How to Turn the Preview Pane On or Off in Vista
The Preview pane allows you to see a preview of the highlighted image, video, or document file in the opened Windows Explorer window without having to open it. This will show you how to turn the Preview pane on or off.The Preview Pane can only be turned on or off for windows with the same folder template at each location. For example, the Music Details, Music Icons, Pictures and Videos, All Items, Contacts, and Documents templates.
EXAMPLE: Windows Explorer Preview Pane
Set Folder Options
1. Open Folder Options.
2. Click on the General tab. (See screenshot below)
NOTE: Having Use Windows classic folders dotted instead will remove the preview pane in the Windows Explorer window...
