Chkdsk will Not Run at Startup in Vista
How to Fix Chkdsk will Not Run at Startup in Vista
If after you set Check Disk or chkdsk to run at startup it will not run, then this will show you how to fix this problem so chkdsk will run at startup. This problem is usually caused when the autochk.exe file gets corrupted, or the registry BootExecute data value is incorrect.
This is not for if chkdsk cannot finish or stops running.
  • Check Disk uses the file autochk.exe to run chkdsk.
  • If you still cannot run chkdsk at startup after this, then you might consider performing a System Restore, Repair Installation, or Clean Installation to fix the problem. See related links below.
  • If you had changed your default boot screen, then you will need to temporarily uncheck the No GUI boot to be able to see what is happening when chkdsk is running at boot up. See: How to Enable or Replace the Hidden Aurora Boot Screen in Vista
STEP ONE
Safe Mode Workaround
This is to see if something may be loading before the check disk program preventing chkdsk from running.
1. Schedule check disk to run using chkdsk /f (STEP FIVE below) in the command promt.​
2. Run msconfig (step 1 in METHOD TWO at link), and click on the Boot
tab and click on Safe boot with the minimal button selected. (See screenshot below)​
3. Restart the computer to hopefully have chkdsk run.​
4. Set msconfig (step 2 in METHOD TWO at link) to boot normally again.​
5. If chkdsk still will not run at startup, then proceed with the steps below. If it did, then you're done.​
STEP TWO
Reset chkdsk BootExecute
  • This will reset chkdsk back to it's default setting of not to run at startup.
  • This step will also fix the problem of chkdsk always running at startup.
  • If BootExecute already has a Data value of autocheck autochk *, then you do not need to do this. (See the Manual Way below to check) Continue to STEP THREE below instead.
Through a Download:
1. Click on the download button below to download the Reset_chkdsk.reg file.​
download
2. Click on Save, and save the .reg file to the Desktop.​
3. Right click on the .reg file (on Desktop) and click on Merge.​
4. Click on the Run button for Security Warning pop-up.​
5. Click on Continue (UAC), Yes, and then OK when prompted.​
6. When done, you can delete the .reg file (on Desktop).​
The Manual Way:
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
5. In the right pane, right click on BootExecute and click on Modify.​
6. Type autocheck autochk * and click on OK. (See screenshot below)​
NOTE: You will be replacing autocheck autochk /p \??\C: with autocheck autochk* instead. If BootExecute already has a Data value of autocheck autochk *, then you do not need to do this. Go to STEP THREE below.​
7. Close regedit.​
STEP THREE
Run a SFC /SCANNOW Command
1. Try running a sfc /scannow command to see if it can fix chkdsk.​
2. When SFC is finished, try running chkdsk again.​
3. If chkdsk still will not run at startup, then proceed with the steps below. If it did, then you're done.​
STEP FOUR
Replace autochk.exe File
NOTE: This will show you how to replace your corrupted copy of the autochk.exe file with clean copy to be able to run chkdsk at startup.
1. Be sure that you already have ran a SFC /scannow from STEP THREE above to see verify that the autochk.exe file was foud to be corrupted first in the sfcdetails.txt file. If it's not, then you do not need to do STEP FOUR.​
2. In Windows Explorer, go to C:\Windows\System32\autochk.exe. (See screenshot below)​
3. Take ownership of the file autochk.exe at the C:\Windows\System32\autochk.exe location, and "Allow" your user account "Full Control" of it. (See screenshot above)​
4. Right click on autochk.exe and click on Properties. (See screenshot below step 2)​
5. Click on the Details tab. (See screenshots below)​
A) Make note of what File version the autochk.exe file is.​
NOTE: If the File version is blank or you have SP1 installed, then do step 6. If not, then do step 8.​
6. Download the same version that you have in step 5.​
7. For the Vista 6.0.6002.18005 SP2 Version of autochk.exe
NOTE: This is for the 32 bit and 64 bit Vista with SP1 and SP2 installed.​
A) Click on the download button below to download the 6.0.6002.18005.zip file.​
B) Go to step 10.​
download
8. For the Vista 6.0.6001.18000 SP1 Version of autochk.exe
NOTE: This is for the 32 bit and 64 bit Vista with SP1 installed.​
A) Click on the download button below to download the 6.0.6001.18000.zip file.​
B) Go to step 10.​
download
9. For the Vista 6.0.6000.16386 RTM Version of autochk.exe
NOTE: This is for the 32 bit and 64 bit Vista without SP1 or SP2 installed. This version has been reported to still work with or without SP1 installed, so you may try it if you still have problems with the newer 6.0.6001.18000 SP1 or 6.0.6002.18005 SP2 version.​
