Power Options and Sleep Mode Problems
How to Troubleshoot a Vista or Windows 7 Sleep Mode Problem
This will show you some steps to help you troubleshoot and find out what is causing your sleep mode problem. These are the usual reasons for sleep mode problems. For more information, see: Windows Help and How-to: Turn Off a Computer FAQs
  • When your computer is in hibernation, the only way to wake it is to tap the case power button.
  • If this sleep mode problem just started recently, then you might consider doing a System Restore before or after trying the steps below if they do not help.
Common Problems:
  • Computer will wake up for no reason.
  • Sleep mode does not work any more.
  • Hibernate option is not available in Power Options, then you accidentally deleted the Hibernation file Cleaner in Disk Cleanup.
  • Screen saver not working.
BEFORE STARTING:Make sure you have the latest device drivers and BIOS installed for your motherboard.NOTE: A out-of-date video driver or other drivers are sometimes the source of sleep mode problems. It is best to keep these up to date to resolve issues found with them.
STEP 1
Check Your Mouse and Keyboard
NOTE: A wireless mouse and keyboard can cause your computer to wake up for no apparent reason, and to not wake up from sleep mode when you press a key or move the mouse. This may also cause your screen saver to not work to. If the computer is using an optical mouse, changes in light can cause the computer to wake.
For a USB Mouse or Keyboard:
1. Check the BIOS settings to make sure that you have a Legacy USB option enabled.​
For a Wireless Mouse or Keyboard:
1. Unplug the receiver on the back of the computer and test.​
2. If sleep or hibernation works now, then try:​
A) Download new drivers for you wireless mouse and test again with the receiver plugged in.​
NOTE: Always get your drivers from the source, never from Windows Updates. They do not work properly sometimes.
B) Disable the wireless mouse and/or keyboard wake up option in Step Five below. If you have to disable both of them, then you can wake the computer up by pressing the power button on the case.​
C) Time to get a new mouse and/or keyboard that is compatible with Vista.​
For a Optical Mouse:
1. Try not to have direct bright light shining on the sensor or moving around it.​
STEP 2
Check Advanced Power Plan Settings
NOTE: Power settings control the computer’s ability to go into and come out of sleep/standby mode.
2. Click on the Power Options icon.​
3. Click on the Change plan settings link under your power plan. (See screenshot below)​
4. Click on Change advanced power settings. (See screenshot below)​
5. Click on Change settings that are currently unavailable. (See screenshots below step 10)​
NOTE: This will allow any Power Options that are grayed out to now work and not be grayed out.​
6. Recommended Settings for Sleep
NOTE: Sleep saves any open documents and programs to memory only, and then puts the computer into a low-power state.
WARNING: If you lose power to the computer, you will also lose what is in memory.​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Hard disk
[/TD]
[TD]
[/TD]
[TD]
Set to at least 1 minute before the computer (Sleep after setting below) is set to sleep.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Sleep after
[/TD]
[TD]
This is for the computer. Set to at least 1 minute after Hard disk and Display is set to turn off.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set to Off.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set to Never.
[/TD][/TR]
[TR][TD]
USB settings
[/TD]
[TD]
USB selective suspend setting
[/TD]
[TD]
Set to Disabled.
[/TD][/TR]
[TR][TD]
Power buttons and lid
[/TD]
[TD]
Start menu power button
[/TD]
[TD]
Set to Sleep.
[/TD][/TR]
[TR][TD]
PCI Express
[/TD]
[TD]
Link State Power Management
[/TD]
[TD]
Set to Off.
[/TD][/TR]
[TR][TD]
Display
[/TD]
[TD]
Turn off display after
[/TD]
[TD]
Set to at least 1 minute before the computer (Sleep after setting above) is set to sleep. Usually set this as the same as the Hard drive is set to turn off.
[/TD][/TR]
[TR][TD]
Multimedia settings
[/TD]
[TD]
When sharing media
[/TD]
[TD]
Set to Allow the computer to sleep.
