Bluescreen help urgently required
We'll look at the NVidia driver problem once we get your boot problem fixed.
By the way, the SysInfo file says it was taken at 17:31 today. You need to fix your system clock before anything else.
Ed
LOL! I know this is not very helpful, but I looked at this post just at 17:31 (today)!
EDIT: 17:32 now :(
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Upload the minidump file from C:\windows\minidump.
You tried Startup repair?
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
"LOL! I know this is not very helpful, but I looked at this post just at 17:31 (today)!
EDIT: 17:32 now :("
Where the hell are you, Hawaii?
Oops, that's wrong direction, isn't it? :D
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Only in England!
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Yes, Startup Repair has been done loads of times. You want the latest minidump files again?
Oh yes.... in Weson-super-Mare!!! Birthplace of the great Mr John Cleese.
Yep, the latest minidump. And don't kill any parrots...
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Got this message:
Logon process has failed to create the security options dialog.
X Failure - Security Options
clicked this away and back to blue screen
Still waiting.... hard disc led flashing on and off so I assume something is happening
Hello,
Can you access Safe Mode consistently?
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
We're getting above my pay grade here, niemiro, and, besides, my head hurts!
I'll leave it in your capable hands for now; almost martini time...
Ed
    Home Grown Desktop
    ASUS P5B-E
    3006 MB
    Antec Sonata
    Logitech LX710
Just booted normal, desktop there but got this message:
VESMgrSub.exe - Corrupt File
The file or directory C:\WIndows\System32\spool is corrupt and unreadable. Please run the Chkdsk utility
If I do this then I could revert back to BSoD. This is the closest I have been to a proper boot. What do you suggest now?
The HD LED is flashing still and I can hear the HD is spinning
Network connection is local only. No internet.
For some reason Windows is trying to configure Adobe Acrobat 8.1.3 Standard but now the following message has appeared:
Error 1317. An error occurred while attempting to create the directory C:\Windows\system32\spool\Drivers
When I use explorer to go to that directory, I get:
Location is not available
C:\Windows\System32\spool is not accessible.
The file or directory is corrupted and unreadable
Would renaming this folder and creating a new spool folder be any use?
Network problems now. Intermittent connection and stops working when trying to use Outlook or IE
It says there might be a problem with one or more network adapters on this computer
Another day..... and a little progress. I have managed to get an internet connection by disabling the MS ISATAP adapter that was causing a problem - Error 31. However, I cannot use MS Outlook as every time I try to launch it, Internet Exporer says it has stopped working, closes down and restarts. And now everything has frozen, except the cursor. Black screen. Error message "logon has failed to create the security options dialog" "Failure-Security Options" CLicked OK and now got IE up but not responding. Cntrl Alt Del not working. May have to shut down with the start button........ Bugger. May not get booted in normal again for a while.
Rebooted nearly an hour ago and decided to let the laptop do a System repair. It has tried to restart, but is now a blank blue screen with occasional flickers from HD LED
