What is going on with the Forum format?
And, will there be any indicators to tell if a member is on-forum, like the orange in the upper right corner for 7F and the green in 10F?
If you hover over the user Icon you should see the User Info box which has various information including the location the user was last seen .... In order to keep the forum layout as clean as possible it may be that a lot of indicators will be / Are located here
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
I thought the number in parentheses on the Tab was how many notifications you had.
Online:View attachment 30376
Offline: View attachment 30377
Thanks Edwin. I've never seen that before I'm used to numbers in parentheses being on the right.
7F
10F
That is notifications.
Thanks John. Now that I'm aware, I have noticed that clicking on the alerts in the menu bar will clear the number(s). So the alerts have to be adjusted in preferences to control the number you get, will there be a global switch to turn them all off or on?
btw: I like the change from grey to blue for the check-boxes.
Thanks Nigel, I'm usually intuitive but I seem to be having a rough time of it lately.
And Now for Something Completely Different...
When creating this post I quoted Edwin, then John, on pg4; Then went to pg5 to add Nigel's, but Edwin's and John's didn't follow to pg5 and I had to copy/paste the first two into Nigel's quote.
    Windows 7
    Gateway DX 4831-01e
    2.93 gigahertz Intel Core i3 530
    Gateway H57M01 | Bus Clock: 133 megahertz
    6GB, SDRAM DDR3
    Intel(R) HD Graphics [Display adapter]
    Realtek HD Audio
    Gateway HX2000 [Monitor] (19.9"visible)
    1600 x 900
    WDC WD10EADS-00M2B0 [Hard drive] (1000.20 GB) HL-DT-ST DVDRAM GH41N [Optical drive]
    300 Watt ATX
    Gateway OEM | mini tower Desktop
    OEM
    Wired USB Optical
    MS Natural Ergo 4000
    Vz FIOS - ping13msL | 30.57Mbps Down | 28.94Mbps up | Speedt
    10 Home 64-bit | v1709| Build -16299.125
    Lenovo ideapad 110 151SK | Laptop
    Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
    Lenovo ideapad 110 MP14MK45 vSDK0J40700 WIN
    8GB DDR4-2133 SODIMM PC4-17000P-S
    (1) Conexant SmartAudio HD | (2) Intel(R) Display Audio
    15.6" HD display* | 1366 x 768 resolution
    1366 x 768 x 32 bits (4294967296 colors) @ 59 Hz
    1TB TOSHIBA MQ01ABD100 | CD/DVD+RW
    OEM
    Laptop
    OEM
    ELAN Trackpad | Logitech M185 USB dongle wireless optical
    OEM
    Vz FIOS - ping13msL | 30.57Mbps Down | 28.94Mbps up | Speedtest.ne
Trying Multi-quoting...
doesn't seem to work as expected, can't seem to empty the clipboard or cancel a post...
    Windows 7 Home Premium
    HP Pavillion
    AMD
    Megatrends
    8GB
    Nvidia 650Ti
    Realtek
    Two 27", One 23", One 50"TV
    1920x1080
    Kingston 125GB SSD, Samsung EVO 500GB SSD
    Thermaltake
    generic
    generic
    Logitech MX Master 2S
    Logitech G710+
    normal
    Windows 10 Home
    Tablet
7F View attachment 30383 10F View attachment 30384
This is the base for what we will be doing, there is lots to do yet so it's not worth reporting anything.
Wait a minute, it works!
    HP Pavillion
    AMD
    Megatrends
    8GB
    Nvidia 650Ti
    Realtek
    1920x1080
    Thermaltake
    generic
    generic
    Logitech G710+
    normal
    Windows 10 Home
    Tablet
    HP Pavillion
    AMD
    Megatrends
    8GB
    Nvidia 650Ti
    Realtek
    1920x1080
    Thermaltake
    generic
    generic
    Logitech G710+
    normal
    Windows 10 Home
    Tablet
