GTA 4 Minimum Requirements
Even though I've got this on the 360, I was looking forward to a PC version because of mods. Looks like I'll stick with the 360 and it's overpriced DLC :rolleyes:
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
It's a big release for Rockstar, so the patch will most likely be released next week.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
while seaching the web I found this article:
"The PC version of Grand Theft Auto IV has to deal with some problems on its release. But Rockstar already is working on solutions and just provided PCGH with possible solutions for three bugs that have been identified.
Issue 1 - Fatal Error MMA10 on saving the game.
Possible Solution 1 - Sign out of the Rockstar Social Club, on starting the game skip the login . This allows the game to start. If you are connected to the internet, you will be prompted to login to Game For Windows Live (GFWL). If you login to this the game will save without issues.
However if you are not connected to the internet, GFWL has an offline mode. If you try to save at your safe house, it will advise you to login. From here choose YES and the game will appear to freeze for a second, hold down the Alt and press Tab to go back to your desktop. You will see the option to sign into GFWL Offline mode, do this and then ALT + Tab back into the game. This should allow you to save, although it may take you to the beginning of the game.
Possible Solution 2 - Install .net Framework 3.5, also unconfirmed but .net Framework 1.1 may need to be installed first.
Issue 2 - Graphical distortion using an NVIDIA 7900 video card
Solution - Install and use the latest beta driver for the 7 series video cards.
Rockstar explicitly points out that the use of Beta drivers is done at one's own risk
Windows XP (32 bit) - 180.70
Windows XP (64 bit) - 180.60
Windows Vista (32 bit) -180.60
Windows Vista (64 bit) - 180.60
Issue 3 - General crashes/freezes
Solution - Install all the latest updates for Windows. Including service packs (SP3 for XP and SP1 for Vista). Close background applications.
Update: 2008-12-04
Rockstar is trying to get all problems of the GTA 4 PC version solved as fast as possible. On the GTA 4 support site of Rockstar Games several issues and their solutions have been listed.
The chart below shows all currently known problems and possible solutions.
RMN20 - Windows Vista: Need to have Service Pack 1 or higher to proceed.
RMN30 - Windows XP 64 / Server 2003: Need to have Service Pack 2 or higher to proceed.
RMN40 - Windows XP: Need to have Service Pack 3 or higher to proceed.
DD3D50 - D3D Error - DirectX 9 video card required.
TEXP110 - D3D Error - Failed to create texture - Please restart the game.
DWIN20 - D3D Error - Failed to query memory. Please re-start the game.
DD3D10 - D3D Error - Please re-boot your system.
DD3D30 - D3D Error - Please re-boot your system.
DWIN30 - D3D Error - Please re-boot your system.
DD3D20 - D3D Error - Please re-install the game and/or re-install DirectX.
DWIN10 - D3D Error - Please restart the game.
DD3D60 - D3D Error - Shader Model 3.0 or higher is required.
DD3D70 - D3D Error - Unable to retrieve D3D Device. Please re-boot your system.
GPUP10 - D3D Error - Unable to retrieve D3D Device. Please re-boot your system.
TEXP20 - D3D Error - Unable to retrieve D3D Device. Please re-boot your system.
TEXP30 - D3D Error - Unable to retrieve D3D Device. Please re-boot your system.
TEXP80 - D3D Error - Unable to retrieve D3D Device. Please re-boot your system.
DD3D40 - D3D Error - Unable to retrieve device capabilities. Please install latest video card driver and/or re-install DirectX.
TEXP10 - D3D Error - Unable to retrieve device capabilities. Please install latest video card driver and/or re-install DirectX.
DD3D80 - D3D reset failed - Please restart the game.
STRB10 - Failed to delete file - Please re-boot your system.
RMN10 - Failed to read file - Please re-boot your system.
STRM10 - Failed to read file - Please re-boot your system.
STRM20 - Failed to read file - Please re-boot your system.
BNDL10 - Failed to write file – Please re-boot your system.
STBF10 - Failed to write file – Please re-boot your system.
VOIC10 - Fatal voice chat error - Please restart the game.
RESC10 - Out of video memory - Please re-boot your system.
BA10 - Out of virtual memory - Please re-boot your system.
EA10 - Out of virtual memory - Please re-boot your system.
TEXP60 - Unable to create color render target - Please re-install DirectX and/or install the latest video card driver.
TEXP70 - Unable to create depth render target - Please re-install DirectX and/or install the latest video card driver.
AE10 - Insufficient Memory to Start Game - Please close some applications and restart the game.
PC10 - Unable to retrieve D3D Device - Please reboot your machine or reinstall your display driver.
TF10 - Unable to write to disk - Please restart the game.
WS20 - InitWinSock failed - Please re-boot your system and/or re-install the game.
