How to Turn System Restore On or Off in Vista
This will show you how to turn System Restore on or off in Vista.System Restore helps you restore your computer's to an earlier point in time. It affects Windows system files, programs, and registry settings. It can also make changes to scripts, batch files, and other types of executable files on your computer. It is a way to undo system changes to your computer that you did not like the results of without affecting your personal user folder files, such as e‑mail, documents, or photos.
Sometimes, the installation of a program or a driver can cause an unexpected change to your computer or cause Windows to behave unpredictably. Usually, uninstalling the program or driver corrects the...
