Vista wont star, help!!
I do not know what is causing that problem, the flash has to be recognized (seen) by the computer.
Your computer has the black screen. It can be caused by a virus, which has to be removed, hardware problems or bad drivers/cards.
I dont know what to do to get it started, other than what I told you.
There have been situations, that if you just let it rest for a few hours it comes back.
I dont know where to go from here. We tried to repair and boot and it did not work.
The repair that is needed will be shown after we boot. It will give access to system restore, safe mode, etc. We could try to something else, but the you lose all your stuff.
I gave you that already, Ubuntu, but you cant boot into it.
Thats why I have nothing else to offer.
We dont have a tutorial on that, I gave you the best thing that I had.
Of course, but the one that I gave you, I think is one of the best. Its clear to understand.
If you backup your stuff and then reinstall, your stuff is saved.
I would help you with the flash, if I knew more than the article that I sent. That says everything. If I find something better online, Ill post it.
