User Account Control (UAC) - Elevate Privilege Level
How to Elevate All Administrator Accounts UAC Privilege Level
This will show you how to change all administrator account's UAC Privilege Level to keep UAC on and not prompt an admnistrator, have UAC ask administrator for password, or the default of asking an Administrator to Continue for permission. UAC will still be on and work as usual for the Standard and Guests account types. For more information, see:
This will still leave Protected Mode: ON in Internet Explorer to.
To Have UAC Progam Exceptions to not have UAC ask for your permission on certain programs in Vista only, then you can use the Norton UAC Tool for this. This program will not work in Window 7.
This can only be done while logged on to an administrator account.
OPTION ONE
Using a REG File Download
1. To Elevate Administrators Privilege Level for no Prompting by UAC
NOTE: When you elevate the administrator accounts privilege level, the Security Center in Vista will give you an alert warning notification in the notification area of the taskbar until you undo this. To turn this alert off, see: How to Disable or Enable the Security Center Alert Warning Notification in Vista.​
Elevate_Administrator_Priviledge.reg
download
B) Go to step 4.​
2. To Have UAC Prompt Administrators for a Password
NOTE: This will act just like it does in a Standard account by UAC asking you for the administrator's password before continuing.​
Administrator_UAC_Require_Password.reg
download
B) Go to step 4.​
3. To Have UAC Prompt Administrators for a Continue or Yes
NOTE: This is the default setting for UAC asking the administrator to click on Continue (Vista) or Yes (Windows 7) to give permission.​
Restore_Default_Settings.reg
download
4. Click on Save, and save the .reg file to the Desktop.​
5. Right click on the downloaded .reg file and click on Merge.​
6. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and then OK when prompted.​
7. Log off and log on, or restart the computer to apply the changes.​
8. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Through Local Security Policy
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions.
1. Open the Local Security Policy editor.​
2. In the left pane, click on Local Policies. (See screenshot below step 5)​
3. Click on Security Options.​
4. In the right pane, double click on User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode.​
5. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Click on the drop down arrow and change the setting to Elevate without prompting. (See screenshot below step 8)​
B) Go to step 8.​
6. To Have UAC Prompt Administrators for a Password
A) Click on the drop down arrow and change the setting to Prompt for credentials. (See screenshot below step 8)​
B) Go to step 8.​
7. To Have UAC Prompt Administrators for a Continue or Yes
A) Click on the drop down arrow and change the setting to Prompt for consent. (See screenshot below step 8)​
8. Click on OK to apply.​
9. Close the Local Security Policy window. Your Done.​
OPTION THREE
Manually Using Registry Editor
1. Open the Start Menu.​
3. If prompted by UAC, then click on the Continue (Vista) or Yes (Windows 7).​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
5. In the right pane, right click on ConsentPromptBehaviorAdmin and click on Modify.​
6. To Elevate Administrators Privilege Level for no Prompting by UAC
A) Type 0 (Number) and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
7. To Have UAC Prompt Administrators for a Password
A) Type 1 and click on OK. (See screenshot below step 8)​
B) Go to step 9.​
8. To Have UAC Prompt Administrators for a Continue or Yes
A) Type 2 and click on OK.​
9. Close regedit.​
10. Log off and log on, or restart the computer to apply the changes.​
Zidnea,
It depends on what type of Vista installation DVD you have.
Retail Full version:
http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html
Retail Upgrade version:
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
OEM (store bought) Recovery Partition: (No DVD)
You will need to check you computer's documentations for the exact procedure, but you usually press something like F10 or F11 during bootup to boot into the Recovery Manager screen to select something like the Restore to factory default option.
Your welcome Zidnea.
Hi Shawn,
At last here's an app that lets you create exceptions for the UAC prompt - without turning anything else off.
I am using it on x64 no problems .
It replaces the UAC prompt - a similar looking widow pops up and you can allow or cancel , but if you tick the "Don't ask me again" box and then the Allow box - that app. will run in future with no prompts.
Two points:
First uncheck the allow submissions box that appears during install process - to stop info. being sent back to Norton.
Second, once I have done the Always allow , I haven't yet found a way to reverse that without uninstalling the app.
It's free from Norton 32bit and 64 bit available
User Account Control Management - Vista UAC | Norton Labs
Your view on this would be appreciated as always
Thanks again
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Hi SIW2,
I'm a bit nervous about installing anything Norton with all of the trouble they had with their AV program and Vista at first.
