Power Options and Sleep Mode Problems
How to Troubleshoot a Vista or Windows 7 Sleep Mode Problem
This will show you some steps to help you troubleshoot and find out what is causing your sleep mode problem. These are the usual reasons for sleep mode problems. For more information, see: Windows Help and How-to: Turn Off a Computer FAQs
  • When your computer is in hibernation, the only way to wake it is to tap the case power button.
  • If this sleep mode problem just started recently, then you might consider doing a System Restore before or after trying the steps below if they do not help.
Common Problems:
  • Computer will wake up for no reason.
  • Sleep mode does not work any more.
  • Hibernate option is not available in Power Options, then you accidentally deleted the Hibernation file Cleaner in Disk Cleanup.
  • Screen saver not working.
BEFORE STARTING:Make sure you have the latest device drivers and BIOS installed for your motherboard.NOTE: A out-of-date video driver or other drivers are sometimes the source of sleep mode problems. It is best to keep these up to date to resolve issues found with them.
STEP 1
Check Your Mouse and Keyboard
NOTE: A wireless mouse and keyboard can cause your computer to wake up for no apparent reason, and to not wake up from sleep mode when you press a key or move the mouse. This may also cause your screen saver to not work to. If the computer is using an optical mouse, changes in light can cause the computer to wake.
For a USB Mouse or Keyboard:
1. Check the BIOS settings to make sure that you have a Legacy USB option enabled.​
For a Wireless Mouse or Keyboard:
1. Unplug the receiver on the back of the computer and test.​
2. If sleep or hibernation works now, then try:​
A) Download new drivers for you wireless mouse and test again with the receiver plugged in.​
NOTE: Always get your drivers from the source, never from Windows Updates. They do not work properly sometimes.
B) Disable the wireless mouse and/or keyboard wake up option in Step Five below. If you have to disable both of them, then you can wake the computer up by pressing the power button on the case.​
C) Time to get a new mouse and/or keyboard that is compatible with Vista.​
For a Optical Mouse:
1. Try not to have direct bright light shining on the sensor or moving around it.​
STEP 2
Check Advanced Power Plan Settings
NOTE: Power settings control the computer’s ability to go into and come out of sleep/standby mode.
2. Click on the Power Options icon.​
3. Click on the Change plan settings link under your power plan. (See screenshot below)​
4. Click on Change advanced power settings. (See screenshot below)​
5. Click on Change settings that are currently unavailable. (See screenshots below step 10)​
NOTE: This will allow any Power Options that are grayed out to now work and not be grayed out.​
6. Recommended Settings for Sleep
NOTE: Sleep saves any open documents and programs to memory only, and then puts the computer into a low-power state.
WARNING: If you lose power to the computer, you will also lose what is in memory.​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Hard disk
[/TD]
[TD]
[/TD]
[TD]
Set to at least 1 minute before the computer (Sleep after setting below) is set to sleep.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Sleep after
[/TD]
[TD]
This is for the computer. Set to at least 1 minute after Hard disk and Display is set to turn off.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set to Off.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set to Never.
[/TD][/TR]
[TR][TD]
USB settings
[/TD]
[TD]
USB selective suspend setting
[/TD]
[TD]
Set to Disabled.
[/TD][/TR]
[TR][TD]
Power buttons and lid
[/TD]
[TD]
Start menu power button
[/TD]
[TD]
Set to Sleep.
[/TD][/TR]
[TR][TD]
PCI Express
[/TD]
[TD]
Link State Power Management
[/TD]
[TD]
Set to Off.
[/TD][/TR]
[TR][TD]
Display
[/TD]
[TD]
Turn off display after
[/TD]
[TD]
Set to at least 1 minute before the computer (Sleep after setting above) is set to sleep. Usually set this as the same as the Hard drive is set to turn off.
[/TD][/TR]
[TR][TD]
Multimedia settings
[/TD]
[TD]
When sharing media
[/TD]
[TD]
Set to Allow the computer to sleep.
[/TD][/TR][/TABLE]
7. Recommended Settings for Hybrid Sleep
NOTE: Hybrid sleep saves your open documents and programs to memory and to the hard drive, and then puts the computer into a low-power state. After the Hibernate after time you set, it will then put the computer into hibernation.
