Whats your internet speed?
I'm confused. First, OrangeAngel's time zone indicates Eastern USA - so why does everyone think it's the UK?
Second, Carmine - WHAT is supposed to be 35 up /35 down? If you mean transfer rates, I've honestly never seen upload and download speeds be the same for anyone (download is always quite a bit faster than upload). And how would you know what it's supposed to be since OrangeAngel didn't mention an ISP (and there's even some doubt about the country as well)? Where did you get that speedtest report? Is that supposed to be OrangeAngel's? If so, did it not post so you added it (and how did you see it when we couldn't - and it's not 35/35 anyway)? If not, how does it relate to OrangeAngel's speed problems?
OrangeAngel,
Where do you live (at least country)? What ISP are you using? What type of connection do you have (dial-up, DSL, satellite,...)? Are you directly connected to the ISP device or through a router or wireless device or through ICS with another computer? Has it always been like this or did this just start happening? It would also help if you completed the System specs section of your user profile as ilikefree requested.
Try doing the procedures in the following to see if they either help or can help us identify whatever might be the problem (I mean, even a dial-up connection is faster than that): http://www.vistax64.com/network-sharing/284688-network-posting-tips.html#post1297090.
To see if this is caused by some type of add-on to your browser (I assume it's IE, if not, use the appropriate method for whichever one you are using), try running the browser without add-ons to see if that helps - if so, follow the instructions to find the add-on causing the problem:
http://blogs.msdn.com/ie/archive/2006/07/25/678113.aspx.
To see if this is caused by your security software, temporarily deactivate it while logged in ONLY to the speed test site (close all other windows and tabs and close you e-mail program) and run the speed test to see if it makes a difference. Reactivate the security software as soon as the test is complete and then update and run a full scan with your security software and Malwarebytes [URL]http://www.malwarebytes.org/mbam.php[/URL]just to be on the safe side. If it made a big difference, change or reconfigure your security software.
Boot into safe mode with networking and check your speeds there (same rules as above). If it's much faster, try a clean boot http://support.microsoft.com/kb/929135. If the problem goes away then it's just a matter of tracking down the culprit causing the problem. Follow the procedures in the article. Once found, delete, remove, deactivate, or uninstall it. Once done be sure to reset Vista back to normal status as explained in the procedures. If the problem occurs in clean mode then just restore the system to normal status and reboot - this solution is not going to work. Once again, when done, please again run a full scan with your security software and Malwarebytes just to be safe.
I hope this helps or the information you provide helps us to help you.
Good luck!
I presumed he was from the UK, as he is using Orange as his ISP. They are a company in the UK. Also the timezone is set as Eastern USA by default and you have to alter it.
    Dell XPS 720
    Itel Core (TM)2 Extreme CPU Q6800 @ 2.93GHz
    2 TB
    NVIDIA GeForce 9900 GTX
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    3 x 1 TB DEL Hard drives.
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
I'm sorry, I must have missed that (and I did look through other posts by OrangeAngel). I've looked again and still can't find it - I must be having some type of bizarre problem. Where does it say Orange is the ISP? I'm also interested in anything else about the situation I potentially missed as well.
Thanks, LanceIot!
    1920 x 1200 pixels
OrangeAngel,
Good luck!
I don't know where I got that! I think I must have been looking at the name and presumed the ISP was Orange. It's an age thing you know Lorien. :confused:
    Dell XPS 720
    2 TB
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Is this good at all? I have an 11.0mbps speed.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
Oh for Fibre Optic!!
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hey tom982,
I'd love that upload speed!
I did hear that maybe some restrictions were put into place locally 0.3 Mb/s for upload? Mmm!
‘I do not seek to follow in the footsteps
of the men of old,
I seek the things they sought‘
Basho (1644-1694) Japanese Haiku
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
I dont think I've posted one of mine since I moved, so here it is.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Just a tip guys, rather than taking screenshots of the test results you can just click on the Copy Direct Link on the speedtest results page and then click on the
symbol to inset the picture's url into your post.
Tom
If you click the "copy forum link" button you can just paste that straight into the post and it will auto insert the image etc.
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Tom
Even better :)
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Looking good.
Mine varies a bit on the upload from 12 to 20.
YES!
We have had a speed upgrade! We used to get a download speed about about 10-20kb/s. After moaning a lot to BT, they apologised and promised to upgrade us. One month. Two months. Six months. We started moaning again. Now, eight months on, they have produced the goods! Admittedly, we live in the middle of nowhere. GPRS is even slower.
I can now even run Speedtest properly! New download speed of 70kb/s!
I didn't see any works or anything, they didn't replace anything near our house, but our speed is better! Look at this! I am absolutely ecstatic!
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I'm getting me an N router. Screw B, and G.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
I better shut up
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
how do you speed up a ping :roflmao:
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
You don't need speeding up! It is about the only thing my new line does reasonably well!
What I don't understand is how you can have a very slow line but a very fast ping and vice versa for pacinitaly? Unless one of your connections is wired and the others is wireless?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
My internet speed
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
