Try to boot from that drive using a bootable cd such as windows vista, using which you can drill the issue down to a hardware or a software. If it boots then drive is fine, if not then the drive is gone.
You can also try this file. You have to save it to the desktop & then right click & merge.
- T4200 Intel
- 2 X 1GB DDR2
- Intel Integrated
- 1 X 250GB 7200RPM
