Solved Switch AHCI TO IDE (Tutorial HowTo) !!!
Wow i am truly amazed how many people found this so helpful , and this tutorial was up at some blogs , and at microsoft help/awnser website , i just cannot believe it :P:P , and 3 years passed since ive been here , anyway i will try to find that reg key that i made back then and i hope that i will find it
    Gateway FX series 7809U
    Intel Core 2 Duo P8700 Fsb 1066
    4gb ddr3 Fsb 1066
    NVIDIA 9800GTX 1024 mb ddr 3 256 bit
    Conexant Hermosa HD Audio
    Laptop Lcd panel
    1440x900 17" laptop panel
    1x SSD Kingsone hyperX 120 GB
    9 Cell battery with 7800 MAH
    100 mbit/sec (megabit)
    4gb ddr3 Fsb 1066
    Laptop Lcd panel
Thank you for this. I was at my wits end and found your tutorial. Thank you works like a charm. Very impressed with your skill.
    Inspiron/ N5010
    M350 2.27 GHz
Post #44 above...?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
It worked for Windows 8 also! After using your registry commands there was still no msahci, but iastor and iastorAV appeared and I could change theirs values. Now Windows 8 finally loaded.
I don't know what happens, but by night harddrive stopped being detected in AHCI mode. I've only uninstalled Linux and changed other disks partition table from GPT to MBR. After this the HDD with my OS started being not detectable by bios and whole PC hangs in POST.
    4gb ddr3 Fsb 1066
    Laptop Lcd panel
I want to go the other way and switch to AHCI as I'm told my SSD will be faster that way
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Thank you Thank you Thank you!!!!! I didn't have HKEY_LOCAL_MACHINE_System_CurrentControlSet_Services_iaStor even after using his download but it still worked. It works in Windows 7!
AWESOME! :party: You're an absolute life saver. You saved me a tremendous amount of time from having to reinstall my OS and all my applications. Amazing that I checked with Microsoft and many other so called Microsoft Consultants and they all said - it couldn't be done! I am glad someone out there had the tenacity and intellect to figure this one out. Thanks so much!!!
