BCCode f4 BSOD's with wininit.exe
Now that I've read a lot more, I'm leaning towards a problem with my mobo and RAID0 from Gigabyte/AMD. My mobo is the same from this other post with lots of scary stories: AMD Game Forums - RAIDXpert 'Unknown Error'
    AMD Phenom II X4 970
    Gigabyte GA-890GPA-UD3H
    Kingston HyperX 8GB (4x2GB) -- 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model KHX1333C
    AMD Radeon HD 6850
    integrated
    Samsung SyncMaster PX2370 + Samsung SyncMaster 710N
    Main: AMD 2+0 Stripe/RAID0 (2 x SAMSUNG Spinpoint F3 HD103SJ 1TB) SAMSUNG SP2504C 250GB (left over) WDC WD800BB 75GB (left over with Win XP)
well completed all the ram and ram slot tests as instructed and no errors, so now can only wait and see...it is possible it may have been AVG but its also possible it may have simple been my usb flashdrive being used as a ready boost beginning to fail as not designed to be constantly used as ram....time will tell now
    ACPI x64-based PC
    Intel(R) Core (TN)2 Duo CPU E8400 @ 3.00GHz
    Asus P5N-D Motherboard
    4.00 GB
    Nvidia GeForce GTX 285
    Hitachi HDP725025GLA SCSI
Take your time, just enjoy the comuputer. If the problem persists, just post.
well been almost 2 weeks now and no sign of the BSOD, so removing avg and the usb stick must have fixed the issue, no idea which action actually did it tho lol. but all is good now (touch wood)..thanks again for all your help Rich...kudos to you
    ACPI x64-based PC
    4.00 GB
Your very welcome and I hope that you good luck remains.
