Solved Start Menu and Taskbar disappeared!!!!!
Do you know how to do that; go back to factory?
If nothing works the only choices that I see are
Wait until someone from security helps and works on the potential virus
Try System Restore again.
Go back to factory specifications
Go back to last known good configuration
if you have a Vista install DVD a repair install.
Its your choice.
You dont want to try some of those solutions?
I can help if you dont know how
Thats great, can you do a system restore from a few days before the problem?
I would like that. I will be happy to accept your friend request.
thanks again for all your help last night i installed 7 and its running fine now and i install antivirus and the other programs u suggested and every thing is fine thanks once again
Glad that it all worked out; one way or another.
