GTA 4 Minimum Requirements
got this game at xmas,and it works perfectly fine on my Dual Core 3.00GHz with 9800 GT OC,as for a second patch well it doesnt look like rockstar are planning on releasing one anytime soon,great game,but seems to be giving most owners problems,read an artical on gta forums that said over 90% of ppl had issues with it.Rockstar have a lot of making up to do!!
    Own
    AMD FX 8120 Black Edition,3.1GHz oc'd to 4GHz
    Gigabyte GA-990FXA-UD7
    Corsair Vengeance 12GB DDR3 1600Mhz
    EVGA GTX 570 HD SuperClocked
    24" BenQ EW2430 LED Monitor
    1920x1080
    2TB Seagate ST2000DM001 Barracuda 7200,SATA 3 6GB/s. 128GB OCZ Octane, 2.5" SSD.
    850W Powercool PCPC850AUBA
    Xclio Touch 767 Full Tower,With Touch Panel.
    Antec Kúhler H2O 620 Watercooler
    Sharkoon FireGlider Gaming Mouse
    Razer Arctosa Black Edition Gaming Keyboard
    Virgin 30-35Mb/s
    Krator N4-21U26W Neso4 Avante Garde 2.1 Speaker
Was looking on play.com for GTA4 and found the minimum requirements:
Windows XP with SP3 / Vista with SP1
1.8GHz Intel Core 2 Duo, 2.4GHz AMD Athlon X2 64 or equivalent
1GB RAM (1.5GB for Vista)
16GB HDD Space
256MB nVidia 7900, ATi X1900 or equivalent
DVD-ROM Drive
Internet connection required for installation and online play
They seem pretty steep for minimum, more of a recommended. Especially the graphic cards, the 7900 is still quite a high end DX9 card.
There is a software issue on my end I am guessing...I have a GTX 295 nVidia and it is sluggish with the game at full settings. It sucks.
    Home Built
    Intel Core 2 Quad Q9300 Yorkfield 2.5GHz
    GIGABYTE GA-EP45T-UD3P LGA 775 Intel P45
    Kingston 8 Gig DDR3
    ASUS nVidia GTX 295 2Gig Memory
    On Board
    28 inch Widescreen HDMI
    1900x1200
    Seagate Barracuda 7200rpm 750GB Seagate Barracuda 7200rpm 500GB
    Ultra X3 ULT40071 850-Watt Power Supply Modular
    RAIDMAX SMILODON ATX-612WBP Black
    5 fans
    wireless
    Cable Modem - Wireless
I am one of them. I can run Call of Duty W@W at 1900x1200 full settings and it runs fine, but with GTA its sluggish. :(
    Home Built
    Kingston 8 Gig DDR3
    On Board
    1900x1200
    5 fans
    wireless
16GB HDD Space
DVD-ROM Drive
i can understand that because the 295gtx is effectively using SLI and the game doesnt support SLI just yet, so your pretty much using a single 260gtx.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Got it to work. Did a benchmark and got 34fps. Looks great. Not at high. End yet but when they support sli I should be in good shape:)
    Home Built
    Kingston 8 Gig DDR3
    On Board
    1900x1200
    5 fans
    wireless
i wouldnt mind having that card though, its sexay
    16Mb Sky bb
Second patch is out :] you may obtain it through LIVE or download it and install it manually.
Here's a short list of what has been fixed/added:
Graphics Menu:
Added "Water Quality", "Shadow Quality" and "Reflection Resolution" sliders in graphics menu.
Added "Definition" and "VSync" toggles in graphics menu.
Rendering optimizations.
VSync optimizations.
Nvidia 7000 series
Mirrors fixed
PATCH 1 FIXES:
Direct input device support is now disabled by default and can only be enabled with the commandline: "-usedirectinput"
Supported Controllers:
Logitech Dual Action
Logitech RumblePad 2
Logitech Cordless RumblePad 2
Saitek P2500
Supported Wheels:
Note: Controls are unmapped, user must map controls using Manufacturer's mapping software.
Logitech G25 Racing Wheel
Logitech Wingman Formula GP Wheel
Logitech MOMO Racing
MOMO Force
Driving Force Pro
Driving Force
Formula Force
Added Commandline "-notimefix" which will help some users who are experiencing the fast/slow gameplay issue after patch 1 was applied.
Fixed a bug that caused some users to experience endless looping audio effects after Patch 1 was applied.
