Isn't there a hotfix for SLI'd Graphics Accelerators?
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
was wondering if anyone can help me. I have 4gb ocz pc2-8500 memory running at 1066mhz on Vista Ultimate 64 bit. on the Window Experience Index Scores i get 5.9 for everything else but memory is at 5.4. i have looked at some posts on here and people are using 2gb and getting 5.9! how is this possible?
can i rectify this? just find it odd.
    Q6600 2.4ghz
    Asus P5E
    4GB (2x2GB) OCZ PC2-8500 1066mhz
    Gainward Geforce 9800GTX 512mb
    1x 500 SATA Seagate Barracuda 32mb cache
Are you using 2 x @GB modules or 4 x 1 GB Modules? And how are your timings?
When I boosted my RAM up to 1000 MHz I hit 5.9 immediately on the first refresh of my WEI.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
im using 2x2gb ocz pc2-8500 1066mhz ram. i mean i can play crysis for breakfast with a pretty good FPS rate but WEI not budging from 5.4. my timings are 5-5-5-18 (as recommended by ocz) i havent overclocked memory or system and i dont think i need to!
CPU: Core 2 Quad 6600 G0 CPU @2.40 GHz
Heatsink: Thermalright Ultima-90
Motherboard: Asus P5E
PSU: Corsair TX 650W
Graphics Card: Gainward 9800GTX 512MB
RAM: 2 X 2GB OCZ PC2-8500 ReaperX @ 533 MHz (1066 MHz Dual)
HDs: Seagate 500 GB 7200.10 RPM 32MB Cache
Case: XClio A380Plus (yes the one with the 360mm fan)
Monitor: 22" Samsung 226BW
    Q6600 2.4ghz
    Asus P5E
Hi Chillax,
I have 2x2 GB Patriot PC2-8500 1066MHz Dual Channel RAM like you with no overclocking, but my timing is set as the default 5-5-5-15 instead. It hits 5.9 in WEI.
Make sure that they are place in the RAM slots correctly to. Most dual channel memory will need to be place in a certain order for the best performance, usually the same colored slots. You might also try 15 instead of 18 to see how it runs.
The OCZ defaults to 5-5-5-18 or the faster (OC) timings of 4-4-4-12.
Which ram exactly are you using, perchance the Reaper HTC or the gold / silver?
Also, you might want to check the actual speed your RAM is running at - CPU-Z will tell ya for sure....
My ReaperX DDR2 C8000 RAM shows in CPU-Z as PC2-6400 RAM, but I pushed it to 1000 (not an Overclock, an even clock as that its what it was rated) and I went from 5.4 or 5.3 to 5.9 - no OC at all. But, as I said, I had to set the mobo to run at that speed because the CPU-Z is recognizing the RAM at PC2-6400 not PC2-8000
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I am more than happy with mine!
    Intel Q6600
    Asus P5B Deluxe Wifi App
    XFX Geforce 8800 GT Alfa Dog
    500GB Sata
John,
I have this memory OCZ DDR2 PC2-8500 Reaper HPC 4GB Edition
OCZ Technology | Products | Memory | OCZ DDR2 PC2-8500 Reaper HPC 4GB Edition
i asked at the OCZ support about this issue and they assured me
'the memory will say its PC6400 as thats the top Jedec table at this time'
also cpuz is telling me its running at 533 x 2 so guess thats good enough. OCZ did say that WEI is crap for performance comparison lol
    Q6600 2.4ghz
    Asus P5E
John,
Right, it is an OK measurement, nothing you really want to base a purchase on, lol. If CPU-Z says it is running at 533MHz, then it is 533MHz. :) Yeah, if you read a few pages back, it doesn't only measure memory, but the FSB, also for the memory test. Looking at yours, it seems to be stock. That is more than enough, but Vista doesn't think so, incorrectly.
~Ibrahim~
    Overdrive PC
    E6600 @ 3.5GHz
    P5N-E SLI
    4GB DDR2
    8800GTS 640MB
    Onboard Realtek ALC883
    Dell SP2008WFP
    WD 640GB (50GB OS/100GB Programs/490GB TV Recordings) Seagate 320GB
    Enermax 620W
    Cooler Master Stacker 830
    6x120mm
    Razer Copperhead
    Gateway OEM
    6Mbps/512kbps
chillax - did you put the memory in the correct slots to enable Dual Channel use?
I have the other HPC model - OCZ Technology | Products | Memory | OCZ PC2-8000 ReaperX HPC 4GB Edition - and my memory would run synced with my CPU, meaning that it was running a very very low speeds and Vista let me know that - with a 5.4 score. I had to 'over clock' the memory - which really means I had to unlink the memory from my CPU so it would run at its full potential, but it still only went to 800, whereas it is rated for 1000, so I nudged it a bit to get my 1000 speed, but even after around 850 MHz my Vista was showing me a 5.9 score, and CPU-Z was showing 425 (Dual Channel takes it to the BIOS reporting 850) - so if CPU-Z is showing 533 for your RAM, then I have a sneaking suspicion that you're *not* in Dual Channel mode....
Oh, and BTW - those 32MB Cache HDs that I got 2 of (and that you have 1 of)? TigerDirect has them on sale - $80 a pop.....
Buying 2 more tomorrow :P
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
well thats me.
    AMD phenom 9600
    ASUS M3N72-D
    Corsiair 3gb 5500
    GeForce 9800 gt ultimate
    samsung HD tv
    1440 x 990
    Western digital 300gb
    G5 logitech
Hello y'all!
I can't begin to explain what a difference this has made; I just wish I had done it sooner!
WWWEEEIII A 9600GT out through an HDMI to my 47" AMAZING... :party:
Later :cool: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
I got a 5.9 on everything but my ram it's 5.5
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
Is the ram actually running at 1000 MHz? I forced the BIOS to run mine at that speed, with the default OCZ timings and all is well....it bumped from a ~5.3 to 5.9 straight out.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I have tried without any success to display my image on the post.
I think that there is a link to my image somewhere on here.
Anyway, I built the puta last week and I get a score of 5.7
Image fixed by: Brink
NOTE: You just needed to click on the Paperclip icon again to select the uploaded image to be displayed in the post. ;)
    Intel Core2 Duo E8400
    Gigabyte GA-EP35-DS3P
    Corsair TWIN2X4096-6400C5 4GB (4x2GB) 5-5-5-18
    EVGA GeForce 8800GT 600MHz
    Western Digital Caviar 640GB WD6400AAKS X 2
No it's running @ 816
    RJ's Toyz/HOTROD
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
then fix that to get a better RAM WEI score.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
It don't bug me that much, I know the WEI score don't mean dick anyway :eek:
This score means more to me...
    RJ's Toyz/HOTROD
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
You can probably break 17K with the RAM running at the speed it is rated for....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
    RJ's Toyz/HOTROD
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