[/TD][/TR][/TABLE]
7. Recommended Settings for Hybrid Sleep
NOTE: Hybrid sleep saves your open documents and programs to memory and to the hard drive, and then puts the computer into a low-power state. After the Hibernate after time you set, it will then put the computer into hibernation.
WARNING: Use the same Recommended Settings for Sleep in step 6 above, except for these changes:​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set to On.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set to at least 1 minute after the computer (Sleep after setting above) is set to sleep.
[/TD][/TR][/TABLE]
8. Recommended Settings for Hibernation
NOTE: Hibernation is a power-saving state that saves your open documents and programs to the hard drive and then turns off your computer. If Hibernate after is not listed, then make sure that you have the Hibernation File enabled or restored to. It is by default unless it was cleaned in Disk Cleanup.​
Main Setting
[/TD]
[TD]
Sub Setting
[/TD]
[TD]
Recommendation
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Sleep after
[/TD]
[TD]
Set it to Never.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Allow hybrid sleep
[/TD]
[TD]
Set it to Never.
[/TD][/TR]
[TR][TD]
Sleep
[/TD]
[TD]
Hibernate after
[/TD]
[TD]
Set it to at least 1 minute after Hard disk and Display is set to turn off.
[/TD][/TR]
[TR][TD]
[/TD]
[TD]
[/TD]
[TD]
Set it to Hibernate.
[/TD][/TR][/TABLE]
9. Click on OK to apply​
10. Just exit out the other windows.​
11. Test sleep mode. If it is still not working correctly, then continue to the next step.​
STEP 3
Check Sleep State Settings in BIOS
NOTE: Make sure you have the latest Video drivers and BIOS for your motherboard. Read your motherboard manual to see if you have any jumpers or settings that sets different sleep voltages for USB.
1. Open the Start Menu.​
2. In white line (Start Search) area, type cmd and press Enter.​
3. In command prompt, type powercfg -a and press Enter. (See screenshot below)​
NOTE: This will give you a report of the available sleep states for your computer and will attempt to report reasons why sleep states are unavailable. You will want to see if the ACPI S1 and/or S3 is listed.
4. Restart the computer into the BIOS settings, and go into the Power Management section in the BIOS.​
NOTE: Usually you will press the F2 or Delete key as soon as your computer starts booting to enter the BIOS.
5. Make sure ACPI mode: S3 or S1 is enabled.​
WARNING: S1 (Sleep) and S3 (Hybrid deeper sleep). If you are running an incompatible video card, some or all of these states below may be unavailable. If one of the settings causes your computer to not wake back up afterwards, then reset the CMOS on the motherboard and restart the computer, or unplug the computer for a moment and plug it back in, and reset the BIOS back to the factory default settings.
6. Make sure Wake on Ring and Wake on Lan are disabled.​
NOTE: This will help keep the computer from waking up on its own.​
7. Save the BIOS setting changes and exit to restart the computer.​
8. Test sleep mode. If this does not help, then move on to the next step.​
STEP 4
To See what had Waken Up Windows Last
NOTE: This will give you a list of items that woke up the computer last that may help narrow down what is waking up the computer.
3. In command prompt, type powercfg lastwake and press Enter. (See screenshot below)​
NOTE: Notice that I had USB\ROOT\HUB listed. For me, this would be the USB wireless mouse. Your list results will vary of course.​
STEP 5
To List, Enable, or Disable Device Names Currently Configured to Wake Up the System From any Sleep State
NOTE: This will show you a list of devices that are able to wake up your computer to help you narrow down a device that may be responsible for waking up your computer. It does not mean that these devices are the ones that woke up your computer though, just that they are able to.
