tnx .Joe
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
y1pSGtdzY3S5GRCV-1hSXBBQbmhcfdPYvEtAZCCmm688XBluu2gxjxx24h2XqmOo51dl2txs8I_DNA
    Intel Core2 Duo [email protected]
    Gigabyte GA-P31-DSL
    4 GB A-DATA
    NVIDIA GeForce 8600 GT
    Western Digital Caviar 300 GB
This is my new machine. I'm really proud of this configuration , it's not so affordable here.
y1pUCCbbRn-9synmmtOqYYsBNicXl2OVCjY9q8YUXB-1i40bWL_yHavsfJgzVXXuNVrgalQ_WE58vQ
    Gigabyte GA-P31-DSL
    4 GB A-DATA
What's up with the 5.1 for my 8GB memory?
I had 5.9 before on my ASUS Crosshair, but now 5.1 on my 780i?
Dat sux!
Anybody knows why?
    custom of course...
    Intel Quad Q9650 3.00GHz
    EVGA 790i Ultra 3-way SLi
    1920X1080
    Thermaltake Armor 6000BWS
    ThermalTake MaxOrb CL-P0369
    10 Mb/sec DL - 1 Mb/sec UL
5.7 overall. Hard disk is holding me back. Everything is 5.9, except CPU which is 5.8. I guess you need a quad-core to get 5.9..
~Ibrahim~
    Overdrive PC
    E6600 @ 3.5GHz
    P5N-E SLI
    4GB DDR2
    8800GTS 640MB
    Onboard Realtek ALC883
    Dell SP2008WFP
    WD 640GB (50GB OS/100GB Programs/490GB TV Recordings) Seagate 320GB
    Enermax 620W
    Cooler Master Stacker 830
    6x120mm
    Razer Copperhead
    Gateway OEM
    6Mbps/512kbps
Im new here and thought I would join in the fun of posting scores.
My computer scores the following:
CPU 5.0
Ram 5.5
Graphic 5.9
3d gaming 5.4
hard drive 5.4
I had updated graphic drivers and thus the 3d graphic score went from 5.5 to a 5.4.. I hope they will fix that in the next release of graphic drivers. My computer runs like a dream. Also the ram memory ahs 2gb of my Dell ddr2 533mhz ram, and the other 2gb is the transcend 800mhz ram that a friend of mine is letting me borrow for a while :)
My computer specs are:
Dell XPS Dimension 410/9200 (DXP061)
Intel Core 2 Duo E6300 @ 1.86ghz
4gb DDR2 SDRAM
512mb ATI Radeon X2600XT
2x250gb Harddrives
Windows Vista Home Premium 64bit
L.
I have just updated my bios to the latest version and my score went from 5.6 to 5.7:D
The processor is running slightly faster and the ram is what got the higher score.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Here is my WEI score. This is also my first post in the forums. :geek:
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Here's my WEI. Dwarf or someone else, what's the shared system memory? 'Cause it's dragging my whole memory score down...:p
Nice systems everyone...:eek::p
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Hi amplid,
There are several reasons why your score is low. The first is the amount of memory in your machine. If you increase it to 2GB you should find that the subscore for your RAM should go up, although probably not by very much. As you have a 64-bit version of Vista, I would recommend that you increase this still further, to 4GB (or more, if your motherboard supports it). Where it will have an impact is with your graphics. Vista appears to allocate a memory space for graphics that is equivalent to half your RAM. This includes the amount of memory on the graphics card itself, so for a system that has a total RAM of 1GB (1024MB) and a graphics card with 256MB of on-board RAM that equates to a shared system memory of (1024/2)-256=256MB. The total graphics memory is therefore 512MB. The shared memory supplements the graphics memory, and is only used when required. Another limiting factor is your driver. You are using version 163.69. The current WHQL version is 169.25. Finally, your graphics card itself. This is quite an old model, and is in itself dragging your score down. To improve your score, I recommend that you replace your graphics card. My current card is a 7600GT and this, together with the 2GB of RAM that I have installed, gives me the figures in my previous post. Note that your score will not increase above 4.5 as that is the lowest score apart from your graphics scores. The only way to increase this would be to upgrade your processor.
Dwarf
    Gigabyte IF233
Hey Brink
You got your card !!! :cool: COOL
Keep it up.
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Thanks Ted.
Yeah, I couldn't see spending the amount they want on the new 9800's when they come out, from what I seen of their projected costs, for what I needed.
Yeah Brink Your kind of like me you want a good
card but you're not really a *gamer* but you want
to be able to maybe run a couple monitors and a HDTV
connection. You got a good card. I have been checking
them out, not bad for 50 over the 8600 I was looking at.
Because I'm going to get something here in a couple weeks.
Good deal buddy.
Later Ted :shock:
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Thanks dwarf for the advice so far. I am indeed planning to replace my RAM memory. About the driver, a program told me that my audio card, system management and GeForce 6600 drivers were out of date, but when I went to my device screen in the CP, it said that all of my drivers where uptodate... Weird...:p
Thanks
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Ah ok, now it worked. Why does Vista give you wrong info like that?:p
And another question, the driver for my NVIDIA nforce PCI system management is outofdate too, but I don't know which driver to choose from the drivers on NVIDIA's site.
Thanks Brink!!;)
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