WARNING: Use the same Recommended Settings for Sleep in step 6 above, except for these changes:​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set to On.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set to at least 1 minute after the computer (Sleep after setting above) is set to sleep.
[/TD][/TR][/TABLE]
8. Recommended Settings for Hibernation
NOTE: Hibernation is a power-saving state that saves your open documents and programs to the hard drive and then turns off your computer. If Hibernate after is not listed, then make sure that you have the Hibernation File enabled or restored to. It is by default unless it was cleaned in Disk Cleanup.​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Sleep after
[/TD]
[TD]
Set it to Never.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set it to Never.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set it to at least 1 minute after Hard disk and Display is set to turn off.
[/TD][/TR]
[TR][TD]
[/TD]
[TD]
[/TD]
[TD]
Set it to Hibernate.
[/TD][/TR][/TABLE]
9. Click on OK to apply​
10. Just exit out the other windows.​
11. Test sleep mode. If it is still not working correctly, then continue to the next step.​
STEP 3
Check Sleep State Settings in BIOS
NOTE: Make sure you have the latest Video drivers and BIOS for your motherboard. Read your motherboard manual to see if you have any jumpers or settings that sets different sleep voltages for USB.
1. Open the Start Menu.​
2. In white line (Start Search) area, type cmd and press Enter.​
3. In command prompt, type powercfg -a and press Enter. (See screenshot below)​
NOTE: This will give you a report of the available sleep states for your computer and will attempt to report reasons why sleep states are unavailable. You will want to see if the ACPI S1 and/or S3 is listed.
4. Restart the computer into the BIOS settings, and go into the Power Management section in the BIOS.​
NOTE: Usually you will press the F2 or Delete key as soon as your computer starts booting to enter the BIOS.
5. Make sure ACPI mode: S3 or S1 is enabled.​
WARNING: S1 (Sleep) and S3 (Hybrid deeper sleep). If you are running an incompatible video card, some or all of these states below may be unavailable. If one of the settings causes your computer to not wake back up afterwards, then reset the CMOS on the motherboard and restart the computer, or unplug the computer for a moment and plug it back in, and reset the BIOS back to the factory default settings.
6. Make sure Wake on Ring and Wake on Lan are disabled.​
NOTE: This will help keep the computer from waking up on its own.​
7. Save the BIOS setting changes and exit to restart the computer.​
8. Test sleep mode. If this does not help, then move on to the next step.​
STEP 4
To See what had Waken Up Windows Last
NOTE: This will give you a list of items that woke up the computer last that may help narrow down what is waking up the computer.
3. In command prompt, type powercfg lastwake and press Enter. (See screenshot below)​
NOTE: Notice that I had USB\ROOT\HUB listed. For me, this would be the USB wireless mouse. Your list results will vary of course.​
STEP 5
To List, Enable, or Disable Device Names Currently Configured to Wake Up the System From any Sleep State
NOTE: This will show you a list of devices that are able to wake up your computer to help you narrow down a device that may be responsible for waking up your computer. It does not mean that these devices are the ones that woke up your computer though, just that they are able to.
2. To List Devices that Can Wake Up the Computer
A) In the command prompt, copy and paste in bold: (See screenshot below)​
powercfg -devicequery wake_armed and press Enter.​
B) Go through the list of devices to see if you have one you do not want to wake up your system.​
EX: A Network Device (Modem, Ethernet, etc.) or Wireless Mouse.​
C) If you found a device that may be causing the problem, then check with the STEP SIX section below first to see if you can disable a wake up option for the device in it's Power Management settings in Device Manager to test to see if that is it before proceding.​
3. To Disable a Listed Device From Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead.​
A) In the elevated command prompt, type below in bold and press Enter.​
WARNING: Be sure to write this device name down in case you want to be able to enable it again in step 4. Once you disable it, it will not be listed again in step 2A until enabled again.​
powercfg -devicedisablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to disable the listed (step 2A) High Definition device (HDAC), then I would type powercfg -devicedisablewake "High Definition Audio Controller" and press enter.​
4. To Enable a Listed Device Again to Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead, or you have done step 3 above with the device.​
powercfg -deviceenablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to reenable the High Definition device (HDAC) that was disable and removed from the list in step 3, then I would type powercfg -deviceenablewake "High Definition Audio Controller" and press enter.​
5. When done, close the elevated command prompt, and test sleep mode.​
STEP 6
To Disable or Enable the "Allow this device to wake the computer" Option for a Device
  • Check your Network device. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections).
