Wow long thread. my take from a hardware side.
Memtest should be run in excess of 24hrs for a difinitive answer.
You claim only a 250W psu.. which is bare minimum and the stock is crap quality. Its very possible it has degraded to a point where it is not able to properly power your system and so its screwing up and bsoding.
I would not put 16gigs into your system, it is going to be very hard on your memory controllers and require more voltages on a bunch of settings. 8 would be your most needed.
Switch up your mobo and the oem disk is a grey area, as you put a non hp mobo in.
I'd switch the power supply and see how it goes.
- Dual L5639 // i7 950 @ 4.0Ghz
- Evga SR-2 // Gigabyte x58a-ud3r
- 12Gig Corsair XMS3 // 6Gig OCZ Gold
- gtx 560 ti // gtx 260-216
- Dual 22" // Headless
- OCZ aGILITY 3, 120Gig + Seagate 500Gig x 2
- PSU
- Silverstone da700 // Corsair 520hx
- Case
- Rosewill BlackHawk Ultra // Antec 900v1
- Cooling
- Twin CM Hyper 212+ // Noctua NH-u12
- Other Info
- Acer 8930 laptop with x9100...
