Solved Switch AHCI TO IDE (Tutorial HowTo) !!!
Wierd , no one posted something like : Good job or something :-? maybe no 1 needs this :-?? i dont know ...
I certainly did Roli, thanks very much. ;-)
I had swapped from IDE to AHCI thinking it would work miracles, well it didn't and things are actually faster back in IDE mode.
Thanks again.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
I'd like to try your solution to my problem of a disappearing SATA drive (LG Blu-ray BH12LS38).
The motherboard is ASUS M3N78-VM. Operating system is Windows 7 Home edition.
My trouble is that when I try to reset the BIOS, there are only three choices given: SATA, AHCI, and Raid. "IDE" is not one of them. The BIOS is currently set to SATA.
Might I get the Blu-ray drive up and running by installing a SATA card in an unused PCI slot?
Many thanks!
    no-name
    AMD
    ASUS M3N78-VM
    2 gigabyte
    NVidia
    Nvidia
    Samsung
Many thanks!
SATA is IDE on your board. Not sure about your idea for attaching a Blu-ray drive as those would normally attach to a SATA socket elsewhere on the motherboard.
What optical drive do you have now? Do what I did and simply swap your existing optical drive for Blu-ray because it is backwards-compatible and will handle 'lesser' disks. You can also get them with Lightscribe if you use that.
I see that there are such things as SATA plug-in PCI cards for plugging in external optical drives: http://www.tigerdirect.ca/applications/category/category_slc.asp?CatId=1455
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Very Good Solution, i try it and everything works great. thks
    acer aspire
    acer
    asus
    4 gb
    nvidia
    none
    acer
I've problem, I hope you will help me. Changing the values from 1 to 0 i could not find the folder "IASTOR". I just found the folder "iastorV" but not the "iastor".
How can it be? Please anyone help me! It's important
I Have the same problem as you. I tried to boot in IDE without changing "iastor" but i got BSOD. I cant find which register file he put to download
    AMD A8-3870K
    MSI A75MA-G55
    Samsung 30nm 4GBx2, 1600MHz
    Sapphire HD6670 LP DDR5
    Realtek ALC887
    Samsung Syncmaster 732N+
In my registry my iaStorv and Msahci are marked 4 at start. Why is that would you know? If I change them my computer wont startup.
    Samsung NP-R519-FA03UK
    Intel Pentium Dual Core T3400
    R519/R719
    DDR2 PC2-6400S
    Mobile Intel 4 series Express chipset family
    Hitachi
Just register to say thank you very much, really good work. I have same problem with the other that cant find "iaStor" in registri, I just skip this but this is still work for me, maybe not for all pc system. One again thank you for the tutorials. :)
    i3 540 -_-
    JW H55M -_-
    2X2 GSKILL 1333 :)
    GEFORCE GTX 480 :)
    REALTEK -_-
    LG 22" :|
Thanks
    dell
    intel
    intel
    nvidia
    nvidia
    nvidia
    samsung