There may be a registry entry that holds the exception information. You may have to search using Norton in the registry to see if it is for that program. I'll be surprised if it doesn't have some way to remove a program from it's exception list.
I will have to give it a try later tonight to see if what I can find and how well it runs. ;)
Thank you for mentioning this program.
Hi Shawn,
Know what you mean ;) - that's why I wanted to use it bit before bringing it up - works as advertised so far .
Uninstalled and reinstalled it without a hitch. Had a quick look with Nir Sofer's Regscanner - doesn't seem to list the allowed apps in any easily identifiable way.
Still, I know which I want to allow , so it's not a prob, and uninstalling the uac manager returned everything to previous state.:D
Look forward to hearing your experiences
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
SIW2,
It's a nice little program. I used Process Monitor with it to track down where it installs everything, but no luck either with understanding what is the exception list.
It seems to work perfectly fine for me to.
I understand that it is just a beta right now, but it would be nice if they added some form of user interface to allow the user to add and remove exceptions manually. Perhaps by way of a tray icon.
So far, I say it looks very promising and is perfectly functional now. :geek:
To bad it probably will not end up as a free program when the final version is released. :(
Okay I'm just about rdy to switch to my new computer and install vista home premium on it. With XP I created a single account and it has Administrative rights, didn't do a password and everything went just fine. Will I need to do things diffrently with Vista on a clean install? UAC sounds like a bit of a pain in general since other than my room mates access to a shared folder no one but me uses my system & I like to have complete control including viewing hidden and system folders.
Hi Bratboy1,
UAC can be a pain at first until you have everything setup and installed. After that it's not to bad.
With Vista your administrator accounts acts just like a Standard account except that UAC will then ask you to approve anything that wants to run with administrator rights first. In a Standard account, you must also provide the administrator's password to approve UAC.
Okay is there a guide you would recommend I use so I ca set things up as I described? What I want to do is just create one account with Admin power but without any sort of password being required when I boot into Vista Home Premium.
ARRG!! Trying to wrap my head around this and still having problems understanding things. Here's what I want to do:
1. Create a user log/account in of say "Monkeyboy" that doesnt require me to enter a user password
2. Grant "Monkeyboy" complete administraitive access like one can do in XP. Thus not requiring UAC box from poping open when I do stuff.
Sounds like I would have to jump thru some hoops to do this. Or am I making things more complicated than need be?
Hi Bratboy,
Have you installed yet? If not , see STEP 2 of this tutorial. Just enter the username Monkeyboy, leave the password boxes blank, click a picture and click next.
This should then logon automatically without having to enter anything
I use this to control UAC - it's beta so use at your own risk, but I have had no problems with it.
User Access Control - Vista User Account Control - UAC | Norton Labs
You may feel that is safer than using the built in Administrator account.
Hope it helps
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
LOL, you're welcome Ebrena. Welcome to Vista Forums.
Thank you so much. I love you guys. I really appreciate the help you have provided me in just a couple of minutes.
    Intel Core 2 Extreme Quad-Core Processor QX6850 (4x 3.0GHz)
    Asus Striker Extreme nForce® 680i SLI Chipset
    4096MB DDR2-800 PC6400 Memory Module Mushkin High Performance II
    NVIDIA GeForce 8800 Ultra 768MB w/DVI + TV Out Video
    Creative Lab Sound Blaster X-Fi Platinum Fatal1ty Champion
    LCD Monitor ViewSonic 19"
    1024x768
    1.5TB (750GB x2)
    Nzxt Hush Gaming Tower Case
    Thermaltake MaxOrb CPU Cooling Fan System Kit
    Razer Diamondback Plasma Edition Gaming Mouse
    Logitech G15 Gaming Keyboard
    1 GB Down/ 1.5GB Up
    Meter Display ( Thermal Temperature LCD Display Black ) Flash Media Reader/Writer ( 12-In-1 Internal Flash Media Card Reader/Writer Black ) TV Tuner ( External TV-Tuner w/Remote Control )
You're welcome Joseeg12, and welcome to Vista Forums.
Hi Shawn.... I have this Dell computer with Home Basic in it. Got scared to do anything with it when the issues re updates broke out and the Windows Update made a mess of the updating process. I just recently discovered your site and taking my first steps to fix/reclaim my machine. Thanks a lot!!!:):geek::)
You're welcome Toufen, and welcome to Vista Forums. Please feel free to post any question you have in the forums. We will be happy to help where we can.
