bsod need help system service error
If you have a dual channel, you must have even number of ram sticks.
In addition, in case you were not aware. Always buy all the ram at the same time, dont mix and match, even if you are told that its ok.
ty, i went ahead and purchased 16gb 4x4 of gskill ddr3 pcs-1600
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    hp 27 inch 1080p and gateway 23 inch 1080p
    western digital 1tb
    stock 250watt
    stock
    stock
    logitech k320 wireless
    comcast cable 20meg
I think that you will be happy with the results.
also do you do any peer to peer sharing? if so can you recomend a good scanner or such to scan torrents before the download begins?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
i thought i had it licked but i just tried a microsoft security scan and as soon as i clicked scan bam i got the bsod
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Post the file
here is the latest dump
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
STOP 0x0000003B: SYSTEM_SERVICE_EXCEPTION
Usual causes: System service, Device driver, graphics driver, ?memory
Code:
icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Windows_NT6_BSOD_jcgriff2 (1).zip\Windows_NT6_BSOD_jcgriff2\100511-16957-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16841.amd64fre.win7_gdr.110622-1503
Machine Name:
Kernel base = 0xfffff800`02a1e000 PsLoadedModuleList = 0xfffff800`02c5be70
Debug session time: Wed Oct  5 15:41:40.544 2011 (GMT-4)
System Uptime: 0 days 4:10:39.980
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 3B, {c0000005, fffff80002d67db7, fffff880081221d0, 0}
Probably caused by : ntkrnlmp.exe ( nt!NtQueryKey+7 )
Followup: MachineOwner
3: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002d67db7, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff880081221d0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!NtQueryKey+7
fffff800`02d67db7 49897318        mov     qword ptr [r11+18h],rsi
CONTEXT:  fffff880081221d0 -- (.cxr 0xfffff880081221d0)
rax=0000000004c7e058 rbx=fffffa8006769060 rcx=00000000000007c0
rdx=0000000000000007 rsi=0000000004c7dfe8 rdi=fffff88008122bc8
rip=fffff80002d67db7 rsp=fffff88008122ba8 rbp=fffff88008122ca0
 r8=0000000004c7e048  r9=0000000000000004 r10=fffff80002d67db0
r11=fffff88008122ba8 r12=0000000004c7e128 r13=0000000004c7e118
r14=0000000000000000 r15=0000000004c7e3b0
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010246
nt!NtQueryKey+0x7:
fffff800`02d67db7 49897318        mov     qword ptr [r11+18h],rsi ds:002b:fffff880`08122bc0=0000000000000000
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x3B
PROCESS_NAME:  MsMpEng.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002a8d813 to fffff80002d67db7
STACK_TEXT:
fffff880`08122ba8 fffff800`02a8d813 : fffffa80`06769060 00000000`0000002c 00000000`00000000 00000000`00000000 : nt!NtQueryKey+0x7
fffff880`08122bb0 00000000`779af81a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`04c7dfc8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x779af81a
FOLLOWUP_IP:
nt!NtQueryKey+7
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!NtQueryKey+7
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aa44
STACK_COMMAND:  .cxr 0xfffff880081221d0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!NtQueryKey+7
3: kd> lmtsmn
start             end                 module name
fffff880`00f36000 fffff880`00f8d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02a00000 fffff880`02a89000   afd      afd.sys      Sun Apr 24 22:43:58 2011 (4DB4DFEE)
fffff880`0468c000 fffff880`046a2000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`039de000 fffff880`039f3000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00dea000 fffff880`00df5000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00e71000 fffff880`00e7a000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00db0000 fffff880`00dda000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`046af000 fffff880`04d7a000   atikmdag atikmdag.sys Tue May 11 21:40:21 2010 (4BEA0705)
fffff880`03e62000 fffff880`03e9d000   atikmpag atikmpag.sys Tue May 11 21:24:19 2010 (4BEA0343)
fffff960`00800000 fffff960`00861000   ATMFD    ATMFD.DLL    Fri Feb 18 23:13:38 2011 (4D5F4372)
fffff880`02b27000 fffff880`02b2e000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`039cd000 fffff880`039de000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03b23000 fffff880`03b41000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`00770000 fffff960`00797000   cdd      cdd.dll      unavailable (00000000)
fffff880`02ac3000 fffff880`02aed000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd6000 fffff880`00d96000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01000000 fffff880`01030000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c78000 fffff880`00cd6000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01345000 fffff880`013b8000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0467c000 fffff880`0468c000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0245e000 fffff880`0246c000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03800000 fffff880`03883000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`039af000 fffff880`039cd000   dfsc     dfsc.sys     Tue Apr 26 22:57:39 2011 (4DB78623)
fffff880`039a0000 fffff880`039af000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`013d3000 fffff880`013e9000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0403d000 fffff880`0405f000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02487000 fffff880`02493000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0249e000 fffff880`024b1000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`02493000 fffff880`0249e000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04065000 fffff880`04071000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03e9d000 fffff880`03f91000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04d7a000 fffff880`04dc0000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`01043000 fffff880`01057000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013c9000 fffff880`013d3000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0128f000 fffff880`012c9000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01590000 