  • High Definition Audio, if listed in STEP FIVE, may also rarely cause the computer to wake from sleep mode. You can disable (only option available) the device as a test in Device Manager to see before putting the computer to sleep. Just enable it again if it is not the problem.
2. Click on the Device Manager icon.​
NOTE: You need to be in a Administrator account.
4. Open the device's list that you want to change. (See screenshot below)​
EX: Network Devices
5. Right click on the device name and click on Properties.​
EX: Network Devices
6. Click on the Power Management tab. (See screenshot below)​
7. Uncheck Allow this device to wake the computer. (See screenshot above)​
NOTE: To Enable it again, just check this instead. If you need to disable the wireless mouse and keyboard, then you can wake the computer by pressing the power button on the case.
8. If listed, check Allow the computer to turn off this device to save power. (See screenshot below step 6)​
NOTE: This will turn the device off when the computer goes into sleep mode.
9. Click on the Advanced tab. (See screenshot below)​
NOTE: This is only for the Network device.
10. Check the boxed in red Property: items below to see if they are set to Disabled in the Value: area. (See screenshot above)​
NOTE: This area may be different for your particular network device since it is based on the driver, but it should be similar. You will be looking for any Wake on type property options listed.​
11. Click on OK to apply and close properties window. (See screenshot below step 6 or 9)​
STEP 7
Check the Screen Saver
NOTE: Some screen savers can interfere with the computer’s ability to go into and come out of sleep/standby mode. Disabling or changing the screen saver may resolve the problem.
1. In the Screen saver settings, select an alternate screen saver, or set it to None, then click on OK.​
2. Test sleep mode.​
STEP 8
Check Startup Programs
  • Many software components start up automatically with Vista and run in the background. Some of these programs may not be necessary, and can interfere with the sleep/standby mode. For troubleshooting purposes, use the following steps to prevent programs from starting up with Vista to see if this is the issue.
  • If you are having these problems, you can avoid from having to do this completely if you logoff and put the computer to sleep from within the logon screen.
A) In the white line (Start Search) area, type msconfig and press Enter.​
B) Go to step 3.​
OR
2. Click on All Programs, Administrative Tools, and System Configuration.​
4. Under the General tab, dot Selective startup. (See screenshot below)​
NOTE: When done with the test, dot Normal startup, to return to the default settings before the test, and click on OK.
5. Uncheck Load startup items and click on OK and restart the computer.​
NOTE: You will get a notification that you made changes to the Startup programs in the bottom right Notification area. Just ignore it for now. It will go away when you put it back to Normal startup after you finish.
6. Test sleep mode.​
7. If unchecking (disabling) Load startup items fixed the sleep problem, then enable one startup item at a time and test to see if the problem occurs again. Continue enabling startup items, until you find the program that is causing the problem. Remove or update the problem program.​
NOTE: See Method One or Two here: How to Check and Change the Startup Programs in Vista
A) When done, change the setting back to Normal startup (step 4).​
8. If unchecking (disabling) Load startup items did not resolve the sleep problem, then set it back to Normal startup (Step 4) and go to the next step below.​
STEP 9
Check Scheduled Tasks for Programs
NOTE: Sometimes a program will have something scheduled to run that will wake the computer up. Try turning them off temporarily to see if it resolves the problem.
1. Check in the suspected program settings to see if there is a feature that may wake the computer.​
NOTE: Sometimes it can be the Auto-Update feature in the program.​
2. Check Task Scheduler for items that are set to Wake-Up the computer to perform it's action.​
A) Expand out the list in the left pane and click on the suspect item's folder. Double click on the task in the middle pane.​
B) Click on the Conditions tab.​
C) Uncheck the Wake the computer to run this task box.​
3. Check Windows Automatic Updates settings.​
STEP 10
Check Windows Sidebar Gadgets
NOTE: Sometimes a Windows Sidebar Gadget may cause the computer to not sleep on it's own.
