Solved DVD reading error
Evidently Chappy here had the same problem with this optical drive-
see this post:http://www.vistax64.com/drivers/166235-tsstcorp-cd-dvdw-ts-653l.html
spin.
All hdd's have rpm. for example I use RAID O with two 320GB 7200rpm hard disks- the rpm's are the speed at which the platters spin. Optical drives do not have platters. Optical drives are listed as read/write speeds. for example, I have a 2x DL BD-RE @8xCD-RW/4xDVD-RW/2.4xDL DVD-R/2xBD-RE/1xDL BD-RE
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
spin.
All hdd have rpm. for exapmle I use RAID O with 2 320GB 7200rpm hard disks- the rpm are the speed at which the platters Optical drives do not have platters.
cool, well you learn something everyday, but the company I bought it from made it look like it was a optical drive. so i took the WD Raptor as optical drive (I thought) and the SpinPoint as storage.
so i need to install the optical device (SATA) manually, I suppose I uninstall it in device manager, but how do I reinstall it? do I have to find the location of the driver file?
    Intel Core# 2 Duo E8500
    Asus P5N-D
    Kingston HyperX 2048 x2
    EVGA GeForce GTX 280
    Creative X-Fi Titanium
    Samsung T220 SyncMaster 22"
    1680x1240
    WD Raptor 74 0ADFD 74gb Samsung SpinPoint F1 750gb
    Corsair 750w ATX/ESP
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
If your sata wd raptor spins @ 10,000rpm's it is not an optical drive, but an HDD.
Your samsung DVD-RW drive is also a sata drive, this is what you need to remove, and reinstall. You may need to have your sata/raid drivers handy so that windows new hardware wizard can install.
In device manager uninstall your samsung drive, then remove the drive physically from your computer, restart, then reinsert your optical drive and install sata driver through the wizard- In device manger you can locate your Storage Controller. For example, I have the VIA VT6421 sata/raid controller, So I would go to VIA and download the driver package for the VT6421, and extract the driver folder onto my thumb drive. To install it I would navigate the wizard to the folder, then to the Vista x64 folder (since I run 64-bit Windows), and then click the vt6421 driver.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
ok, so I have Microsoft iSCSI Initiator as Storage controller, the I go to Microsoft and download device package. It says in the PC raport of the producers that the TSST's full name is TSSTcorp CDDVDW SH-S223Q SCSI Device,that means that it has something to do with my storage cotroller, is there maybe something wrong with my storage controller?
Downloaded the package and tried to install it, but it could not find the update.inf so it couldn't update.
BTW. can't find my drivers folder.
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
ok, so I have Microsoft iSCSI Initiator as Storage controller, the I go to Microsoft and download device package, do I need to put it in a remote device? or can I just leave it on the PC? and is Raptor (C) or SpinPoint (D) my thumb drive?
NO. the Microsoft iSCSI Initiator is not your storage controller-look under that, it should display the controller (may be listed as RAID controller).
here is an image of mine- Which is a VIA controller:
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
See above- the microsoft initiator is not your raid/sata controller that you need to download/install
Download package for the RAID/SATA controller, extract the driver folder onto a thumb drive/floppy drive or folder on your computer. To install it navigate the wizard to the folder, then to the Vista x86 (32-bit) folder , then click the controller driver that matches what in listed under storage controller.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
NO. the Microsoft iCSI Initiator is not your storage controller-look under that, it should display the controller (may be listed as RAID controller).
theres only Microsoft iSCSI, and MagicISO those are the only one thats there.
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
Show me an image of your storage controller. Did you build this system, or buy OEM?
OEM driver disk will include your SATA/RAID controller drivers. It is the same controller used by your WD Raptor SATA HDD
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
here, strange you had to register to view it, I didn't even register to upload it.
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
Look in your included driver disk for RAID/SATA controller or driver package
Your controller appears to be Magic ISO raid SCSI Host Controller (I think as I cant read much of your device manager image as it is in another language)
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
where do I find that/those?
I can change my Language to English and then take a screen if you want
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
Try this, or see if you have something similiar on your driver disk:
MagicISO SCSI Host Controller 5.1.185
searched both of the drivers, but the closest was MagicISO
You do not have a SATA controller.
A SCSI controller coordinates between all of the other devices on the SCSI bus and the computer. Also called a host adapter, the controller can be a card that you plug into an available slot or it can be built into the motherboard. The SCSI BIOS is also on the controller. This is a small ROM or Flash memory chip that contains the software needed to access and control the devices on the bus.
SCSI has a processor integrated into the controller, and you need to install the scsi controller driver. Are you sure this driver is not on your backup driver disk? Anything listed with SCSI? I need to know what board you are using in order to locate the drivers. If we cannot find the driver, you may have to replace the controller board- this issue your having may be a result of a problem with this board also (corrupted driver or bad board, etc.)
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
SCSI has a processor integrated into the controller, and you need to install the scsi controller driver. Are you sure this driver is not on your backup driver disk? Anything listed with SCSI? I need to know what board you are using.
found much more when I changed language to English, in C: drive i found for example ScsInstaller.exe in, found in total 140 items when I searched for SCSI
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
I still have 2 years free service from the company that created my system, should I just send it in and let them fix it?
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
No. I do not think it is necesssary...yet. Call them and tell them your issue with the scsi optical not reading disks, and ask them for assistance in reinstalling driver. They can tell you were it is (if you have a backup/driver disk), or what scsi driver you need and /or where you can download it. This will resolve your issues fast, and if it is later determined your board/optical drive is bad I suggest you send it in for repair/replacement.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
ok, willdo and thanks for all the help!
    Asus P5N-D
    1680x1240
    Antec 1200
    NorthQ Watercooling
    Logitech G9
    Logitech G15
    8mb down, 8mb up
