Web Browser For Vista Extended Kernel
It's only for extended kernel...
Oh gotcha! When I saw it for MSFN, and asked if it was being compiled for x86, you had mentioned that you'd be creating such a build. Damn! Did not know it was only for KernelEx. Oh well!
I wonder if that was edited in after Saturday, because I wouldn't have asked then.
    Windows 8 Pro x64
    HP xw8600 Workstation
    Two Intel Xeon Core2 Quad 3.2 GHz Processors
    Proprietary
    16 GB DDR2 800 MHz
    nVidia Quadro FX 3800 PCI-E
    Realtek HD Audio
    Samsung SyncMaster 213T 21" 4x3 Flat Screen
    1600x1200
    Two Seagate Cheetah 300 GB SAS Disks
    Proprietary
    HP xw8600 Workstation Case
    Two CPU Fans and One Larger Cooling Fan
    Microsoft USB Optical Mouse
    PS/2 Keyboard
    7 mbps
    Storage Interface: Two LSI 3000 SAS Adapters Browser: Firefox ESR 102
Actually, I originally forgot to mention the required extended kernel. Actually was a post modified. Sorry for getted your hopes up :(
    Windows Vista and 8.0.
Well I have ArticFoxie's 360Chrome mod for now. But being on v86 of Chromium is a bit iffy. It works well though.
    Windows 8 Pro x64
    Proprietary
    16 GB DDR2 800 MHz
    Realtek HD Audio
    1600x1200
    Proprietary
    PS/2 Keyboard
    7 mbps
...i think Slimjet will do the same in some time, they backported chrome 50 on Vista and XP, it is likely that they will backport at least 1 version of chrome for Win 7 and 8.1
Slimjet 39.0 beta based on Chromium 110 has just appeared in Slimjet Version History, but no mention one way or the other about Windows 7 support? Of course 110 should work with the latest extended kernel anyway, but wither 3 might want to try it on Win 7 and Jody might want to try on 8.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I never heard of “Softexia,” but here is the official Slimjet Web Browser Download page (you may have to click “Show All Platforms”). Still no reports of anyone actually trying 39.0 beta on Windows 7 or 8, although 38.0.8 stable (based on Chromium 109) should certainly work.
    Intel Q6600
    3 GB
An MSFN members says Slimjet 39.0 doesn’t run on Windows 7, which doesn’t surprise me. :(
    Intel Q6600
    3 GB
I tried the 64 bit web installer and it says the processor entry point Set Process................................. could not be found in kernel32.dll. In the link you provided, someone responded 6 hours ago and provided what appears to be a procedure for correcting the situation. Not sure if he wants one to run everything from the command prompt.
I tried the 32 bit web installer and it says it can't start because its side-by-side configuration is incorrect. That's usually related to C++. I don't know which version is required. I have 10, 12 and 15 installed. It should install whichever version is required.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