Benchmark was disabling sounds after Patch 1 was applied, this is now fixed.
CRASH FIXES:
Unable to load game fixed - For some users, a DOS window would open and close immediately upon Game Launch, GTA IV would never launch.
Hang on Initial Game Loading Screen fixed - Some users experienced Character Art Loading screens in an endless loop.
Certain causes of the RESC10 error have been fixed (Alt-Tab, change resolution). If you experience an RESC10 error, you must restart.
Certain Instances of the "GRAND THEFT AUTO IV has encountered a problem and needs to close" error have been fixed.
VIDEO EDITOR:
Naming clips is now mandatory on Export
MULTIPLAYER:
Legitimate players being kicked from Multiplayer matches has been fixed.
GENERAL ADDITIONS / FIXES:
Wireless 360 controllers not functioning - Triggers were full on/off, fixed.
In the Options menu accessed from the Title Screen a “Game” section has been added with the ability to turn Clip capture on/off.
Download:
Patches and Fixes: Grand Theft Auto 4 v1.0.2.0 Patch - Demo Movie Patch Download Section - GamersHell.com
    My Own Build
    Intel Core 2 Duo E8200 @ 3.73 GHz
    ASUS P5E
    Kingston DDR2 HyperX PC2-8500 4x1GB CL5 @ 1117MHz
    Gainward GeForce 8800GT 512MB GS (700 / 1700 / 1020 MHz)
    SoundBlaster X-Fi Platinum Fatal1ty Edition
    LG Flatron W2252TQ 22"
    Seagate Barracuda 11 500GB & 750GB, Total Capacity: 1.2TB
    Corsair HX520W PSU
    AeroCool S9 Pro with 40cm Side Fan
    Scythe Mugen (Infinity) CPU Cooler, 4x Noctua NF-P12-1300
    Logitech MX1000
    Logitech Media Keyboard 600
    ADSL Broadband - 1 Mbit Down / 256 Kbit Up
    Genius SW-HF5.1 5000 Speakers, Roland RH-50 Headphones
Nice one, thanks :)
Edit: Tried the patch out, and with the 181.22 drivers, the shadows have lost their smoothness with how they were in the previous patch :/
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Graphics Menu:
Nvidia 7000 series
Mirrors fixed
PATCH 1 FIXES:
Saitek P2500
Supported Wheels:
MOMO Force
Driving Force Pro
Driving Force
Formula Force
CRASH FIXES:
VIDEO EDITOR:
MULTIPLAYER:
Download:
finally the triggers are fixed, yay. i got well annoyed, you couldnt hold the trigger half way down with the 360pad, kept thinking it was held all the way down :)
    16Mb Sky bb
i lost all my mods when i installed the latest patch, & i had quite a few...:(
but it seems pretty stable now, fps wise...
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
which mods have you used, skunk ? and what did they do ? :)
I played with Alice God Mod, but it also stopped working... but as you said, the game runs more smoothly now, even that it was smooth before the patch, but now it's poetry :D
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
i had a good few mods running on my GTA4, the ones i remember are listed below
steering mod....... this is a MUST if using the keyboard & mouse, it takes away the ''ice rink'' effect from the handling of the cars...
Ericsson phone mod......this is just a bit of fun, it changes his mobile phone..
heavy weapons mod...... gives you all heavy weapons..
Hitler mod...... changes nico to hitler...lol :p
no intro mod..... this one is great, remove all ads from game startup & load straight to game...
NYPD car mod...... changed from LCPD..
real car names mod.......pretty self explanatory...
& a few other little tweaks that all have to be replaced in the directory :(
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Third patch is out :] you may obtain it through LIVE or download it and install it manually.
Version 1.0.3.0 - March 19, 2009
GRAPHICS:
  • Interior Lights for ATI 1900 series cards:
    • All light sources appear for users with 1900 series ATI cards. (ie. Pool Mini Game)
    • ALT-TAB fixed
  • Graphics Settings:
    • Added menu option " OFF " for Reflection quality
    • Added menu option " OFF " for Shadow quality
PERFORMANCE:
  • Physics optimizations to improve situations with heavy physics calculations (ie. 32 player races)
  • Graphical Performance Optimizations
MULTIPLAYER:
  • NAT Type detection
    • Detect if user has a " strict " NAT and displays message for user
  • Voice chat is received even if your microphone is turned off
CONTROLS:
  • Keyboard / Mouse
    • Remapping restrictions removed
    • Allow Enter, Backspace, and Arrow keys to be remapped by user
    • Allow multiple mouse buttons to be mapped
  • Enable/Disable DirectInput in Menu
    • Users can now activate/deactivate Direct Input devices from "Controls" menu.
