Index - Enable or Disable
How to Enable or Disable Search Index in Vista and Windows 7
This will show you how to Enable or Disable the Search Index. You may want to disable it to get more accurate search results, or to stop your hard drive from running so much.
The Index keeps track of the files on your computer and stores information about the files, including the file name, date modified, and properties like author, tags, and rating. The index is used to make searching for files in Vista much faster. Instead of looking through your entire hard disk for a file name or file property, Vista scans the index, which allows most results to appear in a small fraction of the time that a search without the index would take.
The Index will run slowly in the background during low or idle computer usage to keep itself updated and current from the changes you make to the files from the locations that you have listed in the index. If you do a lot of changes in these indexed locations, then your search results will not always be accurate until the index has finished updating itself. This can cause the hard drive to run a lot, especially for the first week or so after installing Vista. If you do not do a lot of searches or need very accurate search results, then disable the index to allow Vista to default to using the full non-index search of the drive. The searches will take a bit longer since it is a non-indexed search, but it will cut down on the hard drive running as much and will give accurate search results.
  • Disabling the index may also impact some Microsoft programs, like MS Office Outlook or Windows Media Player, that use the Index when they search.
  • Disabling the index in Windows 7 will cause you to no longer be able to do searches in Libraries. To be able to search in libraries, the Windows Search service needs to be Started and set to Automatic. Libraries require it's included folders to also be added to the index to be tracked properly even though they will still open properly.
  • Disabling the index in Windows 7 will cause you to no longer be able to use Arrange by in Libraries.
EXAMPLE: Index Enabled and Disabled
OPTION ONE
Disable or Enable the Index "Windows Search" Service
NOTE: This will enable or disable the Index for Windows completely. It will not affect the regular non-indexed search feature in Windows.
1. Open the Start Menu, then type services in the search box and press Enter.​
2. If prompted by UAC, then click on Continue (Vista) or Yes (Windows 7).​
3. Scroll down and right click on Windows Search, then click on Properties. (see screenshot below)​
4. To Disable the Index
A) Click on the Stop button. (see screenshot below step 6)​
B) Next to Startup type, click on the drop down menu arrow and click on Disable.​
C) Click on Apply.​
D) Go to step 6.​
5. To Enable the Index
A) Next to Startup type:, click the drop down menu arrow and click on Automatic. (See screenshot below step 6)​
B) Click on Apply.​
C) Click on the Start button.​
NOTE: If the Windows Search service will not start, then leave it set to Automatic and see: How to Fix the Start Error For Windows Search Service to Enable the Index
6. Click on OK.​
7. Close the Service window.​
OPTION TWO
Enable or Disable Index for a Specific Drive
NOTE: This will only enable or disable the Index for the drive you selected.
1. Open the Start Menu.​
2. Click on the Computer button on the right dark side.​
3. Right click on the hard drive that you want to enable or disable Index on, and click on Properties.​
A) Uncheck the Index this drive for faster searching box. (see screenshot below step 6)​
B) Go to step 6.​
A) Check the Index this drive for faster searching box. (see screenshot below step 6)​
NOTE: Step 5 in the OPTION ONE section above will need to be set to enabled for this to work to.​
6. Click on Apply.​
7. Select (dot) Apply changes to drive, subfolders, and files. (see screenshot below)​
8. Click on OK.​
9. Click on Continue in the Access Denied window. (see screenshot below)​
10. Click on the Ignore All button for the Error Applying Attributes window. (see screenshot below)​
NOTE: Vista does not like any attempt to mess with the boot files. This is why you get this error and should select ignore all to skip changing these files.
11. This may take a while to finish depending on the size of your hard drive, so sit back, kick the feet up and relax a bit.​
12. When finished, click on OK to close drive properties window. (see screenshot below step 6)​
Hi bmp,
You will not get any errors by disabling the Index. Disabling the Windows Search service (Option One) will disable the Index completely, while Option Two will just disable it for the drive you selected.
