Hi Chevell,
That's impressive - disk transfer rate looks great too. What are your components?
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Updated BIOS, set up RAM....
    Q9450 SLAWR
    XFX 780i
    8GB OCZ SLI 5-4-4-12@800
    XFX 8800 GTX 768MB (2)
    Auzen X-Fi Prelude / Logitech Z-5500 Digital 5.1
    Samsung Syncmaster 214T
    1600 x 1200
    300GB VelociRaptor / 750GB / 500GB / 750GB
    Antec 1000W TPQ
    Antec 900
    4 x 120mm, 1 x 200mm
    Logitech G7, Razer Lachesis
    Microsoft Entertainment Desktop 8000
    3Mb
Here is mine, but my gaming graphics is hurting the score a lot, how did anybody go about fixing that issue?
--Mina
    1.5G Intel Centrino Core2 Duo
    4GB DDR2 SDRAM
    Intel Graphics X3100 w/ 251MB
    160GB (5400RPM) serial ATA hard drive
--Mina
Go to 'User CP' and enter your system details into System Spec and if you like into your Signature so they appear after every post. That way someone will comment on your graphics card (and let's know what driver you are using)
Kotuku
    Intel Core2 Extreme Quad Core
    XFX MB-N790-IUL9 NFORCE 790 U
    4 Gb (2x2) Gskill DD3 1600
    XFX 9800GX2 Black Ed. 1Gb DD3
    2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
--Mina
Kotuku
Thanks Kotuku,
Done.
    4GB DDR2 SDRAM
here's mine my ram seems to let my score down not really sure how to solve this yetCapture.JPG
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
Hi Chevell,
SIW2
Thermaltake XaserV Case
EVGA 132-CK-NF78 780i
PSU: Thermaltake Toughpower 1000 watt
CPU: E6750 8x475 3800 MHz lapped 59c AIR prime95 small ft's
RAM: Gskill 4x1GB DDR2 PC2-6400 @1000 mhz 4 4 4 12
GPU: GTX280 @724/1505/1222 EVGA precision tune utility.
HDD: WD 2x250 GB Raid0
SND: Asus Xonar D2
OPT: Samsung Super Write Master D/L burner
HS: Xigmatek S1283 W/TT 120mm Smartfan
Op system: Vista X64 Home premium
http://service.futuremark.com/compare?3dm06=7642807
http://service.futuremark.com/compare?3dmv=314702
It's a fairly low budget gaming system but it still has some room for upgrades.
    E6750
    EVGA 780i
    GSkill PC6400 @ 1000MHZ 4 4 4 12
    280-GTX
    2X250 GB WD
My score is limited by my dual single core 244 opterons at 4.7. Otherwise everything is up there at 5.9 or so. What is the point that I would see anything from changing to dual core processors. Is it even worth it?
    Built by me with help from a lot of different newsgroups
    2 dual core 275 opterons
    tyan 2885
    4 gigs corsair reg ecc
    ATI 3850 agp graphic card
    1 SynMaster 2253LW 1 SyncMaster 206BW samsung 32 inch LCD
    1680 x 1050 1600 x 900 still working on it
    Highpoint raid 1820 raid 5 5 raptors, just repaired 3 more for photos scratch spare
    2 power supplies about 1500 total watts
    2 Thermaltake cases married together
    stock
    logitec wireless trackball
    logitech wireless
    DSL 1024 down 350 up, wireless mesh 4500 down 3500 up
    Win tv 1600 with satalite tv connected to it. just had to replace primary monitor, old just plain failed 2253 LW is pretty cool almost 4 more inches wide mode than previous which was big, this is massive almost don't need second monitor
Thanks For helping with my selection, it worked out really well :)
    AMD AM2 Athlon 64 X2 6000+
    MSI K9A2 Platinum
    2GB (2x1GB) Matched Corsair DDR2 Memory 800
    Sapphire Radeon 4870 512MB
    On Board (Upgrade soon)
    17" :Hansol CRT Monitor
    1024x768
    500GB Western Digital Caviar 7200rpm
    Corsair TX750W
    Antec 900
    3x120mm Case fans, 1x200mm Exhaust Fan, Stock CPU Cooler
    Genius Netscroll+Eye Ruby
    IBM KB-9910
    Up to 16mb usually around 6-8MB
    CPU Temp at almost full load was around 36oC, Graphics Card rarely goes above 58oC
New to the forum....
    Q9550 2.83 Quad
    8 GB OCZ 800MHz
    Nvidia 9800 GT 1GB
    LG 24
    2 500 GB 32MB Seagate( Raid 0 ) 1 1000 GB 32MB Seagate
    PC P{ower and Cooler 1000W
    HP d5000t ATX CTO
with a wee bit of tweaking i got it up to 5.8 now to find a hard drive that goes faster
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
I had that same issue until I got my Seagate W/32 MB cache. Made a BIG :eek: difference.
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
sounds quick that i got the one with 16MB cache not bad though my ram was at 5'6 untill i OC'd my cpu to 3.0Ghz
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
The Hard Disk ****s my Score.
Well, to get a 1-10 grade, you only have to get your result, x10, and :5,9
Ex: 3D Bussines - 5.5
5.5 x 10 : 5,9 = 9.2
Btw, how do i tweak my HD?
    Asus G2s
    2.20 GHz Core 2 Duo T7500 :\Santa Rosa/:
    1x 2GB DDR2 Kingston ; 1x 1GB DDR2 Kingston
    Nvidia GEFORCE 8600M GT 256mb Dedicated, 768mb RAM
    17" Generic PnP
    1440x1280
    300 GB Fujitsu MHX2300BT 4200 RPM
    ALPS Pointing Device ; Logitech Asus G2 Mouse
    Asus G2s Keyboard from Logitech
    2 MB Wireless Network
Haven't done any tweaking/optimization to date, but will be doing so (eventually)...
Strangely, after I got this computer, a software update for my graphics card (NVidia GeForce 8600GT) came out a month or so after. Then I re-tested my WEI and the Graphics dropped by 0.2 points!
Ah, well. I'm still very happy with my computer - and that's all that matters.
    Dell Inspiron 1720
    Intel Core Duo Processor T8300
    3072MB Dual Channel
    NVIDIA GeForce 8600M GT
I've just got my machine, it's got an Intel Core2Duo 2.4 GHz with 2 GB RAM trouble though it has onboard graphics which is why the score is low. It's OK though as I'm not a gamer.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
here ya go
    Sager 9261/Clevo D900C
    Core 2 Extreme x6800 2.93GHz
    4ghz
    dual Geforce Go 7950 GTX SLI
    Dual 200g raid0
