bsod need help system service error
so iam thinking about replacing parts i just ordered a foxconn motherboard vlr triple heat pips cpu cool some artic 5 thermal paste and a 500 watt power supply do you think if i replace all of that the rest of the components should be fine? i was also planning on placing a fan or 2 in the case since prebuilt factory pc's are known for piddle poor cooling would the ram,hard drive,and cpu be fine you think? i mean since we did all that memtest on the ram the hard drive has had the clean install of windows and the cpu had the prime with no errors
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    hp 27 inch 1080p and gateway 23 inch 1080p
    western digital 1tb
    stock 250watt
    stock
    stock
    logitech k320 wireless
    comcast cable 20meg
iii
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
I really find it difficult to tell you what you should buy. YOu are there and see the results of the testing. I dont want to tell you to buy something and then it does not solve the problem.
I dont want to tell you what to buy or if it will work, but I will say that you are changing the most likely components.
ok i uderstand your position, i had one last thought when i bought the computer with the installed windows 7 everything worked fine for almost 2 years then the hard drive crashed so i had to replace the hard drive with a new 1tb and when replaced the windows 7 coa would not work to activate so i used a windows 7 disc i had and created a keyjen to activate now i know hp's are very hardware specific and the included operating system doesnt like to activate on hardware that did not ship with the pc so i did order a new copy of the backup cds from hp once i load them is it possible or likely that they will fix the issue since they will have all the needed drivers? also how does that work will the restore cd's ordered come with the activation key? basicly what iam asking is will the restore cd's that i ordered from hp give me a legal operating system that shiped with the computer?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
You can use the OS that came with the computer only on one computer. Its called and OEM. The defintion of a new computer is a new MBoard, so sorry, no.
so if i wait till i recieve the restore disks and install them using the factory motherboard it will work correct? do you think loading the factory defaults from the recovery disk's will fix the issue?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
If you install on the origianal MB it should work. The restore discs will work only if it is not a hardware issue and Im think that it may be.
i guess we shall find out when the disks arrive,i am currently running malware again not in safe mode and even after i fixed the 2 trojans it found the first time now it has found 4 more threats and its not done running,would you still lean twoards hardware issue or maybe its the malware?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
I can tell you for a fact that malware and virus can cause those problems.
what do you think of them boot all fix regestry errors virus ect cd's on ebay for like 10 bucks? are they a waste of time and money?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
is there anything i should do about that error i got about device manager stopped working
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Most here agree, dont get them. They usually do more harm than good.
There are two ways to fix the registry; a system restore or if you backed up the registry.
my though's also but your more computer savy than me just thought id ask thanks so much for your help thus far if you do have any ideas of more things to try please feel free to share and i shall keep the forum updated on my progress
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
i found 2 things that might be of help for others with the bsod after letting my pc run in bios for 1 hour the cpu temp got criticaly hot under almost no load (the temps in bios varied greatly from the temps in speed fan) and the second thing i found was after visiting my hard drives manufacture's site and downloading there free disk check utility my hard disk has sever platter issues and is also running hotter than normal
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
Your problem may be due to overheating
i've believe i have niped the bsod in the but, the culpret was adobe flash player 11 it seems to have a bug in it (i don't want to acuse since i can not prove) all i did was roll back the driver to a earlier version and presto no more bsod,after rolling the driver back ive monitored cpu temps there back to normal range along with the gpu even under load,i also uninstalled chrome and installed the latest version not, but that being said i could not have done this without the help of the MAN Richard thanks a million bud your a true asset to this forum
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
TY for your very kind words, but it seems that you solved the problem by finding the driver that was the problem.
but i would not of know were to look without all of your wonderful test for memory and cpu and verifier i never even knew the verifier existed, thank you for the credit but i must step aside as i was only the student following the teachers instructions
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
I thank you for your very kind words. Come back any time with questions or just to learn.
well i do have one question i think i got the answer well in my mind just want to see if you'll confirm it i was thinking of upgrading the ram in my hp and i got 3 sticks of crucial 2 gigs a stick new in package but since there are 4 dimms on the motherboard wouldnt 3 sticks of ram being the odd number of dimm's rever it back to single channel memory?
    hp 6649c
    amd x4 635 2.9
    stock
    4 gigs ddr3
    integrated
    integrated
    western digital 1tb
    stock 250watt
    stock
    stock
    comcast cable 20meg
