Here is my updated WEI for my new system.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Dwarf, What Memory are you using?
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
attachment.php
Gateway GT5676, Quad Phenoms, ATI HD3870, Corsair TX650w
    Gateway GT5676
    AMD Phenom Quadcore 9600 at 2.3GHz
    Stock (Foxconn Bengal RS780)
    4 MB DIMM
    ATI Radeon HD3870 by VisionTek
    Realtek Integrated HD Audio - Stock
    ViewSonic VX-910, 19"
    1280 X 1024
    Two 320GB, 7200rpm, SATA II
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
If I have a Quad Core ... why does WinExp show only having 1 core?
    Gateway GT5676
    4 MB DIMM
    1280 X 1024
    Corsair TX650W
    Micro ATX, Gateway
    Stock
    Stock
    Stock
    3 MB
    Gigabyte IF233
Hi Korki,
Check your BIOS settings. Some BIOSes have the ability to disable all but one of the cores in the processor for diagnostic and compatibility reasons.
    Gigabyte IF233
Specs in my sig. I plan on getting an E8400 soon enough though.
    Home Brew
    Intel E7200
    Gigabyte EP45-UD3P
    Kingston 4GB DDR2-800
    ATi Radeon HD3870 PCIe
    Creative Labs Audigy 2
    Samsung SyncMaster 940BW
    Seagate 7200.10 SATAII 250GB x2 RAID 0 Western Digital 640AAKS
    Antec Neo550
    Antec P180
    Zalman 9500
    Logitech S510 Combo
    Logitech S510 Combo
    Comcast @ 10Mb
I have to say that my little lappy compares extremely favourably to some of the rigs posted on here. I do not have any major graphics card, only an nVidia Geforce 8600M GS and 4gb ram and my index score is not that bad!:party:
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
Thanks Dwarf, I am running The Xtreem Dark DDR2-800 which " uses choice die from original manufacturers and is equipped with the Aluminum heat-sink printed with the Xtreem logo like its brother in the same series. Besides ventilation, the heat-sink brings a special tone to make the product both reliable and attractive. In terms of performance, besides a data transfer bandwidth at 6.4Gpbs, the timing configuration of the Xtreem Dark DDR2-800 is 4(CL)-4(tRCD)-4(tRP)-12(tRAS). From the viewpoint of CAS latency (CL), the factor affecting performance most, as the CL of most DDR2-800 modules is 5, the Xtreem Dark DDR2-800 can display the uniqueness of the DDR400+ specification." The spec are a little higher than your Corsair, yet you get a 5.9 compared to my 5.7?
Hi Les, that score is PRETTY GOOD for a laptop,
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
The FSB has quite a bit to do with memory throughput. I switched out a Q6600 with a Q9450 (and changed absolutely nothing else) and memory went from a 5.4 to a 5.8. After a new BIOS and some memory settings tweaking, I was finally able to get it to 5.9.
    Q9450 SLAWR
    XFX 780i
    8GB OCZ SLI 5-4-4-12@800
    XFX 8800 GTX 768MB (2)
    Auzen X-Fi Prelude / Logitech Z-5500 Digital 5.1
    Samsung Syncmaster 214T
    1600 x 1200
    300GB VelociRaptor / 750GB / 500GB / 750GB
    Antec 1000W TPQ
    Antec 900
    4 x 120mm, 1 x 200mm
    Logitech G7, Razer Lachesis
    Microsoft Entertainment Desktop 8000
    3Mb
I fixed my memory. Now 5.9. Bios was recognizing it as 677mhz, 5,5,5,15. Changed it in Bios to manufacturers settings - 800mhz, 4,4,4,12 and voila. Thanks for the advice fellas. Take a pat on the back and a brownie point each from me. Now, how do I fix my 5.7 exp on the Hard Drives, Ha, ha
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Here’s what mine looked like:
Close the window. Time to create an extra XML file. You need to Update your score, to do so use the steps outlined here. Once it has completed you are ready to start the process:
To access the XML file, follow these steps:
  1. Open the Windows Explorer and navigate to the Windows directory.
  2. Open the Performance directory, followed by the WinSAT directory.
  3. Open the DataStore folder.
  4. You will see two or more XML files, we want to work with the most recent one (the one you just created).
  5. Right-click the file and select Properties.
  6. Click the Security tab.
  7. Click the Edit button.
  8. When the UAC prompt appears, click Continue.
  9. Click the Add button.
  10. Input your username and click OK.
  11. Select the username and then click the Full Control checkbox in the Allow column.
  12. Click OK.
  13. When the Security prompt appears, click Yes.
  14. We can now modify the file. Right-click the XML file, click Open With and select WordPad.
  15. Look for the information within the WinSPR tags.
  16. Modify the scores. Remember, your base score will be the lowest value of the 5 subscores. Make it realistic, nobody is going to be fooled with a massive increase in your score.
  17. Save the file.
Now go back to the Performance Information and Tools window and check your modified score. Here’s my modification:
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
A RAID would probably do it. A boost in FSB might give you enough. Buying a new WD Raptor or Velociraptor would do it. But 5.7 is nothing to look down on. That is a fast system, no doubts.
    Q9450 SLAWR
    XFX 780i
    1600 x 1200
    Antec 1000W TPQ
    Antec 900
    3Mb
My RAID 0 array gives me 5.9.
It could also be because i'm using SATA II drives with 32Mb of cache. Not sure how Vista determines the difference in scores.
I'm only using 7200RPM drives FYI
    Intel Q9550 @ 3.2Ghz (OC)
    4 GIG DDR2-6400
    ATI Radeon 3750
    Creative X-Fi
    22" LCD
    1680 x 1050
    (2) 500 Gig SATAII 32mb Cache in RAID 0 array
    Antec TruPower 650W
    10Mbps Cable
Thanks Guys, Dinesh, I am not sure thats the type of imorovement I wanted. I think Raid might be the option. I looked at FSB but until I get better CPU and Northbridge cooling I don't want to do any overclocking. Just a question though, how would an FSB boost cause an increase in hard drive performance?
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Well Guys, a little bit of tweaking and beat this -
My SystemIntel Quad Core 6600
Asus P5B
4096 MB Xtreme-Dark 800mhz 4,4,4,12
Samsung 206BW 1680 X 1024
4 X Samsung 500GB 7200rpm Serial ATA-II HDD w. 16MB Cache
550 w PSU
Thermaltake Case
ADOBE Photoshop
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Can't beat it NormCameron, Vista Home Basic sucks cause of no aero.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Yeah. Of course I had to tweak my system. I boosted the FSB, finurgled the RAM and bamboozled the PCI. Oh, and the best thing, the one that gave me the biggest boost in my Windows Experience Score was installing Adobe Photoshop.
    Scratch Built
    Asus P5B
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
Also I have OEM crap motherboard so I can't tweak anything only upgraded ram and installed a graphics card cause onboard sucks.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Since most of the data transfers from disk are actually from cache memory through the disk controller and the disk controller runs at bus frequency, adjusting the FSB could improve transfer rates. It could also jack up your disk, too. In most cases, read/write speed of a drive cannot be adjusted. But with the increased usage of cache in drives today, it's possible. I don't overclock my systems, so I could not tell you if it does.
    Q9450 SLAWR
    XFX 780i
    1600 x 1200
    Antec 1000W TPQ
    Antec 900
    3Mb
