Whats your internet speed?
Just tried a tracert. Isn't too bad (I have seen ms in the thousands before, when testing the network at peak times, although I suspect that that isn't to do so much with peak times as unreliability on the phone line)
Code:
Tracing route to sevenforums.com [74.86.171.210]
over a maximum of 30 hops:
  1     7 ms     4 ms     4 ms  192.168.0.1
  2    35 ms    31 ms    35 ms  217.47.89.58
  3    36 ms    31 ms     *     217.47.89.193
  4    34 ms    35 ms    32 ms  213.1.67.134
  5    35 ms    35 ms    36 ms  213.1.79.34
  6    33 ms    35 ms    37 ms  213.1.79.85
  7    35 ms    35 ms    35 ms  87.237.20.246
  8    39 ms    38 ms    38 ms  ae1-0.lontr2.London.opentransit.net [193.251.254
.33]
  9    39 ms    39 ms    43 ms  tengige0-10-0-2.lontr1.London.opentransit.net [1
93.251.242.217]
 10    33 ms    35 ms    35 ms  level3-1.GW.opentransit.net [193.251.248.46]
 11    36 ms    37 ms    43 ms  ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
 12   110 ms   111 ms   107 ms  ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
 13   116 ms   110 ms   119 ms  ae-71-71.csw2.NewYork1.Level3.net [4.69.134.70]
 14   106 ms   111 ms   107 ms  ae-72-72.ebr2.NewYork1.Level3.net [4.69.148.37]
 15   141 ms   143 ms   143 ms  ae-3-3.ebr2.Dallas1.Level3.net [4.69.137.121]
 16   142 ms   143 ms   139 ms  ae-92-92.csw4.Dallas1.Level3.net [4.69.151.165]
 17   146 ms   295 ms   217 ms  ae-4-90.edge2.Dallas3.Level3.net [4.69.145.204]
 18   294 ms   215 ms   219 ms  SOFTLAYER-T.edge2.Dallas3.Level3.net [4.59.36.94
 19   298 ms   215 ms   217 ms  po6.dar02.sr01.dal01.networklayer.com [173.192.1
8.213]
 20   144 ms   147 ms   159 ms  po2.fcr03.sr04.dal01.networklayer.com [66.228.11
8.190]
 21   154 ms   147 ms   151 ms  74.86.175.254-static.reverse.softlayer.com [74.8
6.175.254]
 22   154 ms   150 ms   152 ms  web4.sevenforums.com [74.86.171.210]
Trace complete.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Threason mine is higher is because when our Internet broke a BT guy came over and said that he was going to replace the Limiter at the Exchange box to a better one
So now someone else in out Estate has slower speeds - And we are only paying for 2MB/s speed :)
The further away you are from the Exchange box the slower the speeds
Maybe you should try Mobile Broadband
Well, I am glad for you! We hit about 5kb/s on mobile :( At the back of the house.
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
:( - You could always move house but that is a bit dramatic for Faster internet speeds
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Seeing as house prices are pretty high at the moment, it would probably be cheaper to merge two ADSL cables!
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
    MSI 870A-G54
    EVGA 01G-P3-1452-TR GeForce GTS 450
    Acer 23"
    1920x1080
    OCZ
    In Win
    Thermaltake AF0018 ISGC Fan 12 120mm Case Fan
    Logitech G9
    Ideazon gaming
    Cable
Dang. I'm in the US and I max out at 150 kilobytes/sec download. Only because the one company that provides internet to my area (it's not even rural!) is Qwest, and they charge stupidly high rates if you're not a new member. And to be a new member you have to quit using them for at least a year. And there's no way I'm giving up Internet for a year. I just wish Comcast would put a line through. I basically pay for 30 Meg/sec, but don't get it because they're stupid and don't have any respectable upgrade options. Sorry for the rant :) I'd like die for those 2 meg/sec download speeds haha.
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
I'm surprised that you haven't got more than one alternative. Are you sure? I've just checked, and there are a number of ISPs serving Albuquerque.
Albuquerque Internet Service Providers Isp | Internet Service Providers Isp in Albuquerque, NM - YP.com
Oh I don't live in Albuquerque. I'm about 45 min away in Belen. Well, more like the outskirts of Belen. Although I haven't actually checked for new ISP services in a while... maybe I will. Just figured I'd end up hearing about it if someone new started serving my area.
    Dell Inspiron 1545
    1366x768
    Single built in fan
    Built in
The last time I checked, Comcast told me I have the "Performance" tier of 12/2.
This is with one of the new(ish) ubee DDM-3513 DOCSIS 3.0 cable modems Comcast is handing out. (I exchanged my comparatively ancient Thomson/RCA last weekend.) Handling LAN traffic is a D-Link DIR-825 (ver A, fw 1.01) dual-band (2.4/5GHz) wireless router. All wired connections are GbE.
bat
    DIY
    AMD Athlon 64 x2 5600+ (2.8GHz)
    Gigabyte GA-M57SLI-S4 (rev 2)
    8GB (DDR2-400)
    NVIDIA GeForce 8600 GT (256MB)
    Realtek HD (on mobo)
    LG W2352V (23-in widescreen)
    1920x1080
    1 x 320GB SATA internal - Seagate 1 x 1TB SATA internal - Western Digital 1 x 1TB eSATA external - Fantom Green Drive (WD)
    Antec TruePower Trio 650
    Cooler Master Cosmos 1000
    air, using stock case fans (5x120), CPU fan, GPU fan
    Logitech LX8 (cordless laser)
    Dell QuietKey (old!)
    12/2 (Comcast "Performance")
    3-1/2 Floppy internal IC Diamond thermal paste
Here's my latest speed, after upgrading with Virgin Media in the UK.
    Dell XPS 720
    Itel Core (TM)2 Extreme CPU Q6800 @ 2.93GHz
    2 TB
    NVIDIA GeForce 9900 GTX
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    3 x 1 TB DEL Hard drives.
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
    AMD HD Radeon 6870
    Novatech Night
    Dell XPS 720
    2 TB
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I miss being on Virgin, I have to put up with ADSL since moving :cry:
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Yeah they are bonded, it was the only way to get anywhere near a decent speed.
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Yeah :( But doesn't it cost a fortune though? Paying double the line rental
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I think it's about £87 per month with both lines etc.
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I work from home so it's cheaper than commuting to a workplace, plus it's tax deductible ;)
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
