updated laptop hdd problems?
it was 4 at a time. did not think that was to many but ill try to bear that in mind in future.
however windowes update states they all installed sucsessfully?
also do you think that could be my problem then to do with updates?
forgot to mention it froze after check dsk had completed also so three frezes in last 24 hrs 2 after windows updates restarts. 1 after ch dsk restarts
    acer aspire revo
    intel atom 230
    2gb
    integrated nvidia ion
    lenovo n5901
    lenovo n5901
If you only did four at a time, that should not be the problem. Dont know about chkdsk as you passed all tests.
its only been happening sinc that first batch of updates last night should i try uninstalling them or something?
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
What you may have to do is perform a system restore to uninstall them and then just put in 2 at a time, so you can find the cause and then dont install that one.
ok but whenever i seem to do a system restore it fails but i can try. and when i find the one thats doing it restore again to before that one and carry on is that right?
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
You are having a few too many little problems, lets go with that SFC again, if you can.
so dont try the restore point first to undo the updates. or do i try that first then sfc. or sfc first
by the way just thought id mention this is my dads laptop noot my desktop.
the laptop has only had these issues since last night.
none before
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Lets try the SFC, it tells us about any Vista corruption and tries to fix.
how long will process take? roughly
i only ask as its gone 3:00am where i am if its going to take a long time i may have to call it a day and pick up from this point tommorrow if you dont mind helping me again?
also on the sfc thing do i need to follow all steps or just a particular one? or all in sequence like a.b.c.d.e. in that order?
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
It takes about 15 minutes and its easy to do. Very few easy steps.
ok i will give it ago now
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
rich where i am using 2 computers i just made the mistake of running the comand thing on my pc not my laptop.? will that be ok it said it found something and needs to be restarted to finish do i have to go thru with it now? on this machine before i go through with it on the laptop ?
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
If it found something, its good to know what it is, so finish up
but thats working at the mo its the one im using to talk when laptop is being fixed ?
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Its late there anyway, might be a good time to get some sleep.
shall i continue with that one before running sfc on the laptop it says it may take a while (as im already making mistakes due to lack of sleep would it be better to continue tomorrow) fresh
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
ok i was just saying that (thanks)
erm as the first part A) has been run on the desktop when i shutdown in a min will it not try to continue? finish the fix sfc was trying
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
Let is just run. Brush your teeth and do anything else you normally do and it will be finished.
ok thanks ill do that gets some sleep and continue tommorrow thanks rich you have been a massive help as always could not do it with out you spk to you tommorrow :)
    acer aspire revo
    intel atom 230
    2gb
    lenovo n5901
    lenovo n5901