2. To List Devices that Can Wake Up the Computer
A) In the command prompt, copy and paste in bold: (See screenshot below)​
powercfg -devicequery wake_armed and press Enter.​
B) Go through the list of devices to see if you have one you do not want to wake up your system.​
EX: A Network Device (Modem, Ethernet, etc.) or Wireless Mouse.​
C) If you found a device that may be causing the problem, then check with the STEP SIX section below first to see if you can disable a wake up option for the device in it's Power Management settings in Device Manager to test to see if that is it before proceding.​
3. To Disable a Listed Device From Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead.​
A) In the elevated command prompt, type below in bold and press Enter.​
WARNING: Be sure to write this device name down in case you want to be able to enable it again in step 4. Once you disable it, it will not be listed again in step 2A until enabled again.​
powercfg -devicedisablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to disable the listed (step 2A) High Definition device (HDAC), then I would type powercfg -devicedisablewake "High Definition Audio Controller" and press enter.​
4. To Enable a Listed Device Again to Waking Up the Computer
NOTE: Only do this step if you cannot do it from STEP SIX below using Device Manager instead, or you have done step 3 above with the device.​
powercfg -deviceenablewake "exact name of device listed in step 2A"
NOTE: For example, if I wanted to reenable the High Definition device (HDAC) that was disable and removed from the list in step 3, then I would type powercfg -deviceenablewake "High Definition Audio Controller" and press enter.​
5. When done, close the elevated command prompt, and test sleep mode.​
STEP 6
To Disable or Enable the "Allow this device to wake the computer" Option for a Device
  • Check your Network device. Network activity can cause the network hardware to wake the computer, especially when the network is always on (like cable and DSL connections).
  • High Definition Audio, if listed in STEP FIVE, may also rarely cause the computer to wake from sleep mode. You can disable (only option available) the device as a test in Device Manager to see before putting the computer to sleep. Just enable it again if it is not the problem.
2. Click on the Device Manager icon.​
NOTE: You need to be in a Administrator account.
4. Open the device's list that you want to change. (See screenshot below)​
EX: Network Devices
5. Right click on the device name and click on Properties.​
EX: Network Devices
6. Click on the Power Management tab. (See screenshot below)​
7. Uncheck Allow this device to wake the computer. (See screenshot above)​
NOTE: To Enable it again, just check this instead. If you need to disable the wireless mouse and keyboard, then you can wake the computer by pressing the power button on the case.
8. If listed, check Allow the computer to turn off this device to save power. (See screenshot below step 6)​
NOTE: This will turn the device off when the computer goes into sleep mode.
9. Click on the Advanced tab. (See screenshot below)​
NOTE: This is only for the Network device.
10. Check the boxed in red Property: items below to see if they are set to Disabled in the Value: area. (See screenshot above)​
NOTE: This area may be different for your particular network device since it is based on the driver, but it should be similar. You will be looking for any Wake on type property options listed.​
11. Click on OK to apply and close properties window. (See screenshot below step 6 or 9)​
STEP 7
Check the Screen Saver
NOTE: Some screen savers can interfere with the computer’s ability to go into and come out of sleep/standby mode. Disabling or changing the screen saver may resolve the problem.
1. In the Screen saver settings, select an alternate screen saver, or set it to None, then click on OK.​
2. Test sleep mode.​
STEP 8
Check Startup Programs
  • Many software components start up automatically with Vista and run in the background. Some of these programs may not be necessary, and can interfere with the sleep/standby mode. For troubleshooting purposes, use the following steps to prevent programs from starting up with Vista to see if this is the issue.
  • If you are having these problems, you can avoid from having to do this completely if you logoff and put the computer to sleep from within the logon screen.
A) In the white line (Start Search) area, type msconfig and press Enter.​
B) Go to step 3.​
OR
2. Click on All Programs, Administrative Tools, and System Configuration.​
4. Under the General tab, dot Selective startup. (See screenshot below)​
NOTE: When done with the test, dot Normal startup, to return to the default settings before the test, and click on OK.
5. Uncheck Load startup items and click on OK and restart the computer.​
NOTE: You will get a notification that you made changes to the Startup programs in the bottom right Notification area. Just ignore it for now. It will go away when you put it back to Normal startup after you finish.
6. Test sleep mode.​
7. If unchecking (disabling) Load startup items fixed the sleep problem, then enable one startup item at a time and test to see if the problem occurs again. Continue enabling startup items, until you find the program that is causing the problem. Remove or update the problem program.​
NOTE: See Method One or Two here: How to Check and Change the Startup Programs in Vista
A) When done, change the setting back to Normal startup (step 4).​
8. If unchecking (disabling) Load startup items did not resolve the sleep problem, then set it back to Normal startup (Step 4) and go to the next step below.​
STEP 9
Check Scheduled Tasks for Programs
NOTE: Sometimes a program will have something scheduled to run that will wake the computer up. Try turning them off temporarily to see if it resolves the problem.