Thanks for reply.So now if i Disable Windows Search service option one it will disable Index completely thn i dont need to Disable like Option two way......
So if for scurity or safety reason i ask again it will safe to do this( I wants to disable from Service) and after disable it i can search for file anyway right???(I know search will be slow)and after disable it perfomance will be littlebit better(Maybe) right?
Sorry for asking help but very newbie ....thts why....
No problem bmp. Yes, it is safe and not a security risk. You will still be able to a normal slower non-indexed search with accurate search results. With the Index disable it can help stop your hard drive from running as much in the background.
Thanks Brink for great support ..really helpfull.
P.s I disabled windows Search from services without any prpblem.But i didnt Unchecked it from My computer C drive: Index this drive for faster searching or i need to Uncheck this anyway....
bmp, with the Service disabled there is no need to uncheck it from My Computer to. Disabling the Service disables the Index completely.
luvin it -- thank you!!
    INTEL CORE 2DUO CPU T5250
    MOBILE INTEL 965 EXPRESS CHIPS
    2.00 GB
    (n/a) 800x600 (1Hz)
    FUJITSU MHW2160BH PL
Your welcome VMLENZA.
Re: Indexing Service (Search)
Thanks Man !
Kinda disliked the Indexing feature , Google Desktop is btter IMO
Google Desktop is not compatibile with the 64-bit version of Vista. :(
I did manage to get Google Deskop to install on 64-bit Vista and that was to use the /FORCE switch. :party: Apparently this is what XP 64-bit users need to do.
Google does warn that by forcing the install that the app may or may not work properly - thus far I've experienced no ill side effects :huh:
    Intel Centrino Core 2 Duo
    250 GB SATA-II 7200 RPM
What is the downside to have this indexing disabled. A slower search or incomplete search?
Hello Tabu, and welcome to Vista Forums.
The downside is that the search will take a bit longer to do since it is searching everything instead of just the indexed files. However, your search results will be accurate now instead of waiting on the index to finish updating itself for accurate results.
You're welcome Tabu.
Not sure if it was because of indexing, but whenever I would try to remove an external hard drive, Windows would say that it was in use. Ever since disabling indexing for the partitions on my external, I haven't every gotten an error when unmounting them. Thanks!
    Acer Aspire 5630
    Intel Core 2 Duo T5500 1.66GHz 65nm 667MHz FSB 2MB L2
    Acer Grapevine Intel i945GM Chipset
    2x1GB DDR2 333MHz
    Intel Integrated GMA 950 256MB
    15.4" WXGA Acer CrystalBrite LCD 16ms
    200GB 5400rpm Toshiba MK2035GSS ATA-7, 250GB 7200rpm Maxtor External USB Hard Drive
Sorry if I didn't make it clear, I meant that whenever I would choose to "Safely Remove Hardware" it would say something along the lines of "Windows is currently using the hardware, please try again later" and ever since disabling indexing, I've yet recieved this error message.
    Acer Aspire 5630
    2x1GB DDR2 333MHz
Sorry about that Frank.
It appears that you found out what was tying up your hard drive for it to be "in use". Thank you for posting back your results.
You're welcome DumbHobbit. Especially if you do not do a lot of searches. ;)
I'm a little late to this, but how does one disable the warning when searching in a folder that says, "Your searches might be slow because the index is not running. Click to turn on the index..."
It's not a big deal, but it is a little annoying to have this pop up every time I search.
And please, don't tell me to turn on the index! LOL J/K :geek:
Thanks,
Mic
    Intel Core2 Quad [email protected]
    Gigabyte GA-EP35-DS3L
    4 Gig Kingston SDRAM DDR2 1066 (PC2 8500)
    SAPPHIRE Radeon HD 2600XT
    WD 1 TB
Hello Mic,
LOL, sorry but I do not think that there is any other way that I know of to turn off that message other than to turn on the Index. :(
