Why SP1 may not be available for you and how to get it
Already on the case, but this isnt just happening with the ASUS M2N-E Sli, its happening on a lot of systems with different hardware, the only 2 common items are 8000 series Nvidia graphics and Windows vista. Happens on more than just COD 4 too
Problem signature
Problem Event Name: APPCRASH
Application Name: iw3sp.exe
Application Version: 0.0.0.0
Application Timestamp: 47044075
Fault Module Name: nvd3dum.dll
Fault Module Version: 7.15.11.7519
Fault Module Timestamp: 482e0de8
Exception Code: c0000005
Exception Offset: 001c33f4
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 2057
Additional Information 1: a481
Additional Information 2: 8c8c90dfba46b56992991fedfdd3c75a
Additional Information 3: 691e
Additional Information 4: 76ccca9130c8dbde6fdc80697841a9a1
Extra information about the problem
Bucket ID: 850077102
Which Nvidia driver does Asus recommend for that board and video card? Did you try a earlier driver? Use add/remove the remove it and use the previous version.
    16GB DDR667
    SAS RAID
Actually Vista SP1 does a file integrity check before it installs. If you do not pass that check SP1 will NOT install. It's best to install Vista SP1 first thing after a reformat and BEFORE you get ANY of the Vista updates. SP1 installs most of the Vista updates anyway.
Suggest you guys with problems installing SP-1 do a file integrity check by pulling up the dos prompt as admin, type in sfc /scannow. This will check for missing system files and usually restore any missing sytem files,this should allow SP-1 to install for you.
    E6750
    EVGA 780i
    GSkill PC6400 @ 1000MHZ 4 4 4 12
    280-GTX
    2X250 GB WD
i have windows basic how do i get silverlight? i want aero technology so i can pop my windows in 3d please someone help me.
thank you so much
Hi nunae76 and welcome to Vista Forums :party:
Before I start, a couple of points to note. Firstly, please do not hijack threads. If your topic has no relevance to the thread then start a new one. Secondly, DO NOT post your email address in your post for all to see - this will only lead to you being spammed and there have been occasions where the Admins/Moderators have had to edit a post to remove such addresses. Forum members who wish to reply to you personally can use the PM system available on the forums or, as I am doing, reply in the thread.
Back to your questions. Firstly, silverlight. This should be available for you and you can find a link to it on the main Microsoft Corporation webpage. Secondly, Flip-3D. This feature is NOT available in the basic versions of Vista. To have this feature, you will need to upgrade to either the Premium or Ultimate version.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Hi zeshu34 and welcome to Vista Forums :party:
Yes, the same service pack will work on all versions of Vista. Just be sure to download the correct version from the links in the first post.
    Gigabyte IF233
ok thanks for your help but over there its 32 bit (x86) Vista: what does this (x86)means and I never downloaded any service pack and am using this laptop from 2007 so should I download service pack 1 and is there anything important I need to keep in mind while installing it thanks
Hi zeshu34,
The 32-bit version is the one you require. The x86 actually comes from the model number of the earlier Intel family of processors themselves, namely the 386, 486, 586 (pentium). These were all 32-bit processors, so the term x86 means the same as 32-bit, and is, in some cases, interchangeable.
    Gigabyte IF233
In the interests of upholding the pedantically high standards of accuracy for which this forum is renown, I am obliged to point out that the 80286 was in fact a 16-bit processor :geek:
Thanks for the clarification. :o
    Gigabyte IF233
Hi zeshu34,
The 32-bit version is the one you require. The x86 actually comes from the model number of the earlier Intel family of processors themselves, namely the 286, 386, 486, 586 (pentium). These were all 32-bit processors, so the term x86 means the same as 32-bit, and is, in some cases, interchangeable.
thanks alot mate you are great...
We have 3 siblings laptops, Asus G1Sn running on Vista Home Premium x64. We tried to update one laptop to SP1. The computer died. It ended in the stage 3 of 3 at 88% only full format was available option. Afterwards We searched for the problems and found thousands of cases where SP1 for Vista has killed a PC. I am afraid to install SP on the other 2 laptops. I have found statements that contradict one another such as, you need not to have installed any updates prior to stand alone SP1 and the exact opposite, then the infamous KB937287, some say it causes all the problems during installation others say SP1 cannot go without it. Is there a safe procedure to install the SP1? I don't get to see the SP by the Windows Update so I have to go with the stand alone version, do I need prerequisites? Do i need to install the infamous KB937287?
    T8100
After doing research on this subject and equiping my self with all the prerequisites, I tried to install SP1 on the second laptop. It immediately threw an error with the code 0x8007005, I restarted the computer and tried again only to be stopped by a similar error:0x800f0823.
Somehow I have the feeling that I will need to format this drive as well.. as for the third laptop I won't bother installing any updates.. I'll just go for a new fresh install.
By now I am completely assured that 9 out of 10 computers FAIL to install SP1.
    T8100
Finally, Success! SP1 has installed!
It only took another Format, and now allowing Vista to install any drivers what so ever. straight through all the updates and SP1 went in first time.
So, it would seem the trick is to do like you say... clean install... get SP1 straight away.
My pre-SP1 Vista wouldn't take the SP1 download no matter what!! But I found a solution! I put Windows 7 on!! heh heh
By the time my 14 months runs out hopefully I'll be buying a machine with Windows 7 SP1 preinstalled! ;)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Reading all this from Animazilla I have great sympathy. I am having very similar problems installing SP1 and wonder if you can share your experience to get my laptop updated to SP1 at least.
I have a Dell XPS laptop running Vista Home Premium 32bit, an OEM install by Dell, purchased around 18months ago. I had been running OK and had already installed SP1 via Update fine. But my laoptop started to show memory management issues recently and Dell service engineers concluded it was a software issue not physical memory, and suggested restoring factory intsall from a restore drive copy.
OK - did that. Vista update went about downloading and installing around 80 updates and security releases etc. But after all was done, SP1 did not show up. I cannot install Adobe design Suite without SP1, so Dell support tried all sorts and and the end tried a manual install of SP1. I get the same problem Animalzilla had - gets to the end, the says did not install properly and restored back to preinstall state. No explanation why. This is on my clean delivery state laptop which had once before already happily installed SP1. Why not now? I have lost about two days on this now, and this is a key working machine needed to run my business effectively. I need it back on line asap.
I have restored back to factory delivery state again, and again let update install all updates. Update tells me there is nothing left to update (now at least).
Should I be checking for drivers which may now be out of date? ANy ideas from you experience what I should do?
You should forget about SP1 and concentrate on installing SP2 (which is out now). Service Packs are cumulative - SP2 contains everything SP1 did, plus more.
Thanks for that - I was given the clear impression that I needed to install SP1 beofre attempting SP2. So there seems much confusion about all this. In the end I did in fact manage to get SP1 installed after my second attempt (and re-installing the Dell factory delivery state again). I let update install all available updates (against advice I have read on this forum) and did a manual install. And oddly it only took about 20mins - not the expected 2hours!
So - how do I go about installing SP2 then? Should it appear automatically as an update via updater, or should I look for and perform a manual install again?