1. Check in the suspected program settings to see if there is a feature that may wake the computer.​
NOTE: Sometimes it can be the Auto-Update feature in the program.​
2. Check Task Scheduler for items that are set to Wake-Up the computer to perform it's action.​
A) Expand out the list in the left pane and click on the suspect item's folder. Double click on the task in the middle pane.​
B) Click on the Conditions tab.​
C) Uncheck the Wake the computer to run this task box.​
3. Check Windows Automatic Updates settings.​
STEP 10
Check Windows Sidebar Gadgets
NOTE: Sometimes a Windows Sidebar Gadget may cause the computer to not sleep on it's own.
1. Turn off Windows Sidebar as a test to see if your computer will enter sleep on it's own now.​
NOTE: Sometimes, you may need to restart the computer afterwards as well.​
2. If it does, then turn Windows Sidebar back on and turn off each Gadget one by one. Test sleep again after each one until you find the one causing the problem.​
STEP 11
Check Motherboard Jumpers
NOTE: A few motherboards have been reported has having jumpers on the board for certain functions (ex: USB device wake-up) that may need to be enabled or disabled.
1. Pull out or download your motherboard manual, and check for any such jumpers.​
2. If you have one that is related (ex: USB device wake-up), then test sleep mode inbetween toggling the jumper on and off.​
STEP 12
Reset Print Spooler
NOTE: This may help if your computer will sleep fine manually, but will not sleep automatically or not go to sleep at all. Credit to Artxie for this.
1. Open Services, and temporaily Stop the Print Spooler service.​
2. Open the Start Menu and type %WINDIR%\system32\spool\printers in the search line and press enter, then delete all files in this folder.​
3. In Services, Start the Print Spooler service. Close Services window.​
If the print spooler issue persists, the installed printer driver may not be compatible or corrupted. Check the printer manufacturer's website to download and install the latest Windows compatible driver for it.
STEP 13
Enable or Disable Windows Media Center Updates to Wake Up the Computer
NOTE: This will show you how to enable or disable the Windows Media Center (mcupdate) task from waking up the computer from sleep when it checks for Media Center updates in Windows 7 and Vista.
STEP 14
View and Override Power Availability Requests
By using power availability requests, applications, services, and drivers can temporarily disable power management features to accomplish user scenarios. Availability requests can prevent the display from turning off after inactivity, and prevent the computer from automatically sleeping, enable Away Mode, and shutting down.
STEP 15
Try System Restore
NOTE: If sleep/standby mode previously worked, attempt a system restore back to a time when it worked. If the problem has always existed, skip this step.
1. Save any open files and close all programs, then backup anything that you do not want to lose to be safe..​
NOTE: If System Restore resolves the problem, the problem is probably caused by software that was installed after the restore point date.
I hope this helps,
Is simply disabling devices via device manager adequate, or should i literally unplug stuff (in your opinion). Thanks for taking the time to respond your help is much appreciated.
  • Motherboard
    Asus M3A-H/HDMI
You could try disabling, but physically removing them is the best method to tell for sure if that device is responsible or not.
This is an excellent thread that is obviously the result of plenty of hard work and contributions. It didn't solve my problem directly, but it did get me on the right track, so I wanted to post my solution to help others...
Sleep & Hibernate had been working fine for me, but stopped shortly after increasing memory in my box from 2gig to 4gig. I bought faster RAM this time, and increase the RAM speed from 867 to 1066mhz. Sleep never worked again. I lowered the RAM speed back down to 867mhz, still no sleep.
I ran OCCT to test the RAM, thinking I might have received some bad memory. Long story short, I noticed that the OCCT 3.3v graph showed that the 3.3v bus was only getting 3.1v. Sounds like a power supply problem to me.