    • If commandline "-usedirectinput" is active, it will override pause menu setting.
  • Use 2 direct input devices simultaneously (ie. Wheel and Gamepad)
    • Users can now use 2 different controllers at once, including 1 XInput and 1 Direct Input device.
  • Added more Direct Input / XInput device support
    • Saitek P380/P480/P580/P990
    • Saitek PS1000/PS2700/P3200/P3600
    • Gravis Eliminator Shock gamepad
SECURITY:
  • Detect modified files and prevent users from entering multiplayer if found
    • Game will prompt with a message after blocking user with modified data files from entering multiplayer
    • Should prevent multiplayer access from cell phone and GFWL join in progress
VIDEO EDITOR:
  • Scroll Bar improved response
    • Tweaked to respond better to keyboard inputs
  • Sped up load times for users with many clips
TITLE UPDATE 2 FIXES:
  • Return of Hot Dog Stands and other props
    • Missing hot dog vendors, fences, gates, pylons should be present throughout the world.
  • Scrolling signboards
    • Activate missing scrolling signboard text (ie. highway signs, Star Junction, Clock Tower Sign)
  • ALT-TAB pauses game during cutscenes
    • Cutscenes should now pause and resume correctly after an ALT-TAB task switch. Audio remains in sync.
  • Mismatched MODO/Perseus Clothing
    • Fixed a bug when Niko mixes clothing from Perseus and Modo
  • 360 Controller Texture
    • Controller image should be visible in Controller Configuration screen
GTA IV Patch v1.0.3.0
Download Mirror
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
I like the sound of that physic/graphic optimisation :)
Edit: Does that new security fix block the mod that Skunk posted?
    ASUS Xonar DX
    100Mbps
First impressions are that the game runs a little smoother, again. Built-in benchmark shows a gain (in my case) of 3 fps (was 44, now I have 47fps in average). Not much, but always a little more. Don't know if the game refuses to launch with the mod to which Skunk pointed, because I'm not using it anymore. Just pure original GTA :p
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
sigh..... this patch ''has one again'' removed every mod ive installed....:mad:
& i cant understand how, ive removed the original files...??? it cant of replaced everything i modded, but it has & now i have to replace the lot...
i cant even remember which ones i was running now, i had so many......:(
i even tried a system restore in a last ditch attempt to save my old config, but upon the reboot GTA4 was still patched to 1.0.3.0.
yes Everlong, it will disable the graphics tweak....
its so bloody annoying, i just went to begin the file replacement fiasco ''again'' & gave up after 2 secs of looking at them....lol
IMO, keep the mods & forget the patches...... whatever rockstar can do, so can the modders....;)
god.....it plays like a bag of poo with no mods.....
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Meh, it looks crap without that depth of field that mod gave :(
It should be alright in single player though. I think it's only multiplayer it blocks modded files.
    ASUS Xonar DX
    100Mbps
I have a Vista DUAL-CORE processor, these are my other specs:
Memory: 2gb
Hard drive: 130gb
1.86ghz
DVD rom drive :rolleyes:
Graphics accelerator x3100
OS: Windows Vista home-premium
:sarc:Will I be able to easily run gta 4, or is my year long dream shattered?
Plz reply
Memory: 2gb
Hard drive: 130gb
1.86ghz
Plz reply
here are GTA4 requirements
Minimum System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
Memory: 1.5GB
16GB Free Hard Drive Space
Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
18 GB Free Hard Drive Space
Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
according to this your're qualified for the minimum ones. GTA4 is very dependant on the CPU. Probably you will have to decrease the details to lowest settings to run it smoothly.
    My Own Build
    ASUS P5E
    Corsair HX520W PSU
    Logitech MX1000
Memory: 2gb
Hard drive: 130gb
1.86ghz
Plz reply
im sorry to say, that dream of yours may well be shattered.....:(
my rig drops to about 20fps at some points on GTA4, & its ''leaps & bounds'' above yours my friend....
the game is very badly coded on the PC, hence the fact you need a GTX280 & a 4ghz OC to get a steady playable framerate.....this game is HIGHLY CPU dependent.
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
