Index - Enable or Disable
How to Enable or Disable Search Index in Vista and Windows 7
This will show you how to Enable or Disable the Search Index. You may want to disable it to get more accurate search results, or to stop your hard drive from running so much.
The Index keeps track of the files on your computer and stores information about the files, including the file name, date modified, and properties like author, tags, and rating. The index is used to make searching for files in Vista much faster. Instead of looking through your entire hard disk for a file name or file property, Vista scans the index, which allows most results to appear in a small fraction of the time that a search without the index would take.
The Index will run slowly in the background during low or idle computer usage to keep itself updated and current from the changes you make to the files from the locations that you have listed in the index. If you do a lot of changes in these indexed locations, then your search results will not always be accurate until the index has finished updating itself. This can cause the hard drive to run a lot, especially for the first week or so after installing Vista. If you do not do a lot of searches or need very accurate search results, then disable the index to allow Vista to default to using the full non-index search of the drive. The searches will take a bit longer since it is a non-indexed search, but it will cut down on the hard drive running as much and will give accurate search results.
  • Disabling the index may also impact some Microsoft programs, like MS Office Outlook or Windows Media Player, that use the Index when they search.
  • Disabling the index in Windows 7 will cause you to no longer be able to do searches in Libraries. To be able to search in libraries, the Windows Search service needs to be Started and set to Automatic. Libraries require it's included folders to also be added to the index to be tracked properly even though they will still open properly.
  • Disabling the index in Windows 7 will cause you to no longer be able to use Arrange by in Libraries.
EXAMPLE: Index Enabled and Disabled
OPTION ONE
Disable or Enable the Index "Windows Search" Service
NOTE: This will enable or disable the Index for Windows completely. It will not affect the regular non-indexed search feature in Windows.
1. Open the Start Menu, then type services in the search box and press Enter.​
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. Scroll down and right click on Windows Search, then click on Properties. (see screenshot below)​
4. To Disable the Index
A) Click on the Stop button. (see screenshot below step 6)​
B) Next to Startup type, click on the drop down menu arrow and click on Disable.​
C) Click on Apply.​
D) Go to step 6.​
5. To Enable the Index
A) Next to Startup type:, click the drop down menu arrow and click on Automatic. (See screenshot below step 6)​
B) Click on Apply.​
C) Click on the Start button.​
NOTE: If the Windows Search service will not start, then leave it set to Automatic and see: How to Fix the Start Error For Windows Search Service to Enable the Index
6. Click on OK.​
7. Close the Service window.​
OPTION TWO
Enable or Disable Index for a Specific Drive
NOTE: This will only enable or disable the Index for the drive you selected.
1. Open the Start Menu.​
2. Click on the Computer button on the right dark side.​
3. Right click on the hard drive that you want to enable or disable Index on, and click on Properties.​
A) Uncheck the Index this drive for faster searching box. (see screenshot below step 6)​
B) Go to step 6.​
A) Check the Index this drive for faster searching box. (see screenshot below step 6)​
NOTE: Step 5 in the OPTION ONE section above will need to be set to enabled for this to work to.​
6. Click on Apply.​
7. Select (dot) Apply changes to drive, subfolders, and files. (see screenshot below)​
8. Click on OK.​
9. Click on Continue in the Access Denied window. (see screenshot below)​
10. Click on the Ignore All button for the Error Applying Attributes window. (see screenshot below)​
NOTE: Vista does not like any attempt to mess with the boot files. This is why you get this error and should select ignore all to skip changing these files.
11. This may take a while to finish depending on the size of your hard drive, so sit back, kick the feet up and relax a bit.​
12. When finished, click on OK to close drive properties window. (see screenshot below step 6)​
Well, at least you didn't tell me to turn on the index! :geek:
Actually, I just noticed with the index off Media Center keeps insisting that no shows match my search when I search for any shows, movies, etc., so I'm going to leave it on.
Thanks for the reply and Happy New Year! :party:
    Intel Core2 Quad [email protected]
    Gigabyte GA-EP35-DS3L
    4 Gig Kingston SDRAM DDR2 1066 (PC2 8500)
    SAPPHIRE Radeon HD 2600XT
    WD 1 TB
LOL, no problem Mic. I hope you have a happy New Year to.
Hi Brink,
Thanks for the great tips and site ... lots of useful info.
One thing I will comment on is that I don't think you fully explained the down side of disabling the indexing service in Vista. I agree that there can be a noticeable boost in performance (especially on older systems or laptops that use suspend a lot), but there is also some signficant loss in usability.