fffff880`015da000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ffa000 fffff800`03043000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04dc0000 fffff880`04de4000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0418c000 fffff880`041e8000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`024bf000 fffff880`024d8000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`024d8000 fffff880`024e0080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`024b1000 fffff880`024bf000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`03a5b000 fffff880`03b23000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01286000 fffff880`0128f000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`040a8000 fffff880`040b7000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`024fe000 fffff880`0250c000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bc3000 fffff800`00bcd000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`040c8000 fffff880`0410b000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`0132b000 fffff880`01345000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01565000 fffff880`01590000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0405f000 fffff880`04064200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0256b000 fffff880`02580000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`02527000 fffff880`0254a000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`03a49000 fffff880`03a53000   mbam     mbam.sys     Tue Aug 02 10:47:45 2011 (4E380E11)
fffff880`00c57000 fffff880`00c64000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`02519000 fffff880`02527000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`040b7000 fffff880`040c6000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0250c000 fffff880`02519000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d96000 fffff880`00db0000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02aed000 fffff880`02b1e000   MpFilter MpFilter.sys Wed Apr 06 16:07:29 2011 (4D9CC801)
fffff880`05c95000 fffff880`05ca5000   MpNWMon  MpNWMon.sys  Wed Apr 06 16:07:23 2011 (4D9CC7FB)
fffff880`03b41000 fffff880`03b59000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03b59000 fffff880`03b86000   mrxsmb   mrxsmb.sys   Tue May 03 22:51:06 2011 (4DC0BF1A)
fffff880`03b86000 fffff880`03bd4000   mrxsmb10 mrxsmb10.sys Fri Jul 08 22:44:55 2011 (4E17C0A7)
fffff880`03bd4000 fffff880`03bf7000   mrxsmb20 mrxsmb20.sys Tue May 03 22:51:05 2011 (4DC0BF19)
fffff880`00ff5000 fffff880`01000000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02b8c000 fffff880`02b97000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f96000 fffff880`00fa0000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`012cd000 fffff880`0132b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03995000 fffff880`039a0000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01400000 fffff880`01412000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01413000 fffff880`01505000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`046a2000 fffff880`046ae000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`03e24000 fffff880`03e53000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04177000 fffff880`0418c000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`038fa000 fffff880`03909000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03886000 fffff880`038cb000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01505000 fffff880`01565000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`03a00000 fffff880`03a18000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 16:08:53 2011 (4D9CC855)
fffff880`02b97000 fffff880`02ba8000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03989000 fffff880`03995000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a1e000 fffff800`02ffa000   nt       ntkrnlmp.exe Wed Jun 22 22:51:48 2011 (4E02AA44)
fffff880`01057000 fffff880`011fa000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02b1e000 fffff880`02b27000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`038d4000 fffff880`038fa000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fe0000 fffff880`00ff5000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00fa0000 fffff880`00fd3000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00dda000 fffff880`00dea000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013b8000 fffff880`013c9000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`05ca5000 fffff880`05d4b000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04000000 fffff880`0403d000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c64000 fffff880`00c78000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03e00000 fffff880`03e24000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04de4000 fffff880`04dff000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`02bd3000 fffff880`02bf4000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04083000 fffff880`0409d000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03938000 fffff880`03989000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0409d000 fffff880`040a8000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02b71000 fffff880`02b7a000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b7a000 fffff880`02b83000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b83000 fffff880`02b8c000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0124c000 fffff880`01286000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02580000 fffff880`02598000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04600000 fffff880`04657000   Rt64win7 Rt64win7.sys Thu Mar 04 08:42:52 2010 (4B8FB8DC)
fffff880`05d4b000 fffff880`05d56000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`015f2000 fffff880`015fc000   speedfan speedfan.sys Fri Mar 18 12:08:46 2011 (4D83838E)
fffff880`015ea000 fffff880`015f2000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`05c00000 fffff880`05c95000   srv      srv.sys      Thu Apr 28 23:13:05 2011 (4DBA2CC1)
fffff880`05d95000 fffff880`05dfc000   srv2     srv2.sys     Thu Apr 28 23:12:51 2011 (4DBA2CB3)
fffff880`05d56000 fffff880`05d83000   srvnet   srvnet.sys   Thu Apr 28 23:12:35 2011 (4DBA2CA3)
fffff880`040c6000 fffff880`040c7480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jun 20 23:44:55 2011 (4E0013B7)
