Rogue.Fake.MSE & Don't.Steal.Our.Software
Fred, if you don't mind, I would prefer to contact you through the thread system, this way others can benefit from the solutions :) How many files have been downloaded? If you want to be sure, you could upload them to:
VirusTotal - Free Online Virus and Malware Scan
And this will scan the file against a range of anti virus detection files. This is a bit OTT, but if there is only a few and you want to be sure, then do it.
I doubt that this is the problem however.
From your log file, I see that you are running MBAM 1.45, have you tried updating to 1.46 to see if this works?
Malwarebytes' Anti-Malware Free Download and Reviews - Fileforum
I just followed your link and downloaded MBAM 1.46 and updated to 4180. I'm running a full scan now. Let me know if you think a quick scan is sufficient to detect this issue. Thanks for all the assistance!
Fred
    HPs3700y Slimline
    AMD Athlon64 X2 (B) 50000+ 2.6 GHz (65W)
    Asus M2N61-AR
    3 GB
    NVDIA GeForce 6150SE nForce 430 (Integrated on motherboard)
    High Definition 6-channel audio ALC 888S chipset
    SAMSUNG SYNCMASTER 914V FLAT PANEL LCD
    1280 X 1024
    320GB SATA 3G (3.0 Gb/sec)
    160W
    Logitech Marble Mouse
    HP
    Broadband Cable Connection (256 Kpbs?)
    Not sure what case or cooling means. Could not find in any documentation. The keyboard is the standard that comes with the HP Slimline.
Rogue.FakeMSE was reported as a false positive a little while ago, and should have been fixed already. Please update to 1.46 and the latest databases, and it should be fixed.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I downloaded v.1.46 and then updated as soon as it was installed. It said I had 4180 now. Is there a separate action for updating the latest databases or does the "update" function take care of that? I'm running a full scan with the new version right now. (Do I need to do the full or would a quick scan suffice?) Thanks for the help.
Fred
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Downloading a new version updates the 1.45 to 1.46 (you have done this already) and clicking Update updates the database (you have also already done this) It depends how much time you have, full would be ideal, but you may not be able to do that at the moment.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I running a full scan at the moment...about 30 minutes into it and it's found 1 object infected so far. I'll have to wait till the scan is over to find out. It coould be the Don't.Steal.Our.Software thing. I have MSE set to run a daily scan (quick) and it did not detect anything this morning. I also did a full scan with a-squared earlier and it found nothing. Could this just be a MBAM glitch? The computer is running fine...no problems.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Yes, it could be a glitch, but I don't know until I see that log.
No worries, just post the log whenever you can :)
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Yeah, the new version did not detect the Rogue.Fake.MSE. The Don't.Steal.Our.Software entry did come up, but as I understand it, that's something MBAM did to establish the fact that their database was being stolen. Isn't that correct? Here's the log. Looks clean except for the Don't Steal thing. Thanks so much!
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Database version: 4180
Windows 6.0.6002 Service Pack 2
Internet Explorer 7.0.6002.18005
6/8/2010 2:51:51 PM
mbam-log-2010-06-08 (14-51-51).txt
Scan type: Full scan (C:\|)
Objects scanned: 280043
Time elapsed: 45 minute(s), 46 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 1
(No malicious items detected)
Folders Infected:
Files Infected:
C:\Users\Fred\Documents\Fred's Files\Programs_Patches_Setup\mbam-setup-1.46.exe (Dont.Steal.Our.Software) -> Quarantined and deleted successfully.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Oh, BTW, MBAM was again disabled from startup after rebooting.
Fred
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
That's very strange that it's detecting its own installer as a virus. Perhaps you should contact Malwarebytes about this as they may be interested to find that their software is deleting itself.
mailto:support@malwarebytes.org
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
And they may correct the problem, if it is their problem and not a mistake made by us.
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Fred
Just a quick question here, do you have the free version or the paid version of MalwareBytes ?
The free version doesn't run in real time and that may be why it doesn't start at boot.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
I'm not sure what you mean by deleting, but it is disabling MBAM from the startup menu after reboot. I just sent them an e-mail.
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device. One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
Showing it was a false/positive
Rogue.FakeMSE, is this F/P? - Malwarebytes Forum
Look in Services by typing services.msc, scroll down to MBam, right click on it and choose properties. Set the dropdown box to 'Automatic'
Malwarebytes is not listed in my "services" menu. The Rogue.Fake.MSE is not coming up anymore, but Don't.Steal.Our.Software. is. I wonder why MBAM isn't listed in my "services" menu though!!
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Another problem now..I just ran Super Anti-Spyware and after I rebooted MSE was turned off. I got a warning in the tool bar that I had multiple security issues and when I opened the security center MSE was turned off. It is also not listed in my services menu. Any ideas what's going on here?
Fred
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
Fred download DDS from one of these links:
Mirror 1 Mirror 2 Mirror 3
  • Disable any script blocking protection
  • Right click the dds icon, choose to run as Administrator, to run the tool.
  • When done, DDS will open two (2) logs:
    1. DDS.txt
    2. Attach.txt<--- this log will be minimized in the task tray
  • Save both reports to your desktop.
Include the contents of both logs in your new topic.
The scan will instruct you to post Attach.txt as an attachment.
No need for that though ..... just post it's contents as you would any other log.
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
Fred, this doesn't do anything to your computer .. all it does is show me some files so that possibly, we can track down the problem.
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
    1. DDS.txt
How do I disable script blocking protection?
    HPs3700y Slimline
    Asus M2N61-AR
    3 GB
    1280 X 1024
    160W
    HP
