Solved Start Menu and Taskbar disappeared!!!!!
i have tried to fix this problem my self because i have gotton a lot better at computers since the last time i was here but i just cant get it this time i put malwarebytes on the computer to take the infected file off and when i restarted it my start menu and task bar was gone but i cant get it to stay and when i try to download a cleaner it just freezes
oh yeah and the taskbar didnt disappear tell after i installed malwarebytes i restored the computer to a few days ago and every thing came back and i installed malwarebytes again because i didnt know it was malwarebytes that messed it up and i have been trying to restore it agian and have not been able to get back to the restore area
You have to go back past the first time you had the problem. Try going back at least 3 or 4 days prior to that date.
i have done that and that when my taskbar disappeared i was trying to fix the computer because it was already so messed up malwarbytes wont run now
You have to run malwarebytes full scan. Did you do that? It should take at least 30 minutes.
Also run the full anti virus scan.
Dont forget to try all the steps in both my posts.
sorry it was a quick scan just started the full scan and have not tired the sfc command yet or the repair install will try those when malware is done
After malware do the anti virus scan.
Wow, now Im pretty sure you have a virus.
http://www.microsoft.com/security_essentials/
Make sure your update this first before you use it.
After we are done, I am going to give you a list of things to do to take care of your computer, so you will not have these problems again. In fact I will give it to you now
To maintain your computer
10 Tips on How to Properly Maintain Your Computer for Vista too
Steps that I did not notice on the guide include:
Running a scan disc before doing a defrag
Using Microsoft Security Essentials and Malwarebytes.
Making System Restore points, at least once a week
Makaing a system Image once a month (varies by user)
Not relying on your A/V common sense, should prevail. You know of many sites can cause a problem.
Do not use any reg cleaning or optimizing software.
Download and use Ccleaner. about once every two months
http://www.piriform.com/
If you follow these instructions, you will be trouble free for a long time to come.
Be sure to back up your hard drive about once a month (varies by user) and to keeep system restore points up to date.
Optimize Windows 7
its not my computer im fixing it for some one but it has turned out to be more trouble then what i thought it would be but i have put ccleaner on it and i will make sure he get the info when he gets the computer back after i get it all fixed and thank u for ur help so far
Its about 10 at night. I will stay with you as long as I can. I want to get this fixed for you. I want it to be your Christmas Present.