Replaced the power supply and now the RAM works fine at 1066mhz, and sleep & hibernate are back in action!
    Asus Maximus Formula
    4gb OCZ Fatality 1066mhz
    ATI Radeon HD 2600
    BenQ FP202W
    2 WD 500gb - RAID0 2 Seagate 500gb - RAID0 1 Seagate Free Agent external SATA 500gb
    Corsair HX620W modular
Am I Unique? — IBM USB KB – Does not wake from Sleep with Vista 64
I have an IBM Enhanced USB Keyboard (Livorno) which I like a lot. I am on my second one after an errant cup of coffee.
  • The current keyboard and its older brother worked very well under Win XP (SP2 and/or 3).
  • However, I recently migrated to Vista 64 SP1 and I began to have a problem when I woke the computer from 'Sleep'. :(
  • The keyboard did not work. Only after I rejuvenate it by unplugging and re-plugging the it's USB connector would the keyboard wake up (sic). Then all would be well until I put the machine into sleep mode for the night.
  • BTW the keyboard always worked from a cold boot or a reboot.
  • While I can easily get the keyboard running again, I do not like to get on my knees to get the keyboard to work - though my wife likes the look.:sarc:
I am running Vista 64 SP1 on a white box ASUS P5E, Intel Core 2 Quad 9450, 8 GB RAM, bounteous HD space (Raid 0 for the OS and Raid 1 for the data), Nvidia 8800 HT graphics etc etc.
The keyboard data:
IBM Enhanced USB Keyboard Model Number: 89P8800; Serial: 09749446; Driver: Version: 2.0.1.2 of 15 Feb 15 2007 (the newest driver on Livorno’s website).
Questions:
  • Has anyone else experienced a similar problem?
  • Is my 89P8800 keyboard old and obsolete?
  • In this forum’s discussion on “How to Troubleshoot a Vista Sleep Mode Problem and Find a Solution” (See: http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html )there was the comment “C) Time to get a new mouse and/or keyboard that is compatible with Vista.” – but that was pertaining to a wireless keyboard – not a USB keyboard.
  • If so, I see a similar keyboard (Model 73P2620) available on Amazon. The $38 cost is diminimus compared the eight hours (and 10 lloonngg phone calls) I spent earlier this week calling the Lenovo help desk without finding anyone who was able to help in this matter.
What other keyboards should I look at?
I have scoured the web and have not found anyone with a comparable problem.
Thanks in advance for any/all comments and advice.
John
    White Box
    Intel Xeon X3350 @ 2.66GHz
    Asus P5E
    8 GB DDR2 800 mhz
    Nvidea 8800GT
    Dell 24"
    1920 x 1200
    2 1 TB Samsung Spinpoint F1 (Raid 0 & 1) 2 750 GB Maxtor (Raid 1)
    Lian Li (using for its second build)
    Logitech 810
    IBM Advanced USB Keyboard
    ~ 15 mb/s - Optimum Online
Hello John, and welcome to Vista Forums.
Since it is a USB keyboard, double check the BIOS settings to make sure that you have a Legacy USB option enabled.
Hi, Brink. Thx for the great tutorial ! I've read your tut but I can't solve my problem. I'm using Dell Vostro 1310. Vista Ultimate SP1 with full updates, and lastest bios version and driver for it
When I checked Device Manager, in tabs Keyboards/Standard PS/2 Keyboard and Mice and other pointing devices, I saw it didnt have Power Management tab.
With command " powercfg -a" in command promt, it shows "the following sleep states are avaiable on this system: Stanby (s3) Hibernate Hybrid sleep"
With command " powercfg -devicequery wake_armed", it shows only HD Audio Controller.
When I press Sleep button, it turns off but cann't wake up, fan's still working and screen turns off. So, I must hard reset :|
Sorry, my English skill is so bad. Thanks !
Hello Buidanhthuy, and welcome to Vista Forums.
As a test, disable Hibernation, and double check you Power Plan settings to make sure that they are set the same as the recommended sleep settings in Step Two (step 6).
