Vista wont star, help!!
It would have to be bootable.
First it has to boot and we are having problems with that.
Second you have to follow the instuctions after it boots.
I think it may be best to wait for Mom. I would feel very bad if something happened and we lost your stuff.
First thing you do on another computer burn the CD
Then if the computer boots, boot from the Cd
Then go back to my post and see what to do once Ubuntu is loaded.
If we cannot save your stuff, I do think I will wait for Mom.
. If you cannot get it up and running with the infromation that I gave you, seriously wait for Mom..
i tried to install win to flash - it makes flash bootable , but what do i do if it says ricorrect source of windows files [ i`ve got a problem installing it.]
Things are getting a bit too technical. Im afraid that we may make it worse. I know that you are concerend about Mom, but she loves you and will help. Im not comfortable going any further.
dude, cmoon. my mom payed about 180$ for the service - we better fix it & i got a feeling it`ll be ok. :]]] i found on the internet how to make flash bootable.
If you know how to make a flash bootable, you have everything that you need. There really is not much more that I can tell you.
Just boot the DVD or flash and save your stuff.
You are in over your head, lets wait for Mom,
Actually, you have all the instuctions. If you can boot into Ubuntu, just follow the instuctions that I gave regarding backing up your stuff.
The bios on the Mother Board needs to support booting from a USB device...some newer motherboards have this feature; your computer may not.