WS30 - InitWinSock failed - Please re-boot your system and/or re-install the game.
http://www.pcgameshardware.com/aid,6...and_solutions/
    My Own Build
    Intel Core 2 Duo E8200 @ 3.73 GHz
    ASUS P5E
    Kingston DDR2 HyperX PC2-8500 4x1GB CL5 @ 1117MHz
    Gainward GeForce 8800GT 512MB GS (700 / 1700 / 1020 MHz)
    SoundBlaster X-Fi Platinum Fatal1ty Edition
    LG Flatron W2252TQ 22"
    Seagate Barracuda 11 500GB & 750GB, Total Capacity: 1.2TB
    Corsair HX520W PSU
    AeroCool S9 Pro with 40cm Side Fan
    Scythe Mugen (Infinity) CPU Cooler, 4x Noctua NF-P12-1300
    Logitech MX1000
    Logitech Media Keyboard 600
    ADSL Broadband - 1 Mbit Down / 256 Kbit Up
    Genius SW-HF5.1 5000 Speakers, Roland RH-50 Headphones
The only possible solution that I've heard may work is to defrag your hard drive once the install has finished (obviously!!!, wouldnt be a good idea to do it during the install no would it :rolleyes:). I havent had a chance to test it out yet but will do when i get home from work.
    AMD Athlon 64 X2 4800
    ASUS M2N-SLI Deluxe
    4GB OCZ PC-6400
    Sapphire HD4850 Toxic Edition
    Samsung SM2493HW
    500GB Seagate, 160GB Seagate
    Corsair HX520W
    Antec P182 Gunmetal Grey
I'll give that a try when I get home as well.
You can add a couple of extra parameters to a shortcut by going to the GTA 4 directory and making a shortcut of LaunchGTAIV.exe and then adding "-norestrictions -nomemrestrict" without the quotes, to the end of the shortcut path.
This will allow you to change the graphic settings to what you want and improves performance a bit for me as well.
Though to get it running with the paremeters, you need to log in to Social Club first, then launch the shortcut you made manually.
    ASUS Xonar DX
    100Mbps
OK i dunno if anybody ever heard of this site, but this pretty much solves all your problems when you are wondering if your desktop/notebook can handle games...
I use it all the time before... eeermm... buying a game.
Just click here and you'll know if your pc can run it in 2minutes :D
Have fun with it guys :D
~Willem
My PC meets the requirements, only it recommends a quad core and I have a dual core, but even people with quad core extremes are getting low performance.
The problem is the game is too CPU dependant.
    ASUS Xonar DX
    100Mbps
Do you mean in the target box? If so how exactly? I have tried it and it won't let me. I've tried after the end quotes and before but neither work. :confused:
Sorry scratch that. I worked it out. I missed out a space!! Ooops.
    ASUS M2N-SLI Deluxe
    4GB OCZ PC-6400
    Samsung SM2493HW
    Corsair HX520W
Grand Theft Auto IV by Rockstar Games
Apparently these drivers can fix some issues with the game. Found them on the Steam GTA forums. Some people seemed to have benefited from them, others either get worse performance or no difference. Not tried them myself yet though.
Apparently Rockstar and Nvidia are working together to optimise some drivers for the game.
Be careful using them drivers. A few people have experience a lot of graphic corruption even on the desktop when idle with them. I think they're mainly for 7900 graphic card users who are playing the game. So make sure you install them properly (uninstall current drivers>boot in to safe mode>driver sweeper>reboot and back in to safe mode>install drivers>reboot back to Windows)
    ASUS Xonar DX
    100Mbps
I tried a defrag and what everlong suggested with changing the shortcut and I've got it playable but it looks ****. I'm gonna have a look on the ati forums to see if there's anything on there
    ASUS M2N-SLI Deluxe
    4GB OCZ PC-6400
    Samsung SM2493HW
    Corsair HX520W
A patch is going to be released in the next few days. Rockstar have the patch, but because the game is a Windows Live game, Microsoft need to approve of it being released.
GTAForums.com -> Help with Grand theft Auto IV PC
Also be careful using them drivers. A few people have experience a lot of graphic corruption even on the desktop when idle with them. I think they're mainly for 7900 graphic card users who are playing the game.
    ASUS Xonar DX
    100Mbps
Are people getting the feeling that GTA 4 might be getting quite a few patches....
I'm guessing the PC version works with the 360 controller?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Acer ASPIRE 5930G Platform: Intel Centrino 2
    Intel® Core™2 Duo mobile processor P7350 2.1GHz
    Mobile Intel PM45 Express
    2X2GB DDRII 667MHz
    NVIDIA GeForce 9600M GT 512MB DDR3
    250GB SATA 5400 RPM
It does, but there are quite a few bugs apparently. The patch apparently fixes them.
    ASUS Xonar DX
    100Mbps
Is GTA4 working on Vista 64bit?
Cause... i am gonna buy it soon...
yes, it's working without any problems on 64bit OS :) I have it and it runs fine :D
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
I've installed it and I can comfortably play it at '360' standards. I've still got plenty of tweaking to do though. So far I haven't had any troubles with it, so it may affect nvidia cards more than ATI.
I also defragged the HD the day before and did it again after the GTA4 install and it was 8% fragmented just from the installation :p
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
I've got it running at 30fps average in game, that's pretty much with any setting as well, I had the textures on "High" and the Renderer on "Highest" with all the sliders around half, but then I saved and the memory leak kicked in and it just stuck at 15-20fps.
Hope Microsoft would hurry up and approve this patch.
    ASUS Xonar DX
    100Mbps
I got mine runinng at 35-40fps :) there are some areas when it drops to 25-27, but very rarely... running on my LCD's native resoluion, textures on medium, renderer on highest, and the sliders just below half :)
even on medium settings the game still looks brilliant :D
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
It doesn't look brilliant. The particle system is messed up, shadows look horrible and there's no anti-aliasing. :huh:
    ASUS Xonar DX
    100Mbps
