How to Save and Print a Directory List for a File and Folder in Vista
This will show you how to easily create a file and folder directory list that you can print and save to disk as a file. You can include the name of every file on a drive, along with the file's size, date and time of last modification, and attributes (Read-Only, Hidden, System and Archive). The list of files can be sorted by name, size, date created, date last modified, or date of last access.This way you do not want to mess with the DIR command codes.I would recommend that you try the Save to Disk option first to adjust your settings and see how it looks in the text file. This way you will see how it will print before wasting any ink and paper in the Print option...