Yes, you can still search for files without using the index or replace it with another index though I'd aruge that you will lose much if not all of the performance gain or possibly lose performance given that other search engines aren't optimized.
The thing you would want to state more clearly in your "Note" area is the other areas that are affected. Start Menu searching is essentially useless (I almost never look for a program, just type the name and hit enter!), Outlook search is tied to it as mentioned in one of your posts, Windows Media Player uses it, Windows Mail/Live Mail, ... you get the point. A lot of MSFT apps are tying into using Windows Search for their built-in app search and disabling the Indexer reduces the fucntionality across the board.
I think with Vista SP1 and the new Windows Desktop Search 4.0 release, MSFT addressed a lot of the performance problems (especially for a laptop coming out of Suspend). To me, the usability loss isn't worth the slight performance gain with this specific tip, and I think more of your users might make the same choice given full information on what else might not work. It's not just 'slower searches'.
Thanks!
Hello Pete, and welcome to Vista Forums.
I have added a warning box to help warn about this, but I still have no problems doing a search from the Start Menu, Windows Mail, or Window Live Mail with the Index disabled though.
I'm not clear on some of this, and probably others are confused, too, so maybe someone can help us out?
Is Search 4.0 included in SP1?
I went top the Microsoft page and downloaded Windows6.0-KB940157-x86.msu. I tried to install, but Windows informed me that it was not for my system. I must say the page at Windows Search was less than completely helpful.
The reason I am interested is that I downloaded the M$ desktop search for my XP Pro machine and was impressed by the preview pane, which I cannot seem to find or which does not exist on the Vista search.
So, yes, I am confused. I have heard mention of Google desktop search and others, but am reluctant to dive in without a clear idea of what is out there, what I have and what the downsides of non-Vista searches might be.
Is there a FAQ anywhere or a thread that lays all this out clearly?
TIA
(signed)
:confused: Confused
    Atom
Hello Allend, amd welcome to Vista Forums.
Search 4.0 would have came through Windows Update instead. You should see it listed when clicking on the View update history link in Windows Update.
Thanks.
That is what I thought, but that Windows6.0-KB940157-x86 or any variation on that is not shown among the updates in my Add/Remove.
Maybe I got the wrong update? Dunno. I had problems understanding the Windows Search page. It looked to have been written by a marketer and not a tech-minded person.
How else would I know if I got that update, I wonder? Windows Update seems to think I have everything, and I used "Custom" to check.
    Atom
Sorry Allend, had to reboot into Vista to check for you.
It should be listed as Windows Serarch 4.0 when you go into the Programs and Features View installed updates link if installed from Windows Updates.
OK. Thanks. It does show up in my Windows Update history list as installed on Oct 19th and it is KB940157. It does not, however show up on "Uninstall or Change a program".
I guess I have it. That's disappointing. Would have liked a preview pane like the XP desktop add-on has. I was playing around with that one last night and it is amazing how easy it is to browse around and see the results immediately in a preview.
Can that search work with Vista, I wonder? And how would that coexist with the current indexer? And what about outside suppliers of search like Google?
Too many questons, and I'm out of time.
There must be a better way.
    Atom
I do not about them, but I usually just use Advanced Search when I search for anything in Vista.
You could turn on the Preview Pane in Advanced Search the same way as in Windows Explorer after you type in something to search for. I do not know how that would react by installing it in Vista. It would not be a good idea.
OK. I would like to do that and have hunted all over for the switch to turn on preview, but cannot find it. Where would I look?
I can click the item, but it then opens the file, and there is no preview pane I can find.
Is there some other option that must be turned on? I have my Vista looking more like NT or Server 2003 than than Vista out of the box.
Are we even talking about the same thing? Here is a shot:
    Atom
Yep, same thing. ;)
In the middle toolbar in your Advanced Search screenshot, click on Organize, Layout, and Preview Pane.
Well, I'll be hornswaggled! It was there all the time and I missed it.
I figured the newest version should be best, but did not see that item.
Thanks. I'm glad I asked. Now, how do I get it open in Advanced mode every time, assuming I am using Windows+F? (I got it open maximized each time by closing it with Ctrl held down). And is there any way to bracket dates, or just <, =, or > ?
And, the preview pane does not seem to always stay on for some reason. I have had to open it multiple times. This is not entirely intuitive.
I suppose I need to find the FAQ or read the help.
Thanks again.
Thanks.
    Atom
LOL, you're welcome Allend.
I have to open almost each time as well.
Allen, I'm happy that you found an alternative that suites your needs. :)
You're welcome Superneat.