Thx Brink, the first action when I installed Vista is disable hibernate, i've read step 6 and configure settings the same as recommended sleep settings but nothing changes :|
I think problem is my keyboard and mouse don't have Power management tab in Device Manager. Right ?
Double check in the Power Management section in your BIOS settings to see if there is a Power on by Mouse and Keyboard type option that you can enable to hopefully allow your mouse and keyboard to wake the computer.
Hi Bink:
Thanks for the VERY quick response - I hope you don't think me too rude for not responding for two days. If so I apologize!
I changed by ASUS 0702 bios from Legacy USB Support [Auto] to Legacy USB Support [Enabled], hoping that your advice would work.
Alas, it did not. I put the machine to sleep Wednesday night - and when I woke it up Thursday AM, I had to crawl under my desk again to UnPlug/RePlug. Then last night, just to be sure it was not the powered hub the keyboard was connected to, I plugged the keyboard cable directly into one of my computer's USB ports. The keyboard still failed to wake up today. :confused:
Now what to do?
Perhaps I will purchase a new keyboard. Should I chance it with a new Leverno Kboard - or try another?
Thanks again in advance,
John
    White Box
    Asus P5E
    8 GB DDR2 800 mhz
    Nvidea 8800GT
    Dell 24"
    1920 x 1200
    Logitech 810
Not at all John.
Did you double check in the Power Management section in your BIOS settings to see if there is a Power on by Mouse and Keyboard type option that you can enable to hopefully allow your mouse and keyboard to wake the computer.
You might also try the keyboard and mouse plugged into the PS2 ports to see if that makes any difference to.
If you get another keyboard/mouse combo, check to make sure that they are compatible with Vista to lessen the chance of problems with them.
Thanks Brink
So I went and ordered the keyboard (newer version) from Lenovo - after I spoke with their customer service who assured me that this keyboard is "compatible with Vista 64".
Let's hope so - or else it is going back.
BTW my Logitech 810 USB-wireless mouse does wake the computer in the AM when I put it back in its charging stand.
Thanks for all your help and pls cross your fingers with me that the new KB does work as advertised!
John
    White Box
    Asus P5E
    8 GB DDR2 800 mhz
    Nvidea 8800GT
    Dell 24"
    1920 x 1200
    Logitech 810
I hope so John. Please keep us informed.
Shawn:
I thought I had just proved myself stupid again :mad:
The old IBM USB keyboard will wake the computer from sleep.
Aha, I thought - that is the solution, but, alas, it was not.
While the machine would awake on a key press, the keys were still mute when I tried to type something.
Oh well, the new keyboard ships today - I hope that fixes the problem. :)
Best
John
    White Box
    Asus P5E
    8 GB DDR2 800 mhz
    Nvidea 8800GT
    Dell 24"
    1920 x 1200
    Logitech 810
I have my fingers crossed for you.
Shawn:
The keyboard arrived yesterday - it's wonderful to type on a perfectly clean KB. :geek:
Now the real test — would it operate when the computer woke up this morning?
Yes! :D So it appears that the old model was at fault.
The new model number is: 73P62210
Of course I will keep you posted should things go amiss. Thanks for all your help and concern.
John
    White Box
    Asus P5E
    8 GB DDR2 800 mhz
    Nvidea 8800GT
    Dell 24"
    1920 x 1200
    Logitech 810
You're welcome John. I'm happy to hear that the new keyboard is working for you. Thank you for posting back.
I have a Dell Inspiron 1525 with Vista Ultimate and I am having issues when I close the lid it restarts my computer instead of sleeping.
My Lid Close power option is at sleep....I don't know how to figure this out...
Thanks!
Julie
Hi Julie, and welcome to Vista Forums.
That is strange. Double check all of your other sleep settings (Step Two in tutorial) to see if they also look correct.
I did that - I have almost done all the steps......sometimes it randomly restarts when there is no activity.
When I shut the lid, it goes to sleep, but then when I press the power button to get it out of sleep it restarts and tells me I have to start in safe mode.
I didn't have this issue before - I got my laptop in April and last month, Vista had an issue and the OS had to be reloaded...ever since then it has been doing this. I turned off automatic updates, etc...and to no avail.
