Hi Americano,
I am on 50 meg and use Netgear for my applications away from my direct wired computer. I always use Netgear as the equipment is good and the service back up is great.
I suggest you look at a WRN2000 router. This will give you up to 300mbps and 5 x coverage. However, always remember that your wired application will always give the best performance and it depends on the time of the day on what speed you get. Nothing is guaranteed until you pay for it.
Thanks, I'll take that into consideration.
We just got our package updated today and after running a speed test the connection is at the same amount. I don't know if they didn't upgrade the speed or if I am already at the maximum speed my router can transfer. Do you, or anyone else, know if this is the case? My router model is:
NETGEAR MR814 v2