1. Turn off Windows Sidebar as a test to see if your computer will enter sleep on it's own now.​
NOTE: Sometimes, you may need to restart the computer afterwards as well.​
2. If it does, then turn Windows Sidebar back on and turn off each Gadget one by one. Test sleep again after each one until you find the one causing the problem.​
STEP 11
Check Motherboard Jumpers
NOTE: A few motherboards have been reported has having jumpers on the board for certain functions (ex: USB device wake-up) that may need to be enabled or disabled.
1. Pull out or download your motherboard manual, and check for any such jumpers.​
2. If you have one that is related (ex: USB device wake-up), then test sleep mode inbetween toggling the jumper on and off.​
STEP 12
Reset Print Spooler
NOTE: This may help if your computer will sleep fine manually, but will not sleep automatically or not go to sleep at all. Credit to Artxie for this.
1. Open Services, and temporaily Stop the Print Spooler service.​
2. Open the Start Menu and type %WINDIR%\system32\spool\printers in the search line and press enter, then delete all files in this folder.​
3. In Services, Start the Print Spooler service. Close Services window.​
If the print spooler issue persists, the installed printer driver may not be compatible or corrupted. Check the printer manufacturer's website to download and install the latest Windows compatible driver for it.
STEP 13
Enable or Disable Windows Media Center Updates to Wake Up the Computer
NOTE: This will show you how to enable or disable the Windows Media Center (mcupdate) task from waking up the computer from sleep when it checks for Media Center updates in Windows 7 and Vista.
STEP 14
View and Override Power Availability Requests
By using power availability requests, applications, services, and drivers can temporarily disable power management features to accomplish user scenarios. Availability requests can prevent the display from turning off after inactivity, and prevent the computer from automatically sleeping, enable Away Mode, and shutting down.
STEP 15
Try System Restore
NOTE: If sleep/standby mode previously worked, attempt a system restore back to a time when it worked. If the problem has always existed, skip this step.
1. Save any open files and close all programs, then backup anything that you do not want to lose to be safe..​
NOTE: If System Restore resolves the problem, the problem is probably caused by software that was installed after the restore point date.
I hope this helps,
I'm not sure about the graphics card overheating, but it isn't overclocked.
I have a 500 watt power supply made by Antec. I also have all my case fans on medium.
    AMD Phenom X4 9850 2.5 GHz
    ASUS M3N-HD / HDMI
    4.00 GB
    nVidia GeForce 8800 GTS 640
    500 GB
Not sure if I had mentioned this, but the new drivers had seemed to fix the video issues, although, sometimes (after sleep or occasionally sometime after boot (only occurred twice, though)) the video just goes black and the machine stops responding completely.
Also, soon after I start flying in Flight Simulator X, the machine will stop responding, the video will freeze and the same sound just repeats.
Orion,
Power supply looks good to me. I'm stumped on this last problem that you are having. You might post that question in the General Discussion forum and Vista General newsgroup to see what the others may come up with for you as a hopeful solution.
Sorry, :(
Orion,
Sorry, :(
WAIT!!!!!!!!!!!!!!!!!!
I found that Nvidia released new drivers. I tried those and some of my video freezing issues stopped!
Will post more info later, it is very late here and I have things to do tomorrow so...
Thanks for helping and talk to you later.
-Orion
    ASUS M3N-HD / HDMI
    4.00 GB
    500 GB
Well, my computer was still crashing and now even before I could get off the runway :(.
So, I reinstalled Windows Vista. This time Windows Vista Ultimate 32 bit SP1. I guess I'll just wait until I get a new computer or Windows 7 for 64 bit.
Thanks for all your help anyways
-Orion
    ASUS M3N-HD / HDMI
    4.00 GB
    500 GB
Hi all,
I have a P5N-D with 8 GB RAM DDR2 DDR2 SDRAM - Wikipedia, the free encyclopedia -800MHz, C2Q Q6600 and a ASUS EN9800GTX.
Newest BIOS 602 installed with vista Indian Institute of Management Bangalore - Wikipedia, the free encyclopedia 64, Nvidia nforce and gforce drivers are the newest official ones.
I want to use the standby hybrid sleep, but it does not work reliably, about every third time or so it does not completely shut down the fans still turn and but the display stays black, and it can not be waken up only be pressing the powerbutton for 5 seconds with a new start, disruptive shutdown is in the event log written.
Anyone having similar problems or suggestions what i could test?
Besides the standby problem, the system is running smooth also under stress.
i have only a multicardreader and sata hdd, a joystick and a wireless. I will try to install a driver for the keyboard.
