Thank You Rich, I was able to update the driver from NVIDIA. This following is leading into a question.
The driver I had was 7.15.11.7521 and I updated from the mfg. site to 8.17.12.6099. After I installed the driver WINDOWS UPDATE shows a driver update which was older that the one I got from the mfg. site. It failed to install and the error code said it was proability due to the fact that I had a newer version already installed.
I down loaded a program from Pit Stop that ran a scan and showed me all outdated drivers and I could update them them for a fee.
Is there a free program like this?
If so should I install it or just use the windows update which I tried and it was showing "you have the latest driver etc."
Thank you for your response.![Confused :confused: :confused:](/images/smilies/009.png)
- H P Pavilion s3120n
- AMD Athlon 64X2 Dual Core Processor 4200+ 2.20GHz
- M2Nc51-AR
- Ram 2.0 GB
- NVIDIA GeForce 6150 LE Graphis
- Realtex
- ViewSonic VX2035WM
- 1680X1050 pixels
- 320GB 7200RPM Serial ATA
- PSU
- AC Bel Model#PC6012
- Cooling
- fan
- PS2
- PS2
- 10 down 1 up
- Other Info
- Computer has had the motherboard, power pak and tv tuner replaced. Using HP Deskjet F440 Printer, and IE9.
