs - 2 @ 2 gig sticks and 2 @ 1 gig sticks
    2 @ Gforce 7300GT 512MB DDR
    the one on the motherboard
    3 @ DCL/LCD 21" Wide screens - 1680 x 1050 pixels
    1680 x 1050
    IDK - But I have 2 @ 250 Gig each Ones a Western Digital
    Ultra
    bunch of fans
    Logitech - Wireless
    Logitech - wireless
    comcast, 3mbs or something
Hullo Newbie13,
If you update your User profile System Specs people might be able to comment on why your score is so low.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
here's mine after some upgrades 5.8 not bad it's just my harddrive thats slowing it down some need to get one of those ssd or a 32mb cache version
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
I had a problem with my RAM and it brought all but my HDD score down. Your memory might be a bottleneck therefore reducing you entire score...
<<When you say 2 HD video cards do you mean an ATI HD something?>>
Then again i might be completely wrong about your score. WEI is not a good measuring system as it only targets some very specific components and functions. For example Quads get better scores in WEI but only really in video conversion and editing do they step above Duals.
Use 3dMark or PCMark to get a more rounded score.
I am not a great person to be talking down the WEI system really as my system is a 5.8 because of Core2Duo (see what i mean about Quads v Duos) and HDD (GPU and RAM are both 5.9).
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
wait this is stupid, someone explain how this really works please. I've got 3 gigs of ram but got a memory rating of 4.5??????? how much do u need for a high rating?
    MEDION
    Intel Core 2 Duo (2.0 Gigahertz each core)
    3 Gigabytes
    nvidia GeForce 9300M G (128 megabytes)
    1280x1800
    1 Hard Drive with 320 gigabytes of space
    Built in Webcam, fingerprint sensor, dvd/cd burner, wireless internet
Maybe your RAM is slow don't really know. I got a 5.9 rating for my ram.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Hi Tristan,
What is the configuration of your RAM? If your motherboard is capable of dual channel mode and you are using 3 x 1GB sticks then that could explain it. To get the maximum performance from your RAM in this mode, both channels need to be balanced. Any inbalance can cause the memory controller to default to single channel mode. For 3GB you need 2 sticks @ 1GB and 2 @ 512MB. It is also important that, apart from their capacity, the RAM matches in terms of speed and timing. You also need to ensure that the memory slots are correctly populated, i.e. Channel 1 Slot A and Channel 2 Slot A need to be the same as do both slot Bs (these might be colour-coded, in which case you need to ensure that slots of the same colour have identical RAM in them). Check you motherboard manual for any limitations that may exist as regards RAM capacity and also the effect of using all available slots. For example, some older systems had limitations which meant that although they were capable of supporting 4GB of RAM they could only do so with 4 x 1GB sticks, and they could only do so by reducing the memory speed so instead of running at, say, DDR-400 rate it would only be running at DDR-333 rate. This reduces the memory bandwidth.
For best performance, I would either stick with just 2GB or go with 4GB but in the form of 2 x 2GB sticks.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
I get a 5.9 on my RAM because i payed $230 AUD and got 1066MHz RAM with 5-5-5-15 timings. You might only have 800MHz @ 5-5-5-18.
I like what Dwarf said. Take a stick out and see if your score gets higher.
Dwarf i have 4x1GB sticks and there is no speed reduction however you were talking about older mobos.
EDIT: Tristan-117 i might be wrong but when i looked at your sysytem specs it seems that you are using a laptop. Is this correct? If so i will let you knwo that a laptop will ALWAYS score lower than a desktop. Even with the exact same hardware in a desktop and a laptop the desktop will come out on top.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
thanks for that info, and yes i am using a notebook/laptop
    MEDION
    3 Gigabytes
    1280x1800
