User Account Control (UAC) - Elevate Privilege Level
How to Elevate All Administrator Accounts UAC Privilege Level
This will show you how to change all administrator account's UAC Privilege Level to keep UAC on and not prompt an admnistrator, have UAC ask administrator for password, or the default of asking an Administrator to Continue for permission. UAC will still be on and work as usual for the Standard and Guests account types. For more information, see:
This will still leave Protected Mode: ON in Internet Explorer to.
To Have UAC Progam Exceptions to not have UAC ask for your permission on certain programs in Vista only, then you can use the Norton UAC Tool for this. This program will not work in Window 7.
This can only be done while logged on to an administrator account.
OPTION ONE
Using a REG File Download
1. To Elevate Administrators Privilege Level for no Prompting by UAC
NOTE: When you elevate the administrator accounts privilege level, the Security Center in Vista will give you an alert warning notification in the notification area of the taskbar until you undo this. To turn this alert off, see: How to Disable or Enable the Security Center Alert Warning Notification in Vista.​
Elevate_Administrator_Priviledge.reg
download
B) Go to step 4.​
2. To Have UAC Prompt Administrators for a Password
NOTE: This will act just like it does in a Standard account by UAC asking you for the administrator's password before continuing.​
Administrator_UAC_Require_Password.reg
download
B) Go to step 4.​
3. To Have UAC Prompt Administrators for a Continue or Yes
NOTE: This is the default setting for UAC asking the administrator to click on Continue (Vista) or Yes (Windows 7) to give permission.​
Restore_Default_Settings.reg
download
4. Click on Save, and save the .reg file to the Desktop.​
5. Right click on the downloaded .reg file and click on Merge.​
6. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
7. Log off and log on, or restart the computer to apply the changes.​
8. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Through Local Security Policy
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions.
1. Open the Local Security Policy editor.​
2. In the left pane, click on Local Policies. (See screenshot below step 5)​
3. Click on Security Options.​
4. In the right pane, double click on User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode.​
5. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Click on the drop down arrow and change the setting to Elevate without prompting. (See screenshot below step 8)​
B) Go to step 8.​
6. To Have UAC Prompt Administrators for a Password
A) Click on the drop down arrow and change the setting to Prompt for credentials. (See screenshot below step 8)​
B) Go to step 8.​
7. To Have UAC Prompt Administrators for a Continue or Yes
A) Click on the drop down arrow and change the setting to Prompt for consent. (See screenshot below step 8)​
8. Click on OK to apply.​
9. Close the Local Security Policy window. Your Done.​
OPTION THREE
Manually Using Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
5. In the right pane, right click on ConsentPromptBehaviorAdmin and click on Modify.​
6. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Type 0 (Number) and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
7. To Have UAC Prompt Administrators for a Password
A) Type 1 and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
8. To Have UAC Prompt Administrators for a Continue or Yes
A) Type 2 and click on OK.​
9. Close regedit.​
10. Log off and log on, or restart the computer to apply the changes.​
i just tried to follow this tutorial but when i try to launch secpol.msc i get an error message that says An attempt was made to reference a token that does not exist..... any ideas?
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
Hello Ripbox,
Are you doing this from within an administrator account?
If you are, then from what I have read on this error, it may be caused by a startup program interfering with this from a potential Virus or malware. You might temporarily disable all of your startup programs and restart the computer as a test to see.
up its from an admin account so ill give your start-up idea a whirl:)
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
Re: User Account Control - Require Password
What I'd like to know is how to UNDO this particular change. I have Vista Home Premium 32-bit and I used one of those "tweaker" applications to turn on the password when the elevation prompt dialog appears. Now that same tweaker doesn't work to disable the password and return to the simple "click to continue" model.
Never mind that I'm an idiot for using one of those tweakers - the problem is that secpol.msc does not exist on this machine so far as I can tell and I don't know how else to disable the password check. Is there a registry key somewhere that can be edited or some other way to return to the default elevation prompt behavior?
    Gateway MT6920
    Intel Core 2 Duo 1.8GHz
    unknown
    3GB
    unknown
    unknown
    built-in LCD
    dial-up (53k)
Hello Beerslayer,
You can use one of the OPTIONS to To Have UAC Prompt Administrators for a Continue to return to the default UAC setting.
I had UAC turned off, but thought I'd give your "elevate privilege level" a try to avoid the " UAC is turned off " notification. Now I have security shields on some icons, and with SpywareBlaster for example, it tells me I do not have the privileges to Immunize, when I update, and if I click OK, it then goes ahead and immunizes anyway. Is that how it should be?
Security centre tells me UAC is turned off too.
Couple of hours later: Just restarted and security icons are now gone. A bit confusing, but I guess a longer trial will make the effect of these changes clearer.
    home built
    E8500 @ 3.8Ghz (400 fsb)
    Gigabyte GA-X48-DQ6
    Corsair 2X2 Gig 1066mhz 8500CDF
    MSI GTX280 OC 1Gig
    on board
    LG Flatron W2242T
    1680 x 1050
    2 x Seagate 320Gig ST3320620AS
    Antec True power 2.0 550 watt and Thermaltake 450 watt vga
    Cooler Master CM690
    Intel oem
    Microsoft laser usb
    Logitech usb
    8192 / 384 kbps
Hello Seasalt, and welcome to Vista Forums.
Yeah, any time you change the UAC permission level you will need to restart the computer afterwards to apply the change as per the second to last step in the tutorial. ;)
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
You're welcome Shawn, glad I can help out.
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
Vista Home Premium -- tried both ways, turns of UAC quite nicely, but i keep getting alerts from windows security center: "user account control is turned off". i don't see turning off alerts as an option, because i like the way security center alerts me when my antivirus or firewall is down. you don't have a way to disable UAC for admin. without getting this alert from windows security center??
Hello PimpleMaze, and welcome to Vista Forums.
In METHOD TWO, did you use either step 1 in downloads or step 6 in the manual way?