fffff880`05d83000 fffff880`05d95000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02bc6000 fffff880`02bd3000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02ba8000 fffff880`02bc6000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03924000 fffff880`03938000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02a89000 fffff880`02aaf000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0410b000 fffff880`0411d000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0243f000 fffff880`0245c000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`0245c000 fffff880`0245df00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04662000 fffff880`04673000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0411d000 fffff880`04177000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04657000 fffff880`04662000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`03f91000 fffff880`03fe7000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`024f2000 fffff880`024fe000   usbprint usbprint.sys Mon Jul 13 20:38:18 2009 (4A5BD37A)
fffff880`024e1000 fffff880`024f2000   usbscan  usbscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`0246c000 fffff880`02487000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00fd3000 fffff880`00fe0000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02b2e000 fffff880`02b3c000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02b3c000 fffff880`02b61000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015da000 fffff880`015ea000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01200000 fffff880`0124c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03909000 fffff880`03924000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02b61000 fffff880`02b71000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e83000 fffff880`00f27000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f27000 fffff880`00f36000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`038cb000 fffff880`038d4000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d2000   win32k   win32k.sys   Fri Jun 10 22:56:14 2011 (4DF2D94E)
fffff880`04673000 fffff880`0467c000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f8d000 fffff880`00f96000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0254a000 fffff880`0256b000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`03a18000 fffff880`03a49000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`086e6000 fffff880`08757000   spsys.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
fffff880`013e9000 fffff880`013f7000   crashdmp.sys
    Checksum:  00000000
fffff880`01030000 fffff880`0103c000   dump_pciidex
    Checksum:  00000000
fffff880`00c4c000 fffff880`00c57000   dump_msahci.
    Checksum:  00000000
fffff880`02ab0000 fffff880`02ac3000   dump_dumpfve
    Checksum:  00000000
This is what I see when I examine your files. The last few were consistent. So the cause are one of the reasons shown above.
We will assume that you did the memory test correctly so that leaves a driver pt system services (OSservices that load with boot)
We will determine the cause. Lets assume that the memory test was done correctly. Take the verifier test, again, for 36 hours. At the end of 36 hours give me the dump reports. We will then go from there. I read your first post, again, if a clean install did not solve the problem, it points to a hardware problem.
Go to the website and update your graphics driver.
well i didnt have a actual windows 7 disk since i never made the restore disks and they havent arrived yet i burned a iso image from pirate bay so it might of been a corruput copy
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
We are not allowed to go any further if Seven or Vista is not legal
windows 7 is legal now iam only saying before i downloaded a iso of 7 then after i recieved my disks i loaded them so it is legal now i can send you a screen shot of the system info if you want i was just saying at one point in this computers life i did that but it was earlier,still run the verifier and send you the log?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
So that no rules are broken can you take a screen shot of the Microsoft Validation Sticker?
Go to computer icon on desktop, go to properties. Bottom right.
this is what you want correct?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Im sorry for that my friend, but we, at the Forum want to maintain a good reputation. TY for the screen shot.
its quite alright bud i understand i would of asked the same thing,now when i run the verifier you said to run it for 36 hours i know ill get a bsod in 36 hours if i keep loading the instaler after each bsod will it all stay in the log or do i just let the verifier go till i get a bsod then download the log and send it to you?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Send them all at once. Before you use the verifier update your graphics driver by going to the website of the grapahics card.
the verifier has been running for almost 4 hours with no bsod should i leave it run or should i change it and tick the low resource simulation?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Just keep it running for now. It should BSOD. The verifier stresses out the drivers.
ot a weird one for you i have a logitech wireless keyboard and mouse with a usb adapter i just changed the batteries yesterday i updated the drivers today and if i have the usb dongle pluged in the usb port on the back of the computer the keyboard and mouse sometimes dont respond ,sometimes when they do respond it is very slugish,and sometimes it works like a charm now i have tried this on another pc and it works great i have tried pluging the dongle into the usb port on the front of the computer and it acts the same as the back, am i over thinkin or is that a sign the motherboard is going to sh*t since the usb doesnt respond? however i do have a lexmark printer connected to the back usb ports and that always works
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
its got so bad that i can't even finish the dump log before i get the bsod i've tried in windows safe mode neither will let me finish i've tried almost 15 times i've even turn the verifier off and tried in windows and in safe mode any ideas
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
