OMG! Can someone please help me?!!
it happens to people all the time. i guess patience is what counts :)
    Gateway ML6437-est. laptop
    Intel (R) Pentium(R) Dual CPU T230 @ 1.86GHZ /1.87 GHz
    factory installed/user customized
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
    currently certified as the fastest computer in the city of 38761
i hope the recovery installs the sound/network connections/ and all the software.
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
In all the excitement I forgot. You asked before what caused all this. I think it was a virus and that the Adobe updater was not what it seemed.
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
As this is a snapshot of your computer with all the drivers and factory-installed softwares, it will have all things that came with the computer.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
ok guys, looks like it worked and i am able to start re-configuring all my settings. One more problem though, does anyone know how to reset my wireless router? I swear I knew the password but everyone one that I try seems to be wrong. Sheesh...I just can't catch a break....
Sunne
what kind of router do u have and which company do u get ur internet from? u might have to call them to let them reset it and give u another one.
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
Well, it's a Qwest hard router and I have a Netgear Wireless router attached to it. I'm going to reinstall the internet cd from Qwest and see if that helps....
its usually in your windows folder a folder called windows.old do a search for it
problem is when using a system resore/factory reset as yo did sometimes they give the folder a differant name (as you didnt use an actual vista install disk but the manfacturers recovery software
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Ok, searching for windows.old came up with nothing, any other ideas?
Sooo grateful for you guys...
Sunne
Sunne
When you open your c: partition, you should see the folder right there. Can you see it there?
Extensa
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
goto MyComputer and click Organize and make sure MENU is checked if so then YEY. a menu with file/tools/etc should be above Organize/VIEW/etc..next go to TOOLS and FOLDEROPTIONS..click VIEW Tab..click the 'show hidden files and folders' then clik Apply then OK. if u got this far ur almost there. hopefully!! the old account stuff is still there. double click "local disk c:\" and go to USER and the the name of the old account should be there.
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
Grrrr!! There is STILL nothing there; I did everything you suggested...where the heck are those files?! Aww, man...
Sunne
Hi Sunne,
I have a horrible feeling it was trying to tell you there wasn't enough space to save your data.:(
If that is the case, you should still be able to recover most of it.:)
See this post :
Recover Files After Format - Windows 7 Forums
Hope it helps.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Ok, I did something really dumb now. I uninstalled the pre-installed version of Microsoft Office; I did this because I was going to install my purchased version of Office Professional...wow, I must be really challenged. I do not have a cd of the basic Microsoft Office so I am getting one that is an .iso file. How do I install that version after it's finished downloading? Anyone know? I'm just trying to get back to normal so that I don't fail the classes I've worked so hard to finish...anyone that could help...
Hopefully this will be my last stupid move...
Thanks guys,
Sunne
Yes, should be, you can see from the post that I was able to recover files after formatting the drive twice.
The actual space the operating sytem has been restored on will have overwritten some of them - but any that are on the free space area of the drive - I guess most of it - should be recoverable using those free programs.
Trouble is - any thing you write to your hard drive now - including anything you download - will be overwriting some of the files - they are still there - you just can't see them.
Best thing would be to download the recovery programs onto an external drive or another partition, run them from there and restore anything to there.
If you don't have an external drive - I would risk shrinking the main operating system partition and creating another partition on which to do the restore operation.
It needs to be big enough to hold the recovered data - but not so big that it overwrites anything as you create it.
Any idea how much space you would need to restore the most vital DATA ?
You could run a quick test with this - it does not need to be installed - just rt click the zip and Extract all - then rt click the Data Recovery and Run as Admin - it is not my first choice app. for the job , but will let you see what can be recovered .
It is also small and will not overwrite too much downloading it.
View attachment DataRecovery_EN.zip
You can then decide if you want to create another partition , get the other apps. and do the recovery.
The recovery apps find the data on the HD - if you elect to recover any , they will copy it to your chosen location - the data is stil there on the hd - they just make copies.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
It is also a good idea to turn off System Restore and Disk Defrag - turn them back on when you have completed the recovery .
Type services and click it when it appears
scroll down to Volume Shadow Copy , rt click , select Properties
Select Disabled - click Apply then OK
click STOP the service
Type defrag , click it when it appears , OK the UAC prompt
click Configure Schedule,
Untick Run on a Schedule, click OK
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
SIW2, I sure hope that you do this for a living because I've been dealing with this since 7am today and my head is throbbing like I've never felt before. Right now I am downloading the free trial of Office because, like a dope, I thought that I should uninstall it like needs to be done with Norton so that my new Office Pro would install correctly...sheesh. I have learned...boy, have I learned...I'm going to try your suggestions as soon as I can get my assignments done and posted online. Thank you so much (Pooch, Dinesh and inc2000; anyone I might have missed too)...I will update this thread with findings so that other people can learn...
Thanks again (*bowing to you all*)
Sunne
Good luck with the assignments - and keep us posted:D
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
