IE8 final release today
You do not need to install any ISP crap esp BT.
You do it manually, you think they pack in all that junk for FREE ?
They get paid by the companies to put junk on your PC.
You contradict yourself, it is spying regardless of how you dress it up.
Quoted : it doesn't actually spy on anyone but relays statistical information back to Yahoo! if it does anything : End Quote
If you don't know how to set up Internet and Mail without a gay ISP CD I advise you get an "expert" to do so for you. ;)
I'm having an issue with IE8 I have 32 bit Vista & since installing IE8 it has crashed with every attempt to run it, I cant even uninstall it as its not on the uninstall list.
    HP-Pavilion GX624AA-ABA a6303w
    Intel Pentium Dual CPU E2140 @ 1.60GHz 1.60GHz
    Board: ASUSTeK Computer INC. Benicia 1.01
    2038 Megabytes Installed Memory
    Intel(R) G33/G31 Express Chipset Family [Display adapter]
    HP - Display - HP w2007 Wide LCD Monitor
    16800 by 1050 (60Hz)
    c: (NTFS on drive 0) 349.92 GB 147.17 GB free d: (NTFS on drive 0) 10.16 GB 1.38 GB free
You can find it under installed updates, if you elaborate your difficulties someone I am sure will help.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
I installed IE8 x64 in Vista x64 Ultimate. It broke Agent, my newsgroup viewer. the filters no longer retrieve. Browsing web pages is very slow. I am ready to backup my data and attempt to remove it.
    16GB DDR667
    SAS RAID
I am fairly sure that British Telecom know what they are doing. I haven't contradicted myself either. As I have said, I hardly ever use Explorer, so it doesn't bother me. I don't even know what a 'gay ISP CD' is anyway.
    Maxdata Belnea 0.book 3
I said you possibly do not know what your doing not British Telecom.
And I quoted you above contradicting yourself so don't backtrack now.
Sure BT know fine well n00bs will install the CD and get PC filled with total Junk, and get them paid for the pleasure of doing so. :party:
Hi Guys,just installed IE8 on HP(32) ,no major dramas,had the sidebar problem for a couple of restarts but working OK now.
Main difference/problem is when i was putting on Football Bets(TAB betting site in Australia) the old Window is not refreshed,IE8 just keeps loading new windows/pages over old and i end up with a folder with 13 expired pages. I have never run into this problem with IE7 and have tried altering as many settings as i could but nothing works.Any Ideas???. TIA D.
IE 8 uninstalled easily. Back to IE 7. Everything works now.
    16GB DDR667
    SAS RAID
IE8 Sidebar issue can be fixed by this :
* Close Windows Sidebar. To do so, right-click on the Sidebar icon
in the Notification area and click Exit
* Open an elevated Command Prompt window. To do so, click Start,
click All Programs, click Accessories, right-click Command Prompt, and
then click Run as administrator.
* In the Command Prompt window, type the following and press ENTER:
regsvr32 msxml3.dll
Similarly, run these commands:
regsvr32 scrrun.dll
regsvr32 jscript.dll
If the registration was successful, you'll see the message
DllRegisterServer in <filename> succeeded for each command executed.
Open Windows Sidebar (sidebar.exe) and check if the problem is resolved.
Ok I got IE working I only had to do a complete system restore I had much larger issues before IE8 but now that I did the restore IE8 works fine and now using a lot of helpful hints & tricks from this site my machine is running very good
Previously, I had a mentioned a statement dat 'i've heard that IE8 dusn wrk wit ultimate 64-bit.' A friend told me dat it dint work in his comp. I tried once via yahoo7.com n it said dat my OS dusnt support. I was still adamant. I went 2 microsoft.com n dnlded it frm der. It works perfectly. No probs. at all. Faster dan IE7. But, not as fast as Google Chrome, though...
    HP 6314tx
    Intel C2D 1.73ghz
    2gb
    Nvidia GEFORCE GO 7400 128mb
    Hitachi SATA 160gb
    External Seagate 1TB HDD, Logitech 5.1 speakers
My eyes are bleeding......
IE8 > Firefox, otherwise why would they get so anal about win7 having IE installed!
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Is IE8 that good? Im scared to try it lol I like IE7 atm...IE8 idk hard to explain I just dont like the look rofl...
It has the same feel of IE7 with a few more bells and whistles and it is faster so there is absolutely no reason I could find to not recommend it to you. The only visual difference you will notice is the "add to favorites" tab is gone but can be done from the "favorites" tab in the menu display. The favorties bar which I didn't like and probably the "look" you are talking about can be turned off easily and you have the IE7 look. I was comfortable with the way I accessed my favorites and didn't want that bar at the top so I deselcted it and I have what looks and feels like what I have been used to.
    Amd Athlon X2 6400+ BE
    ASUS Crosshair 590 SLI
    Corsair XMS2 X 4 (8 gigs)
    Nvidia 8800 GTS 512 G92(SLI'd)
    Soundmax
    Samsung Syncmaster 2053BW 20"
    1680X1050
    WD 320, WD 500
    Thermaltake Toughpower 850 watt
    Raidmax Smilodon
    Air cooled,5 case fans
    Logitech MX400
    Microsoft
    16mbps
Same problems for me with IE8 (Ultimate x64) in that it keeps crashing not only my sidebar but other programs too e.g GRID, Crysis and Windows Explorer. Tried running the commands (as admin) but still crashing :( Uninstalled IE8 and all was well again. Reinstalled IE8 and sidebar and other programs start crashing again. All this after a full format and OS reinstall :mad:
IE8 is not right Microsoft!
    [email protected]
    Asus Maximus Formula II
    8GB OCZ Platinum
    Asus GTX295
    Xonar D2X
    26" iiyama ProLite
    1920x1200
    3x Seagate Barracudas (2TB)
    Corsair TX750
    Antec 1200
    Logitech MX Revolution
    Logitech G15
Well, at least IE 8 is relatively reliable. I recently downloaded Safari 4 for Windows. It will freeze & crash at least 50% of the time in certain Yahoo! links. Everywhere else it seems fine though. It has frozen a couple of times in slow forums. No change there from Safari 3 then! I suppose by the time the bug fixes fix the problem it will have slowed it down to a crawl again. I'd rather have a slow browser that worked properly than a light-speed one that crashes or freezes occasionally! :mad:
It's not reliable for me, It crashes not just the sidebar but other programs too. Even it's own tabbed browsing has issues where IE7's was fine.
    [email protected]
    8GB OCZ Platinum
    Asus GTX295
    Xonar D2X
    26" iiyama ProLite
    1920x1200
    Corsair TX750
    Antec 1200
    Logitech G15
