Go into safe mode and delete those folders, then reboot.![]()
You mean delete them from the Program Data folder? I just ran Advanced Disc Cleaner and at the end of the scan there was a list of files . I selected all and deleted all but 10, which ADC said were beiing used by another program. the name of the file was:
mcssubdb.bak C:/Program Data/McAfee?mcs/cache
While looking in the Program data folder there were also folder of the following programs that I've uninstalled in addition to the McAfee: Norton, NortonInstaller, PC Doctor (have no idea where that one came from), and PKWARE. Are all of these safe to delete?
Also what's the purpose of using safe mode? Will safe mode not allow me to delete a necessary file?
- HPs3700y Slimline
- AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
- Asus M2N61-AR
- 3 GB
- NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
- High Definition 6-channel audio ALC 888S chipset
- SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
- 1280 X 1024
- 320GB SATA 3G (3.0 Gb/sec)
- PSU
- 160W
- Logitech Marble Mouse
- HP
- Broadband Cable Connection (256 Kpbs?)
- Other Info
- Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
