IE8 final release today
For those of you with Vista x64 who have sidebar probs after installing IE8 ...
Open the run box and run the following three commands and your sidebar will then run properly on reboot.
regsvr32 msxml3.dll
regsvr32 scrrun.dll
regsvr32 jscript.dll
That did the trick! MY SIDEBAR IS BACK!! Thank you sir. I was getting ready to uninstall Flash10 like a previous post said but glad I read this first since I have had flash 10 installed for a couple weeks now with no problems. If you are having sidebar issues after installing IE8 run those 3 commands and wallah fixed.
    Amd Athlon X2 6400+ BE
    ASUS Crosshair 590 SLI
    Corsair XMS2 X 4 (8 gigs)
    Nvidia 8800 GTS 512 G92(SLI'd)
    Soundmax
    Samsung Syncmaster 2053BW 20"
    1680X1050
    WD 320, WD 500
    Thermaltake Toughpower 850 watt
    Raidmax Smilodon
    Air cooled,5 case fans
    Logitech MX400
    Microsoft
    16mbps
regsvr32 msxml3.dll
regsvr32 scrrun.dll
does rhis work for 32 bit Vista amd and analog clock problem?
regsvr32 msxml3.dll
regsvr32 scrrun.dll
Reinstqlled IE8--ran from run-errors-ran from elevated command prop-worked, but did not fix analog clock problem--Going to uninstall IE 8 again--Please post if anyone has fix for this in 32 bit vista
I have Vista HP & my version of IE 7 has a Yahoo tool bar which was part of the BT Yahoo! package. Will I have to uninstall the tool bar for the IE 8 upgrade?
    Maxdata Belnea 0.book 3
I have No idea? try install and see you can uninstall IE 8 and it will go back to IE7---I have done this now three times with out problems die to the uninstall.
OK thanks. I am not sure if I will bother upgrading to IE 8 to be honest. I tend to use SeaMonkey & Firefox most of the time.
so many browsers out there. i use safari and ie.. like the new safari its good will try out that seamonkey to ty for the link
  • Memory
    c:250GB
    4mbit adsl
There are 3 updaets for Ie8 ....right after you installed IE8 run Wds auto update immediately ....see if it fixes the side bar problem..and other problems...
    S-Vaio FZ
    Intel Core2duo T7100-1.8GHz
    DDR2-2GB-PC2.5300-Sp.667MHz
    Mobile Intel Graphics Media Accelerator X3100-358MBvideo ram
    200GB/7200Rpm/Serial ATA
Follow up to my last post:
IE8 borks the Vista Sidebar. Rebooting only resulted in the sidebar crashing upon reboot without even opening IE at all. Did they even run IE8 on a Vista system with the sidebar active?? I mean how do things like this get past beta testing?
Running IE8 with a sidebar on Vista Ultiamte 64 fine....
After the fix posted in this thread I'm good to go now. I was curious and did a search on this issue and found posts from mid December (2008) that IE8 RC1 was causing sidebar crashes back then. My question now is how did this problem still exist in the final release version released 4 months later? I tried the RC1 version and had no issues with the sidebar...odd.
Again I will say IE8 is sweet with lots of nice bells and whistles so if you have no issue with sidebar your golden, if you do have problems find the fix in this post and then you will also be golden.
    Soundmax
    1680X1050
    WD 320, WD 500
    Raidmax Smilodon
    Logitech MX400
    Microsoft
    16mbps
IE8 and the sidebar are working fine for me.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Microsoft seems to be in a browser race because IE7 on Vista 64 isn't stable and lagging and IE8 is released already? I smell disaster already.
    i7 965
    Asus Rampage II Extreme
    Corsair TR3X6G1333C9 x 2
    Gigabyte GTX295 SLI
    SB X-Fi MB
    Samsung Syncmaster T240
    1900x1200
    2x1TB Western Digital Black (Raid 0), 150GB WD Raptor
    1200W Thermaltake Toughpower
    Lian Li PC80P
    Chassis - 3 Front 140mm, Top 140mm, Rear 140mm
    Logitech MX Revolution
    Fold up beast by me :-)
