Gomjaba what ram do you have? Wonder why it would score so low?
5.3 here ... all 5.9 except Ram
(but I knew its slow when I bought it)
That may just be the timing on the ram. I had that problem until i changed the timing on the ram.
Any suggestions ? I never touched any setting from my bios
Edit: I am home at the moment, so I don't really know what settings I am using at the moment. But its probably set to "auto".
This is all I was able to find :
Are the settings obvious in the bios ?
Strange I get a 5.9 on my 4x2GB and I am running 5-5-5-15
The Memory measurement in WEI isn't just the speed of your RAM - It's checking the throughput of the entire subsystem. So Front Side Buss speeds are just as important, if not moreso, than the speed/timings of your DIMMS. So if you overclocked your comp some by raising FSB speeds, your memory score will also rise.