I have checked the settings they reccomended here in the vistax64 forum tutorial. The only thing that is left to do is i will check the
powercfg -devicequery wake_armed command to see what is in.
I will also check if the cardreader is somwhere in the device manager and try to find a new driver for it.
Thanx for any suggestions and help.
Hi Shawn,
I have a question about Step Five: #9. If i select, for my network card, "allow this device to wake the computer" AND "only allow management stations to wake the computer", would this allow my networked laptop to wake the sleeping desktop and vice versa? Or is that the sort of thing that the "wake up on ARP/PING" is intended to allow? I'm looking for an easy way to allow any machine on my home network to wake any other machine. (I've read other posts about magic packets, etc...but surely there's some setting such as these that would allow wake up when a networked machine is looking for the sleeping machine?)
Thanks in advance!
Dustin
    Dell Optiplex 745
yeah thanks Sid, but that was me in that post you linked to! I think i'm trying to make a mountain out of a mole hill with this issue, it just seems like something that should be much more intuitive, IMHO. Can you tell me what those options i referenced above are for then?
    Dell Optiplex 745
Sorry for that, you should have posted in the same thread ;)
If you're talking about the link, the progs are made to create and send magic packets through the network, you can wake up individual machines by using the mac address or you can wake all the machines.
well no i was talking about the options Brink sites in this tutorial and that i referenced in my first post here this morning.
    Dell Optiplex 745
Well, apart sending magic packets, i do not see any issue to your demand.
The options you're talking about are just permissions to give to "allow" the computer to wake up or not.
I found this article very helpful as it taught me a lot about Vista.
But it missed the cause of my problem (easy to happen with so many things to consider and different hardware manufacturers)
My I suggest an additional step 1 point:
Check mother board switches!
My Asus PK5PL-CM has a jumper that sets different sleep voltages for USB.
One for S1 sleep and another for S3 sleep :odah - should have read the mboard manual a bit more carefully. When I changed the jumper to S3 my Vista Sleep/Restart problem was solved.
Hi Garray, and welcome to Vista Forums. It has been added under STEP THREE in the note. Thank you for the feedback.
Hello all:
I really thought that following this list of suggestions would do the job for me and get sleep mode recovery working again. With respect to night kid's 'keeping the internet connection alive' if the wireless router is setup to sign on to his ISP then the connection shpould be alive after Vista completes the restart or boot up operation.
Back to the drawing boards for me, I have to get this sleep mode recovery thing fixed!! Thanks for all of the excellent suggestions in this tutorial.
George
If anyone is using Logitechs Setpoint v4.oa2 for Vista do what I did, remove it ! I still have basic use of the keyboard (except for some special buttons)and mouse using vista's usb drivers/unchecking allow keyboard&mouse to wake computer. Now sleep mode works like it should...the trade-off is worth it.At least now I can focus on using my pc and not mess around with troubleshooting! Hope this helps someone else... Norbert
    custom built
    presler 945d
    asus p5p800
    2 gig kingston ddr400
    hd 3850 agp
    sound blaster audigy
    22" benq
    maxstor 40gb pata Hitachi 160gb sata seagate 320 ext. usb
    ocz 650 xtreme
    lian-li pc600
    1 intake 2 exhaust
    logitech mx400
    logitech elite multimedia
    1gbit
    casual gamer-all the fear games/doom3/all half-life/quake4 most at max settings. Good performance with my last agp baby...
I have Vista Home Premium 32bit. In Step 5 above I cannot do, I do not have the power managment option at stage 6 of this step therefore I cannot change any of the device wake up settings. Any suggestion on how I can get my toshiba laptop version of Vista into the retail version. Toshiba have changed a lot of Vista and are unhelpful when I seek there assistance so jsut struggle on the best I can. Thanks Hendo.
Hello Hendo, and welcome to Vista Forums.
Some devices do not have a Power Management tab. What devices are you trying to disable from wakeup?
I am trying to stop the mouse from waking the computer. I followed the instuctions and found that if I disconnect the mouse cable from the usb port my notebook will into sleep mode. Now I need to work out how to stop it from preventing the notebook from going into sleep mode. I have a Toshiba Satallite which has preinstalled vista so it makes it hard for me to get vista to run properly. Thanks
