which graphics card to upgrade too?
Its an nvidia nforce 720a.
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
As I said the GTS250 is just the 9800GTX in a new frock, something I learned upon reading the article I linked to.
I think your definition of bottleneck is different than mine. I define it as a limiting factor that in this case would render any video card upgrade useless because the CPU is already maxed out. This I do not agree with, but I would agree that he'd get higher frame rates with a more powerful processor and that the speed of the processor becomes more of an issue the more powerful a card gets. That said I don't agree that 3.2ghz is necessarily the required speed, as there are a number of phenoms and core2 quads that don't hit that mark that would be up to the task. At this point I feel that upgrading from his current video card will yield him higher frame rates than if he kept the same video card and upgraded the CPU, thus I make my recommendation to upgrade the card and not worry about the CPU for now because without the video card upgrade he wouldn't need it anyway.
    AMD Phenom x4 9600 Agena
    Asus M3A-H/HDMI
    8GB OCZ Fatal1ty PC2-6400
    Powercolor Radeon HD4830
    HP W2408h, Gateway VX1100
    1920x1200, 1600x1200
    Maxtor 200GB IDE (x2) WD Caviar SE16 640GB SATA (x2)
    CoolerMaster eXtreme Power Plus 500w
    CoolerMaster ATCS 210
    MS Wireless Mouse for Bluetooth
    MS Wireless Keyboard for Bluetooth
I never said 3.2 ghz was the required speed, I just used it for an example. For a GTS 250, just get to the upper 2 ghz area.
    Intel Core 2 DUO E8400 @ 3.6 ghz (1600 mhz FSB)
    (XFX) NVIDIA nForce 680i LT SLI
    4 GB RAM (Crucial Ballistix 4 x 1 GB DDR2/PC2 6400 @ 960 mhz)
    (EVGA) NVIDIA GeForce GTX 260 C216 - 55nm @ 684/1476/1190
    Creative Sound Blaster Audigy SE 7.1 (PCI)
    Acer X223W
    1680 x 1050
    Western Digital Caviar 320 GB SATA - 7200 RPM 3.0 GB/s
    COOLER MASTER Real Power Pro 650W - 57A on the +12v line
    Antec 300
    Arctic Cooling Freezer 7 PRO
    Unknown Logitech Wired
    Unknown IBM Wired
    20 mbps download/5 mbps upload
    2x 120mm blue LED front intake fans, 1x 120mm blue LED side intake fan, 1x 140mm blue LED top exhaust fan, 1x 120mm blue LED rear exhaust fan
First of all i need a psu, thinking about a,
Cooler Master Real Power M520 - 520W Modular Power Supply Unit.
This seems like it will be capable for an upgrade.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Taking a look at these tests (I've been spending too much time on Tom's I know :)) there is a negligible increase in performance (6%) from a 2.6ghz dual core to a 3.2ghz quad core when using a 9800GTX. I don't think his CPU is going to be a big problem with a GTS250/9800GTX.
CPU Power for the Graphics Cards - Review Tom's Hardware : GPU vs. CPU Upgrade: Extensive Tests
    Asus M3A-H/HDMI
Maybe i should overclock my cpu?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
The COOLER MASTER Real Power M520 is a solid unit. I believe we all recommend some CPU overclocking, just a little bit.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
How much do you think i could overclock it with that new Psu?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Enough. Around 2.8 ghz or so will be fine. If you weren't getting a new GPU you could take your CPU to it's max (which isn't very high).
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
If i overclock it to 2.8 X3, will i need some extra cooling along with the Psu?
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
I read that the stock AMD CPU cooler is better than the Intel stock cooler, so you should be okay. I'm not sure though, as long as your CPU doesn't pass 60 degrees Celsius you'll be okay. Sure they operate at over 60 but GPU's also operate at 100 degrees Celsius, you don't want that.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
Ok, do you know any software that can monitor my cpu's temperature?
Thanks
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
Use AMD's OverDrive utility, go to the amd website to find it.
You aren't going to get to 2.8ghz with that cpu. I don't think there was ever an 8650 Black Edition and even if you had the unlocked multiplier I still think 2.8ghz would be a stretch.
    Asus M3A-H/HDMI
I think 2.6 should be fine atleast, il use the one on amd's site aswell.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Video cards run off the CPU, 2.3 ghz will bottleneck any good GPU, especially since you have an AMD CPU. How many wattage are on your power supply as well as the amperage on the +12v rail(s)? You're going to have to either find your exact PSU on the web or look at the sticker on the PSU (which will probably require disassembly, so look for your PSU on the web first).
ok a triple core will not bottle neck a video card unless you are using a super high end card
I saw a noticeable performance increase in one of my old systems when I overclocked an E6600 from 2.40 ghz to 3.0 ghz, running an 8800GTX video card (which performs worse than a 9800GTX+/GTS 250) at 1280 x 1024. Then again that is a low resolution and relies more on the CPU. 2.3 ghz is a slow speed regardless, you'll get a big jump in performance if you go to 3.2 ghz or so, even at 1680 x 1050.
The GTS 250 is just a 9800GTX+ but with a faster core clock speed (EVGA's default model is 756 mhz opposed to 738 mhz). It works in SLI only with a 9800GTX+ which must have both equal memory size and memory clock, it doesn't SLI with a 9800GTX at all. That's just silly. Of course a bios flash will most likely change this, but you'll also lose your warranty.
yes because your processor was running at a faster speed which improved things
not because it was bottlenecking the gpu
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
It's not whether it's a triple core or not. The Intel Core 2 DUO E8xxx series outperform the AMD Phenom CPU's (not Phenom II) in quad-core applications.
It was bottlenecking my GPU, that increase in CPU speed allowed my graphics score to improve in 3DMark Vantage.
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
ok as i said high end gpu
    1680 X 1050
    6 Mbs Down 1 Mbs Up
GTS 250 is high end. You also forgot the fact that the OP only has a 1280 x 1024 monitor, therefore the CPU does a lot more work (compared to 1680 x 1050 and above).
    Acer X223W
    1680 x 1050
    Antec 300
    Unknown IBM Wired
ok anyway...
    1680 X 1050
    6 Mbs Down 1 Mbs Up
