Bluescreen help urgently required
It finally gets there with the following messages:
IAAnotif.exe - Application Error
The instruction at 0x1000f183 referenced memory at 0x00000004. The memory could not be read.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program:...ommon Files\Roxio Shared|9.0\SHaredCOM\RoxWatchTray9.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the applications support team for more information.
AML has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available
Clicked Ok and got explorer.exe - Application Error
The instruction at 0x6f2d5505 referenced memory at 0x00000000. The memory could not be written.
Click OK to terminate program
Clicked Ok
wf_tp.exe - Application Error
The exception unknown software exception (0x0eedfade) occurred in the application at location 0x7626fbae
Clicked Ok and got the explorer.exe application error message again
BT Tray
Error:Unable to start the bluetooth stack service
Exception EoleSysError in module wf_tp.exe at 007EE65
The RPC server is unavailable
And now the Explorer.exe message is constantly reappearing. Can't seem to get rid of it
Arty, sorry, but I think you're screwed.
All I can suggest is a clean install of Vista, which, of course, means reinstalling all of your other programs as well.
It's going to be difficult, I know, but try to backup up any data/files that are important to you.
If you have any problems/questions, let us know.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
This is not what I really wanted to hear. I have so many work related files on the laptop. I am an architect and there are thousands of drawing files on it. What do you reckon happened here?
If you really, really want, I will re-read this thread and we will try to go back to the basics, but realistically the only easy way to solve this problem would be a Clean Install, as Ed has said. We do not really have any leads except for networking, and I would suggest backing up everything in Safe Mode, even though it is all dumped into C:\Windows.OLD. Your current situation is dire, and I don't know that fixing would be possible, and certainly it would be beyond difficult.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
It could be a dead hard disk, so run some Hard Disk checking tools after you are back online (or now) Seatools for Windows is my favourite. You can back up all your files in Safe Mode (DO THIS!) even though it should be dumped into Windows.OLD. If you format your hard Disk, this will not happen, and often it goes wrong, so put no faith in this. I will need to quitely re-read this thread, as it has moved so fast that none of us have kept up. Booting into Safe mode is a good sign, and from this point we often fix, but your Safe Mode with Networking is not good and things do not look good here. Even if you don't reinstall now, do backup now, as your situation may deteriorate drastically, and we don't want to have to do post-mortem data recovery.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
If you have your data files on a separate partition, then reinstalling won't affect them
If they're on the same partition as Vista, then make sure you don't format the drive as part of the install; again, your data files shouldn't be affected.
But you're always safest if you can back them up beforehand, just in case...
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Thanks guys for your assistance in this problem. I have given up and got a man in to sort it out. £40.00 to back up data and reinstall vista then reinstall data.
Geez, I would've done it for 30 pounds if you'd covered the airfare... :geek:
Good luck,
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Hmm. But would you have got here if you had to fly through volcanic ash?????!!!!!!!!!
Well I would not have had to fly, I already live in England. I don't know if you even live in England, but my family and I drive hundreds (often over one to two thousand) miles every year, all across Europe to wherever we have booked our holiday, just for one holiday. We take it in 5 1/2 hour shifts and every 24 hours take a break. Pricing: £20 + Fuel :)
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