A) Click on the download button below to download the 6.0.6000.16386.zip file.​
download
10. Save the ZIP file to your desktop.​
11. Open on the downloaded autochk.exe.zip file.​
12. Extract (drag and drop) the autochk.exe file from wihtin the ZIP file to your desktop.​
13. Right click on the autochk.exe file on your desktop and click on Properties and the Unblock button under the General tab. (See screenshot below)​
NOTE: If you do not have the Unblock button, then it is already unblocked. Continue on to step 14.​
14. Right click on the autochk.exe file on your desktop and click on Copy.​
15. Go back to the Windows Explore window at C:\Windows\System32\autochk.exe. (See screenshot below step 2)​
16. Right click on a empty space in the Windows Explorer window and click on Paste. (See screenshot below step 2)​
NOTE: If it will not let you Copy or Paste the new autochk.exe file (on desktop) over, then rename the old one and repeat step 14, then delete the old renamed autochk.exe file afterwards.​
17. Click on Copy and Replace. (See screenshot below)​
NOTE: This replaces your autochk.exe with the downloaded clean one on the desktop that has not been taken ownership of.​
18. Click on Continue for Access Denied prompt.​
19. Click on Continue for UAC prompt.​
20. Close the Windows Explorer window.​
STEP FIVE
Set Chkdsk to Run at Startup
1. Try the different methods in this tutorial below to run chkdsk to see which one works best for you.​
There are several folders inside Windows that require "elevation" in order to copy and replace files within them. It is a security feature that protects specific operating system files. Yes, even though you are using an administrator account, you still have to elevate your access rights, as detailed in the steps Shawn mentioned.
As I noted, the shortcut to do that, which you can download, did not work for me. I had to manually elevate my rights.
1) you mean i still have to do that even though i'm using the administrator account?
2) i must add the registry listed here? http://www.vistax64.com/tutorials/112795-context-menu-take-ownership.html
3) will downloading this registry change/affect/cause problems to my computer in any way?
4)...what does taking ownership do anyway ._.
Yes, you will still need to "allow" your account "full control" of the file as well. Taking Ownership by itself just makes your account the owner of the file to be able make changes to the permission levels, but still doesn't give you the permission levels above that are needed to modify the file itself.
Hi Lorri,
If you mean the Take Ownership item, then yes you sure can if you want to. :)
You would just need to download and run the REG file in step 2 of the STEP ONE section at that link. That's all. :)
i'm sorry if this question does not belong in this post...but...
i have a vista home premium with a 138GB HD (82GB full, 56GB free) on an HP pavillion computer. my computer is about 2-3years old
if i run chkdsk at startup, approx how long will it take?
Hello Lorri,
It really depends on if it finds any disk corruption, and how bad if found. I would give it around 12 minutes or so to run. Longer if problems are found.
if there are problems, would it take hours?
when i ran chkdsk (using my mum's computer) on my external HD, it took 3hrs. would i expect that long? (it's a ranger and it has about 50GB of used space, 100GB of free space)
On a slower system and/or a large hard drive, it could take longer yes. To be safe, I would do it when you have a few hours to spare so you are not rushed if it does take much longer.
No.
You're welcome Aftermath. :)
would i expect it to take 12hours+? (just like defragmentation, for some reason...)
That can happen if you also use the /r switch
when you run chkdsk. In that case not only does
it repair the file system, but it checks every sector
on the partition. That thing could be running for
days on these TB sized drives!! If your drive is
bad enough you have to check every sector
you might as well spend the time getting the
data off and buying a new drive.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Lorri,
When chkdsk is ran in the command prompt with the /r switch, it tells it to attempt to recover any bad sectors of the hard drive if any are found. The most common comand to use is chkdsk C: /f to run check disk on the C: drive.
It will run the same speed using either option at boot. The only time that it will run faster than the last time is if you had a bad sector that it fixed last time, and you did not have one the next time. It pretty much runs close to the same amount of time each time you run it. About the only variance is if it finds any bad sectors to fix.
I say just give it a run and see one day when you are not busy so that you are in no rush for it to finish. :)
